Hi everyone,
I have an Sonoff TH10 flashed with ESPHome.
Created this config in the YAML file for ESPHome:
switch:
- platform: gpio
pin: 12
name: "Slaapkamer - Lamp"
The device is discovered in Domoticz and works fine, however logging says:
MQTT Autodiscovery HomeAssistant: Unhandled color switch type '{ onoff }' (Slaapkamer - Lamp)
any ideas?
- gizmocuz
Re: Unhandled color switch type '{ onoff }
Is it possible you can post the 'config' MQTT object of this color switch ?
You can find this by using a application like MQTT Explorer to connect to your broker
