I paired 8 new Innr GU10 lamps with my Conbee II stick last week. Since yesterday I use 5 of them in combination with a couple of other lamps and sensors. At first the lamps seem to work okay but after some time part of the new lamps lose their connection with the Conbee with no clear reason. The only way to reconnect them is by switching the power of the lamp on and off. After less than an hour the first one already will disconnect again. I have 16 lamps and power plugs paired, but only 13 are connected to power. I also have 8 sensors (plus the virtual daylight sensor) and no switches paired to the Conbee II. Although I know this is probably not a Domoticz issue I hope someone can help me with this annoying problem.
Peter
Conbee II losing connection
Thorgal789
- Target OS: -
Re: Conbee II losing connection
Hello, yes I think too it s more a deconz issue.
You can use the forum https://forum.phoscon.de/ or the discord https://discord.gg/QFhTxqN
If the issue appeared suddently, can try to find a faulty device in logs, on deconz / help / debug view, use the 2 errors flag and the 2 info one to start.
Have you access to the GUI ? To see network picture ?
Have you check your deconz version and firmware version ?
It mean you turn off the power supply of them ? with a switch ? or you mean they are not connected at zigbee network ?but only 13 are connected to power
