Adding characters to output of text-string
Toulon7559
Domoticz version: <2025
Post by Toulon7559 »
Translating the contents of the KNMI Weather-info for an application, (amongst others) I use following lua-script-line for generation of output
file:write("$forecast = " .. summary1 .. ";\n") --forecast
A typical result today from that lua-script-line is
$forecast = Zonnige perioden;
However, the application reading this textstring requires to see
$forecast = "Zonnige perioden";
Simple question, but causing headache:
how to get those enclosing " into the string?
Have looked at lua.org, but not yet seen a suitable answer
In other words:
need to find a way to insert ASCII-character hex022 into the text-string coming from that lua-script-line.
boum
Domoticz version: 4.10717
Re: Adding characters to output of text-string
Post by boum »
Either switch your double quotes to single quotes.
Or just escape the character:
file:write("$forecast = \"" .. summary1 .. "\";\n") --forecast
Toulon7559
Thanks for the hint!
