Domoticz shows only 2 sensor parts SNZB-02
YellowBee59
Domoticz version: 2022.1
Post by YellowBee59 »
Working on a new Domoticz installation on Docker.
Ran into some problems.
I have:
Raspberry Pi 4b with docker 20.10.14 on Raspbian Bullseye
Domoticz 2022.1 on Docker
Zigbee2MQTT 1.25.0 on Docker
Mosquitto 2.0.14 on Docker.
Everything seems to works fine. Autodiscovery sees the Sonoff SNZB-02.
The Domoticz log shows 4 items voor this temperature sensor:
Status: Zigbee_Auto: discovered: 0x00124b0022cf700a/0x00124b0022cf700a battery (unique_id: 0x00124b0022cf700a_battery_zigbee2mqtt)
Status: Zigbee_Auto: discovered: 0x00124b0022cf700a/0x00124b0022cf700a temperature (unique_id: 0x00124b0022cf700a_temperature_zigbee2mqtt)
Status: Zigbee_Auto: discovered: 0x00124b0022cf700a/0x00124b0022cf700a humidity (unique_id: 0x00124b0022cf700a_humidity_zigbee2mqtt)
tatus: Zigbee_Auto: discovered: 0x00124b0022cf700a/0x00124b0022cf700a voltage (unique_id: 0x00124b0022cf700a_voltage_zigbee2mqtt)
If got only two items in my Devices list:
zigbee2mqtt_0x00124b0022cf700a and 0x00124b0022cf700a_voltage_zigbee2mqtt.
They show both the correct values.
I am missing the battery and the separated temperature and humidity values.
Any ideas?
Re: Domoticz shows only 2 sensor parts SNZB-02
battery could be interpreted as the battery status (so not a real device but a value linked to the temperature device).
You should get a battery status indicator after some time (could take a day).
What kind of device are you getting, a combined temperature/Humidity?
Can you make a screenshot of all the 0x00124b0022cf700a devices in the device list?
YellowBee59
Thanks for your response. The situation has changed. My old Domoticz has crashed so I had to take the new one quicker in 'production'. Decided to use the old way with the plugin. That works good. But not able to make a screenshot anymore. :-(
My plan is now to install a new Domoticz on Docker (different Pi) and test it again.
What if got was indeed a combined temp/humi device. And a voltage device.
