Plugins and Python 3.10
meyland
Post by meyland »
Right now I'm running Domoticz version 2022.1 (build 14268) on Fedora 35 and Phyton 3.10.2. I have installed some plug-ins in my Domoticz environment and the most of them are working without problems. But two of them says "Python exception set prior to callback 'onMessage'", which results in no input from the plug-ins.
The two plug-ins are:
  • Domoticz-deCONZ
  • yamaha-av-receiver
I have, of course, checked for newer versions of the plug-ins
Can anyone give me at hint to a solution?
regards
Peter
Re: Plugins and Python 3.10
Python 3.10 support in Domoticz beta is still experimental. Fedora is also not very common.
Can you post some more logging?
meyland
Post by meyland »
I would like to give more information, but the text "Python exception set prior to callback 'onMessage'" is the only message I get. Can you maybe tell me how I can enable more logging.
regards
Peter
Sometimes you can set extra debug logging on in the plugin (through menu setup - hardware).
What happens if you only update the plugin without changing anything through menu setup - hardware (it will/should restart).
meyland
Post by meyland »
I have now tried to turn on debug info in the Yamaha Plug-in and there are a lot of info, but no extra info about the error, only the text "Python exception set prior to callback 'onMessage'". Before I upgraded my server to Fedora 35 (and Python 3.10) everything was working.
regards
Peter
meyland
Post by meyland »
I've tried to do some debugging in det code. I've modified the function ProcessInbound in class CPluginProtocolLine (PluginProtocols.cpp, line 101), so I got som debug information:
	void CPluginProtocolLine::ProcessInbound(const ReadEvent* Message)
		CConnection* pConnection = Message->m_pConnection;    //pm
		CPlugin* pPlugin = pConnection->pPlugin;              //pm
      pPlugin->Log(LOG_ERROR, "(%s) entry", __func__);      //pm
		//	Handles the cases where a read contains a partial message or multiple messages
		std::vector<byte>	vData = m_sRetainedData;										// if there was some data left over from last time add it back in
		vData.insert(vData.end(), Message->m_Buffer.begin(), Message->m_Buffer.end());		// add the new data
		std::string		sData(vData.begin(), vData.end());
		int iPos = sData.find_first_of('\r');		//  Look for message terminator
      pPlugin->Log(LOG_ERROR, "(%s) iPos  : %d", __func__, iPos);  //pm
      pPlugin->Log(LOG_ERROR, "(%s) string: %s", __func__, sData.c_str());  //pm
		while (iPos != std::string::npos)
			Message->m_pConnection->pPlugin->MessagePlugin(new onMessageCallback(Message->m_pConnection, std::vector<byte>(&sData[0], &sData[iPos])));
			if (sData[iPos + 1] == '\n') iPos++;				//  Handle \r\n
			sData = sData.substr(iPos + 1);
		m_sRetainedData.assign(sData.c_str(), sData.c_str() + sData.length()); // retain any residual for next time
      pPlugin->Log(LOG_ERROR, "(%s) exit", __func__);       //pm
The Yamaha plugin sends these commands to the receiver when started:
@MAIN:PWR=?
@MAIN:VOL=?
@MAIN:INP=?
@MAIN:MUTE=?
@MAIN:SOUNDPRG=?
@MAIN:STRAIGHT=?
