Plugins and Python 3.10
Posted: Saturday 12 March 2022 10:18
by meyland
Right now I'm running Domoticz version 2022.1 (build 14268) on Fedora 35 and Phyton 3.10.2. I have installed some plug-ins in my Domoticz environment and the most of them are working without problems. But two of them says "
Python exception set prior to callback 'onMessage'", which results in no input from the plug-ins.
The two plug-ins are:
- Domoticz-deCONZ
- yamaha-av-receiver
I have, of course, checked for newer versions of the plug-ins
Can anyone give me at hint to a solution?
Re: Plugins and Python 3.10
Posted: Saturday 12 March 2022 11:38
by waltervl
Python 3.10 support in Domoticz beta is still experimental. Fedora is also not very common.
Can you post some more logging?
Posted: Saturday 12 March 2022 13:10
by meyland
I would like to give more information, but the text "Python exception set prior to callback 'onMessage'" is the only message I get. Can you maybe tell me how I can enable more logging.
Posted: Saturday 12 March 2022 14:41
by waltervl
Sometimes you can set extra debug logging on in the plugin (through menu setup - hardware).
What happens if you only update the plugin without changing anything through menu setup - hardware (it will/should restart).
Posted: Tuesday 15 March 2022 21:13
by meyland
I have now tried to turn on debug info in the Yamaha Plug-in and there are a lot of info, but no extra info about the error, only the text "Python exception set prior to callback 'onMessage'". Before I upgraded my server to Fedora 35 (and Python 3.10) everything was working.
Posted: Sunday 20 March 2022 14:30
by meyland
I've tried to do some debugging in det code. I've modified the function ProcessInbound in class CPluginProtocolLine (PluginProtocols.cpp, line 101), so I got som debug information:
void CPluginProtocolLine::ProcessInbound(const ReadEvent* Message)
CConnection* pConnection = Message->m_pConnection; //pm
CPlugin* pPlugin = pConnection->pPlugin; //pm
pPlugin->Log(LOG_ERROR, "(%s) entry", __func__); //pm
// Handles the cases where a read contains a partial message or multiple messages
std::vector<byte> vData = m_sRetainedData; // if there was some data left over from last time add it back in
vData.insert(vData.end(), Message->m_Buffer.begin(), Message->m_Buffer.end()); // add the new data
std::string sData(vData.begin(), vData.end());
int iPos = sData.find_first_of('\r'); // Look for message terminator
pPlugin->Log(LOG_ERROR, "(%s) iPos : %d", __func__, iPos); //pm
pPlugin->Log(LOG_ERROR, "(%s) string: %s", __func__, sData.c_str()); //pm
while (iPos != std::string::npos)
Message->m_pConnection->pPlugin->MessagePlugin(new onMessageCallback(Message->m_pConnection, std::vector<byte>(&sData[0], &sData[iPos])));
if (sData[iPos + 1] == '\n') iPos++; // Handle \r\n
sData = sData.substr(iPos + 1);
m_sRetainedData.assign(sData.c_str(), sData.c_str() + sData.length()); // retain any residual for next time
pPlugin->Log(LOG_ERROR, "(%s) exit", __func__); //pm
The Yamaha plugin sends these commands to the receiver when started:
@MAIN:PWR=?
@MAIN:VOL=?
@MAIN:INP=?
@MAIN:MUTE=?
@MAIN:SOUNDPRG=?
