how to start domoticz in raspberry
how to start domoticz if you type his ip adress and port in the navigator and domoticz do not start?
- EdwinK
- Domoticz version: BETA
Re: how to start domoticz in raspberry
Did you follow the instructions on https://www.domoticz.com/wiki/Raspberry ... l_Domoticz
Tukker
- Domoticz version: 2023.2
Having installed Domoticz as indicated by @EdwinK domoticz sometimes starts up without displaying the web page.
This doesn't have to be the case in your setup, but it's worth the try.
On my RaspberryPi install (after a boot up or a reboot) Domoticz seems to work but the web page isn't displayed.
On the monitor of your raspberry: <sudo service domoticz status> -> active (running)
When you do <sudo service domoticz restart>, everything will be fine.
You can automate this in crontab. <crontab -e>
Add this line to your crontab.
<#domoticz restart after 100 seconds>
<@reboot sleep 100 && sudo /etc/init.d/domoticz.sh restart>
Hope this helps you like it did on my setup.
Bugs bug me.
- Domoticz version: 2026.3
Make sure the time settings are correct. The time sync has to be finished before you start Domoticz.
Else Domoticz will stop.
jacobdvh
I have a very similar question. I did follow exactly the instructions to configure Rasperry and install Domoticz.
Domoticz starts OK.
Then loading several devices from the P1-USB hardware, also OK.
But then I don't see any of these devices on Dashboard nor on Utility. It used to come on immediately, but nothing now anymore.
Can anybody help me here? I think it has been a change in the Domoticz software, but cannot find it.
Thanks in advance.
Jacob
Domoticz starts OK.
Thanks in advance.
Jacob
