MQTT solar-assistant
octy
Post by octy »
I have a inverter connected to Solar-Assistant and they released mqtt support ( https://solar-assistant.io/help/integration/mqtt )
Have sett it up as i think it works, but get the messages under.
Is it something i can do, someone want to nudge me in the right direction? :?
octy
Re: MQTT solar-assistant
Post by octy »
Solved some of them, did not have Auto Discovery Prefix to homeassistant.
But the ones containing battery information did not get created:
total/battery_power/state
total/battery_state_of_charge/state
Inverter_1/battery_voltage/state
Inverter_1/battery_current/state
And the temperature sender from the inverter is reporting low battery, but does not have battery..
Any idea where/how i can edit and add the missing devices?
gizmocuz
Post by gizmocuz »
Battery information can/should be found in the device overview
Could you post the config/data MQTT object of your inverter? You can find this by using (for example) MQTT Explorer
octy
Post by octy »
Updated
Here is what sensors i get, log and mqtt info.
Think the solar unit is made for home assistant
octy
Post by octy »
Some of the battery sensors does not show in domoticz, and some of the sensors in the inverter randomly says its low on battery.
Amahoki
Post by Amahoki »
Dear Octy,
I just installed SolarAssistant connected to my 3 inverters, and when trying to link with domoticz, I have the same red errors in the log as in your first post.
Did you solved this finaly?
If you have any clue to help would be great.
Thank you
Amahoki
Post by Amahoki »
Dear Octy,
Finaly I can get all inverters information except battery SoC, voltage and current.
Did you find a way for those?
Thank you
nico21311
Post by nico21311 »
Dear all
I found how to have all information from solar_assistant prefix
you need to install domoticz-mqttmapper-plugin
https://github.com/FlyingDomotic/domoti ... me-ov-file
follow the instruction to install it
after that your need to configure your file.json (find my configuration below for example)
to customize the parameter use :
https://www.domoticz.com/wiki/Developin ... vice_Types
hoping that help you
   "battery pourcentage": {
        "topic": "solar_assistant/total/battery_state_of_charge/state",
        "type": "243", "subtype": "6","switchtype": "0",
        "mapping": {"item": ""}
		"battery current inverter 1": {
        "topic": "solar_assistant/inverter_1/battery_current/state",
        "type": "243", "subtype": "23","switchtype": "0",
		"battery current inverter 2": {
        "topic": "solar_assistant/inverter_2/battery_current/state",
	"battery voltage Inverter 1": {
        "topic": "solar_assistant/inverter_1/battery_voltage/state",
        "type": "243", "subtype": "8","switchtype": "0",
		"battery voltage Inverter 2": {
        "topic": "solar_assistant/inverter_2/battery_voltage/state",