and the modificed code gives this result:
2022-03-20 14:19:33.149  Error: AVR Yamaha: (ProcessInbound) entry
2022-03-20 14:19:33.149  Error: AVR Yamaha: (ProcessInbound) iPos  : 12
2022-03-20 14:19:33.149  Error: AVR Yamaha: (ProcessInbound) string: @MAIN:PWR=On
2022-03-20 14:19:33.149  Error: AVR Yamaha: (ProcessInbound) iPos  : -1
2022-03-20 14:19:33.149  Error: AVR Yamaha: (ProcessInbound) exit
2022-03-20 14:19:33.149  Error: AVR Yamaha: (ProcessInbound) iPos  : 15
2022-03-20 14:19:33.149  Error: AVR Yamaha: (ProcessInbound) string: @MAIN:VOL=-50.0
@MAIN:INP=TUNER
@MAIN:MUTE=Off
@MAIN:SOUNDPRG=2ch Stereo
@MAIN:STRAIGHT=Off
2022-03-20 14:19:33.149  Error: AVR Yamaha: (ProcessInbound) string: @MAIN:INP=TUNER
@MAIN:MUTE=Off
@MAIN:STRAIGHT=Off
2022-03-20 14:19:33.150  Error: AVR Yamaha: (ProcessInbound) iPos  : 14
2022-03-20 14:19:33.150  Error: AVR Yamaha: (ProcessInbound) string: @MAIN:MUTE=Off
@MAIN:STRAIGHT=Off
2022-03-20 14:19:33.150  Error: AVR Yamaha: (ProcessInbound) iPos  : 25
2022-03-20 14:19:33.150  Error: AVR Yamaha: (ProcessInbound) string: @MAIN:SOUNDPRG=2ch Stereo
@MAIN:STRAIGHT=Off
2022-03-20 14:19:33.150  Error: AVR Yamaha: (ProcessInbound) iPos  : 18
2022-03-20 14:19:33.150  Error: AVR Yamaha: (ProcessInbound) string: @MAIN:STRAIGHT=Off
2022-03-20 14:19:33.150  Error: AVR Yamaha: (ProcessInbound) iPos  : -1
2022-03-20 14:19:33.150  Error: AVR Yamaha: (ProcessInbound) exit
2022-03-20 14:19:33.150  Error: AVR Yamaha: Call to function 'onMessage' failed, exception details:
2022-03-20 14:19:33.162  Error: AVR Yamaha: Exception: 'SystemError'.  No traceback available.
2022-03-20 14:19:33.162  AVR Yamaha: (AVR Yamaha) Python exception set prior to callback 'onMessage'
2022-03-20 14:19:33.162  Error: AVR Yamaha: Call to function 'onMessage' failed, exception details:
2022-03-20 14:19:33.162  Error: AVR Yamaha: Exception: 'TypeError'.  No traceback available.
2022-03-20 14:19:33.163  Error: AVR Yamaha: Exception: 'TypeError'.  No traceback available.
2022-03-20 14:19:33.163  Error: AVR Yamaha: Call to function 'onMessage' failed, exception details:
2022-03-20 14:19:33.163  Error: AVR Yamaha: Exception: 'SystemError'.  No traceback available.
2022-03-20 14:19:33.163  AVR Yamaha: (AVR Yamaha) Python exception set prior to callback 'onMessage'
2022-03-20 14:19:37.234  Status: AVR Yamaha: Stop directive received.
regards
Peter
jzapater
Post by jzapater »
I have the same problem with Domoticz-Tuya-Thermostat-Plugin
Any solution ?
jzapater
Post by jzapater »
Thanks, @dnpwwo.
Resolved in your commit 0c099e19745c6440dd86446509516ce2947eb9a5
epierre
Post by epierre »
seems the Linky plugin has some issue also on 3.10, though through alternatives I am unable to force 3.8 as domoticz always use 3.10 and I don't know why (even with strace...)
ImperiHome & MyDomoAtHome on top of:
868.42Mhz - Vera Lite - Fibaro SS-101, S-211, K-101, FWP - Fortress SSA2
433Mhz - Cubie Domoticz + RFXtrx + Oregon || Foscam 9821W
2,4Ghz - Cubie MySensors Gateway + COV + TempHumidity + Pressure + WaterMeter
Barberousse
Post by Barberousse »
epierre wrote: Wednesday 24 August 2022 13:46 seems the Linky plugin has some issue also on 3.10, though through alternatives I am unable to force 3.8 as domoticz always use 3.10 and I don't know why (even with strace...)
To be more specific, there are troubles with the Configuration object, giving the message "Error: (JSONtoPython) failed to add item '-1', to list for string." for each Domoticz.Configuration(Config) call.
I will check if I'm able to reproduce on a very simple test plugin.
Domoticz V2022.1 (build 14479)
Python 3.10.4
Ubuntu 22.10
epierre
Post by epierre »
for me working since yesterday, updating toward the git !