@MAIN:STRAIGHT=?
and the modificed code gives this result:
2022-03-20 14:19:33.149 Error: AVR Yamaha: (ProcessInbound) entry
2022-03-20 14:19:33.149 Error: AVR Yamaha: (ProcessInbound) iPos : 12
2022-03-20 14:19:33.149 Error: AVR Yamaha: (ProcessInbound) string: @MAIN:PWR=On
2022-03-20 14:19:33.149 Error: AVR Yamaha: (ProcessInbound) iPos : -1
2022-03-20 14:19:33.149 Error: AVR Yamaha: (ProcessInbound) exit
2022-03-20 14:19:33.149 Error: AVR Yamaha: (ProcessInbound) iPos : 15
2022-03-20 14:19:33.149 Error: AVR Yamaha: (ProcessInbound) string: @MAIN:VOL=-50.0
@MAIN:INP=TUNER
@MAIN:MUTE=Off
@MAIN:SOUNDPRG=2ch Stereo
@MAIN:STRAIGHT=Off
2022-03-20 14:19:33.149 Error: AVR Yamaha: (ProcessInbound) string: @MAIN:INP=TUNER
@MAIN:MUTE=Off
@MAIN:STRAIGHT=Off
2022-03-20 14:19:33.150 Error: AVR Yamaha: (ProcessInbound) iPos : 14
2022-03-20 14:19:33.150 Error: AVR Yamaha: (ProcessInbound) string: @MAIN:MUTE=Off
@MAIN:STRAIGHT=Off
2022-03-20 14:19:33.150 Error: AVR Yamaha: (ProcessInbound) iPos : 25
2022-03-20 14:19:33.150 Error: AVR Yamaha: (ProcessInbound) string: @MAIN:SOUNDPRG=2ch Stereo
@MAIN:STRAIGHT=Off
2022-03-20 14:19:33.150 Error: AVR Yamaha: (ProcessInbound) iPos : 18
2022-03-20 14:19:33.150 Error: AVR Yamaha: (ProcessInbound) string: @MAIN:STRAIGHT=Off
2022-03-20 14:19:33.150 Error: AVR Yamaha: (ProcessInbound) iPos : -1
2022-03-20 14:19:33.150 Error: AVR Yamaha: (ProcessInbound) exit
2022-03-20 14:19:33.150 Error: AVR Yamaha: Call to function 'onMessage' failed, exception details:
2022-03-20 14:19:33.162 Error: AVR Yamaha: Exception: 'SystemError'. No traceback available.
2022-03-20 14:19:33.162 AVR Yamaha: (AVR Yamaha) Python exception set prior to callback 'onMessage'
2022-03-20 14:19:33.162 Error: AVR Yamaha: Call to function 'onMessage' failed, exception details:
2022-03-20 14:19:33.162 Error: AVR Yamaha: Exception: 'TypeError'. No traceback available.
2022-03-20 14:19:33.163 Error: AVR Yamaha: Exception: 'TypeError'. No traceback available.
2022-03-20 14:19:33.163 Error: AVR Yamaha: Call to function 'onMessage' failed, exception details:
2022-03-20 14:19:33.163 Error: AVR Yamaha: Exception: 'SystemError'. No traceback available.
2022-03-20 14:19:33.163 AVR Yamaha: (AVR Yamaha) Python exception set prior to callback 'onMessage'
2022-03-20 14:19:37.234 Status: AVR Yamaha: Stop directive received.
Posted: Monday 04 April 2022 12:10
by jzapater
I have the same problem with Domoticz-Tuya-Thermostat-Plugin
Any solution ?
Posted: Friday 27 May 2022 19:35
by jzapater
Thanks, @dnpwwo.
Resolved in your commit 0c099e19745c6440dd86446509516ce2947eb9a5
Posted: Wednesday 24 August 2022 13:46
by epierre
seems the Linky plugin has some issue also on 3.10, though through alternatives I am unable to force 3.8 as domoticz always use 3.10 and I don't know why (even with strace...)
Posted: Thursday 01 September 2022 20:30
by Barberousse
epierre wrote: Wednesday 24 August 2022 13:46
To be more specific, there are troubles with the Configuration object, giving the message "Error: (JSONtoPython) failed to add item '-1', to list for string." for each Domoticz.Configuration(Config) call.
I will check if I'm able to reproduce on a very simple test plugin.
Domoticz V2022.1 (build 14479)
Python 3.10.4
Ubuntu 22.10
Posted: Monday 05 September 2022 15:13
by epierre
for me working since yesterday, updating toward the git !
