Tasmota to Domoticz via WQTT
nettworker
Post by nettworker »
Hello
i use a Sonoff Dual R3 with Tasmota. I try to connect it to a running Domoticz Installation via MQTT.
MQTT Server IP and Port is given. IDX of a Dummy switch in Domoticz also. But there is no Reaction in Domoticz ( no Messages in Log from this Device )
Is there any Example how to configure Tasmota?
Domoticz version: 2025.1
Re: Tasmota to Domoticz via WQTT
If you are not going to use rgb bulbs you should be able to use MQTT Autodiscover. In Tasmota you have to use setoption 19
Else use the Tasmota python plugin (without setoption 19) https://github.com/joba-1/Tasmoticz
jvdz
Domoticz version: 4.107
Post by jvdz »
nettworker wrote: Thursday 03 March 2022 8:15 Is there any Example how to configure Tasmota?
Just follow the documentation for Tasmota! ;) https://tasmota.github.io/docs/Domoticz/
