Mobile home script modification not working
Fredom
Domoticz version: 2025.1
Post by Fredom »
Dear members,
The script below works perfectly.
But I want something extra and that is that when a mobile leaves home, a message goes to Telegram with the name and how many mobiles are still at home.
I've tried everything necessary but no good result yet.
I turned off the debug rules because these bits now work fine.
I have set the 6 lines in question to read because this gives error messages.
The 7 are the number of registered cell phones.
I hope this is possible in this script.
local phones =
    'Mobiel Fred',
    'Mobiel Hanny',
    'Mobiel Mariska',
    'Mobiel Barney',
    'Mobiel Nils',
    'Mobiel Test',
    'Mobiel Mandy',
    'Thuis',
return
    active = true,
            devices = phones
    logging =
         level = domoticz.LOG_DEBUG,
        marker = 'phones',
     execute = function(dz, item)
        local   home = dz.devices('Thuis')
        local atHome = home.active
        local function phonesActive()
            local activePhones = 0
            for _, phoneName in ipairs(phones) do
                if dz.devices(phoneName).active then
                    dz.log(phoneName .. ' active', dz.LOG_DEBUG)
                    activePhones = activePhones + 1
            if (dz.devices('Thuis').state == 'On') then
                activePhones = activePhones - 1
            return activePhones
        if item.active then
            if (dz.devices('Thuis').state == 'Off') then
                    dz.notify(item.name:gsub('Mobiel ', '') .. ' komt thuis. Er is nu ' .. phonesActive() .. ' mobiele telefoon binnen.', dz.PRIORITY_MEDIUM, dz.SOUND_PERSISTENT, nil, dz.NSS_TELEGRAM) --werkt goed
                    --dz.log(item.name:gsub('Mobiel ', '') .. ' komt thuis. Er is nu ' .. phonesActive() .. ' mobiele telefoons binnen.', dz.LOG_DEBUG)
                if phonesActive() > 1 then
                    dz.notify(item.name:gsub('Mobiel ', '') .. ' komt ook thuis. Er zijn nu ' .. phonesActive() .. ' mobiele telefoons binnen.', dz.PRIORITY_MEDIUM, dz.SOUND_PERSISTENT, nil, dz.NSS_TELEGRAM) --werkt goed
                    --dz.log(item.name:gsub('Mobiel ', '') .. ' komt ook thuis. Er zijn nu ' .. phonesActive() .. ' mobiele telefoons binnen.', dz.LOG_DEBUG)
                    home.switchOn().checkFirst().silent()
            --else
                --if phonesActive() < 7 then
                    --dz.notify(item.name:gsub('Mobiel ', '') .. ' vertrekt. Er zijn nu nog' .. phonesActive() .. ' mobiele telefoons binnen.', dz.PRIORITY_MEDIUM, dz.SOUND_PERSISTENT, nil, dz.NSS_TELEGRAM) --werkt nog niet goed
                    --dz.log(item.name:gsub('Mobiel ', '') .. ' vertrekt.Er zijn nu nog' .. phonesActive() .. ' mobiele telefoons binnen.' dz.LOG_DEBUG)
                --end
            --end
                if phonesActive() < 1 then
                --dz.log(item.name:gsub('Mobiel ', '') .. ' vertrekt. Er zijn nu geen mobiele telefoons meer binnen.', dz.LOG_DEBUG)
                dz.notify('Devices'.. item.name .. ' vertrekt. Er zijn nu geen mobiele telefoons meer binnen.', dz.PRIORITY_MEDIUM, dz.SOUND_PERSISTENT, nil, dz.NSS_TELEGRAM) --werkt goed
                home.switchOff().checkFirst().silent()
Thanks in advance
Fred
Yours sincerely,
Fred
Rasberry Pi 3B+ - Debian Trixie - Domoticz 2025.2
RFLink - RFXCom - Zigbee (CC2531)
P1 Smart Meter - KaKu
Re: Mobile home script modification not working
This is strange, the logging and notification works on entering house but the notification on leaving is not working. Is the logging on leaving really working?
Fredom
Post by Fredom »
waltervl wrote: Sunday 20 February 2022 20:49 This is strange, the logging and notification works on entering house but the notification on leaving is not working. Is the logging on leaving really working?
Thank you for your response.
This is the part that doesn't work.
The rest of the script works perfectly
          --else
                --end
            --end
Yours sincerely,
Fred
And what is not working, do you get errors?
Is there no log when activated?
Do you use elseif instead if else?
Fredom
Post by Fredom »
waltervl wrote: Sunday 20 February 2022 23:45 And what is not working, do you get errors?
Hi waltervl,
I solved the problem.
I forgot a comma in the log line and an end statement.
It works perfectly now.
Thanks for thinking along
Yours sincerely,
Fred
Fredom
Post by Fredom »
Hi Waltervl
Unfortunately, the script still doesn't quite work.
Can someone help me to get the last bit working.
The last part of the script where the dummy "Thuis" should be switched off,
and the message that the last mobile is leaving, doesn't work.
