Domoticz shows only 2 sensor parts SNZB-02
Posted: Tuesday 03 May 2022 20:46
Working on a new Domoticz installation on Docker.
Ran into some problems.
I have:
Raspberry Pi 4b with docker 20.10.14 on Raspbian Bullseye
Domoticz 2022.1 on Docker
Zigbee2MQTT 1.25.0 on Docker
Mosquitto 2.0.14 on Docker.
Everything seems to works fine. Autodiscovery sees the Sonoff SNZB-02.
The Domoticz log shows 4 items voor this temperature sensor:
Status: Zigbee_Auto: discovered: 0x00124b0022cf700a/0x00124b0022cf700a battery (unique_id: 0x00124b0022cf700a_battery_zigbee2mqtt)
Status: Zigbee_Auto: discovered: 0x00124b0022cf700a/0x00124b0022cf700a temperature (unique_id: 0x00124b0022cf700a_temperature_zigbee2mqtt)
Status: Zigbee_Auto: discovered: 0x00124b0022cf700a/0x00124b0022cf700a humidity (unique_id: 0x00124b0022cf700a_humidity_zigbee2mqtt)
tatus: Zigbee_Auto: discovered: 0x00124b0022cf700a/0x00124b0022cf700a voltage (unique_id: 0x00124b0022cf700a_voltage_zigbee2mqtt)
If got only two items in my Devices list:
zigbee2mqtt_0x00124b0022cf700a and 0x00124b0022cf700a_voltage_zigbee2mqtt.
They show both the correct values.
I am missing the battery and the separated temperature and humidity values.
Any ideas?
I have:
Any ideas?
