domoticz Version: 2022.1 is constantly blocked
Post your feedback and suggestions for the forum, website, wiki, Twitter-account, Facebook page and tracker (not the Domoticz project itself) here.
camilosti
Domoticz version: 2023.1
Post by camilosti »
Hi friends
My domoticz every day stops responding, scheduled lights do not turn on. The web server does not respond and the mobile APP cannot connect to the server.
Everything is back to normal if I connect via putty and run the following command: sudo /etc/init.d/domoticz.sh restart
After a few hours it crashes again.
I am running the latest stable version as of today.
Any suggestion to solve this problem?
Thank!!
Re: domoticz Version: 2022.1 is constantly blocked
It seems to crash then.
Are you on Bullseye operating system? Because that has an issue with python plugins.
Else see the troubleshooting wiki for actions to run: https://www.domoticz.com/wiki/Troubleshooting
gizmocuz
Post by gizmocuz »
Also try switching to the beta version
cd domoticz
./updatebeta
camilosti
Post by camilosti »
Thanks for your time friends.
Check and I'm on the Raspbian 10 version (buster)
How do I update?
Following these steps
https://www.youtube.com/watch?v=fZMhADtqfDU
camilosti
Post by camilosti »
Thanks friends for the recommendations.
I upgraded to Bullseye and after several days it hasn't crashed again.
I'm happy... thank you
camilosti
Post by camilosti »
Hi friends
After some time without problems I have seen that when I restart Domoticz it usually does not work, The web server does not respond and the mobile APP cannot connect to the server.
It doesn't even usually start Linux if I don't have the monitor, keyboard and mouse connected.
Any suggestions on where to look for a solution?
These are the data of my Domoticz
Version: 2024.2
Build Hash: 73d655383
Compile Date: 2024-01-15 12:48:07
dzVents Version: 3.1.8
Python Version: 3.7.3 (default, Oct 31 2022, 14:04:00) [GCC 8.3.0]
willemd
Post by willemd »
Using a raspberry? Did you configure "wait for network after reboot" using raspi-config? It should be off I think.
camilosti
Post by camilosti »
Yes, I'm using raspberry... I don't remember if I configured that... how can I check that?
HansieNL
Post by HansieNL »
Start a terminal session and type following command: sudo raspi-config
Then: Network at Boot - Select wait for network connection on boot
Blah blah blah
solarboy
Domoticz version: 2026.4
Post by solarboy »
Wait for network ? Which is it ? Off or On ?
Sjonnie2017
Domoticz version: Latest ß
Post by Sjonnie2017 »
On
YouLess Energy meter
