https://www.domoticz.com/wiki/ZwaveJS2M ... _OpenZwave
As soon as I disable the old OpenZwave hardware all the devices associated with it disappear and in the replace menu under the new device I only see UnknownIf you need to retain history of the old devices then you need to replace the old device with the new one if identical devices are created. Use the replace function in Edit device, see wiki https://www.domoticz.com/wiki/Managing_ ... ace_device Devices that were replaced will get the old name and old IDX, no need to change scripts.
So how do I know which to chose?