I also get messages in the log that I don't understand
2022-03-06 20:43:57.021 Error: dzVents: Error: (3.1.8) phones: There is no device with that name or id: true
2022-03-06 20:44:17.080 Error: dzVents: Error: (3.1.8) phones: There is no device with that name or id: true
2022-03-06 20:46:47.607 Error: dzVents: Error: (3.1.8) phones: There is no device with that name or id: true
2022-03-06 20:46:57.673 Error: dzVents: Error: (3.1.8) phones: There is no device with that name or id: true
2022-03-06 21:08:11.345 Error: dzVents: Error: (3.1.8) phones: There is no device with that name or id: true
2022-03-06 21:09:41.699 Error: dzVents: Error: (3.1.8) phones: There is no device with that name or id: true
2022-03-06 21:15:42.897 Error: dzVents: Error: (3.1.8) phones: There is no device with that name or id: false
2022-03-06 21:16:33.076 Error: dzVents: Error: (3.1.8) phones: There is no device with that name or id: true
2022-03-06 21:20:03.745 Error: dzVents: Error: (3.1.8) phones: There is no device with that name or id: true
2022-03-06 21:20:33.845 Error: dzVents: Error: (3.1.8) phones: There is no device with that name or id: true
The intent of this script should be.
Mobile comes in "Thuis" switch on.
Last mobile leaves "Thuis" switch Off.
And here the script as it is now
local phones =
    'Mobiel Fred',
    'Mobiel Hanny',
    'Mobiel Mariska',
    'Mobiel Barney',
    'Mobiel Nils',
    'Mobiel Test',
    'Mobiel Mandy',
return
    active = true,
            devices = phones
    logging =
        marker = 'phones',
            return activePhones
        if item.active then
            if not  dz.devices(atHome) then
                    home.switchOn().silent()   --werkt goed
                if phonesActive() > 0 then
                    home.switchOn().checkFirst().silent()   --werkt goed
                    dz.notify(item.name:gsub('Mobiel ', '') .. ' vertrekt. Er zijn nu ' .. phonesActive() .. ' mobiele telefoons binnen.', dz.PRIORITY_MEDIUM, dz.SOUND_PERSISTENT, nil, dz.NSS_TELEGRAM) --werkt goed
                    dz.log(item.name:gsub('Mobiel ', '') .. ' vertrekt.Er zijn nu ' .. phonesActive() .. ' mobiele telefoons binnen.', dz.LOG_DEBUG)
                if phonesActive() < 1 then   -- not workng
                    home.switchOff().checkFirst().silent()   --not working
                    dz.log(item.name:gsub('Mobiel ', '') .. ' vertrekt. Er zijn nu geen mobiele telefoons meer binnen.', dz.LOG_DEBUG)   --not working
                    dz.notify('Devices'.. item.name .. ' vertrekt. Er zijn nu geen mobiele telefoons meer binnen.', dz.PRIORITY_MEDIUM, dz.SOUND_PERSISTENT, nil, dz.NSS_TELEGRAM) --nt working
Yours sincerely,
Fred
It looks like somewhere in the script you mixed up a true/false check with a phone name check. Therefore the strange errors.
Put a log in the script that always shows the value of phonesActive(), that will make debugging easier.
boum
Domoticz version: 4.10717
Post by boum »
Line 47:
should be:
if not atHome then
Then your last test is never executed because your if/else/end blocks does not match. Bad indentation does not help.
It is currently:
When phonesActive() is less than 7, the else part is never executed, which is the case for < 1. You should invert the two tests or if you want both notifications move the second part out of the else block:
Fredom
Post by Fredom »
waltervl wrote: Sunday 06 March 2022 23:32 It looks like somewhere in the script you mixed up a true/false check with a phone name check. Therefore the strange errors.
Hi waltervl,
If I knew how to do that, I certainly would. I can make minor adjustments to an existing script and hope it works, unfortunately nothing more. But I am learning more and more.
I no longer have errors in the log file thanks to boum's tip.
"if not atHome then"
Yours sincerely,
Fred
Fredom
Post by Fredom »
boum wrote: Monday 07 March 2022 10:02 Line 47:
should be:
if not atHome then
It is currently:
Hi boum,
Thanks for your quick response.
I think I did what you suggested. The domoticz log file now has no errors.
But if a mobile comes in now, I get a message from Fred coming home. There is now 1 mobile phone inside.
and Fred leaves. There are now 1 cell phones inside. And when the mobile really leaves, there is no notification and "Home" does not switch off either
I'm not a programmer but I can make small adjustments in a script
local phones =
    'Mobiel Fred',
    'Mobiel Hanny',
    'Mobiel Mariska',
    'Mobiel Barney',
    'Mobiel Nils',
    'Mobiel Test',
    'Mobiel Mandy',
return
    active = true,
            devices = phones
    logging =
        marker = 'phones',
            return activePhones
        if item.active then
            if not  atHome then
                if phonesActive() < 4 then
Yours sincerely,
Fred
boum
Post by boum »
Like before, your chaining of if/then/else is faulty. You moved some things around and now there is no "else" clause for the "item.active" that's why "nobody is leaving"
local phones =
    'Mobiel Fred',
    'Mobiel Hanny',
    'Mobiel Mariska',
    'Mobiel Barney',
    'Mobiel Nils',
    'Mobiel Test',
    'Mobiel Mandy',
return
    active = true,
            devices = phones
    logging =
        marker = 'phones',
	-- don't need a function for that, it won't change during the invocation of the script
        if item.active then
            -- this is when a phone enters
            if activePhones==1 then
                    dz.notify(item.name:gsub('Mobiel ', '') .. ' komt thuis. Er is nu ' .. activePhones .. ' mobiele telefoon binnen.', dz.PRIORITY_MEDIUM, dz.SOUND_PERSISTENT, nil, dz.NSS_TELEGRAM) --werkt goed
                    dz.log(item.name:gsub('Mobiel ', '') .. ' komt thuis. Er is nu ' .. activePhones .. ' mobiele telefoons binnen.', dz.LOG_DEBUG)
                    dz.notify(item.name:gsub('Mobiel ', '') .. ' komt ook thuis. Er zijn nu ' .. activePhones .. ' mobiele telefoons binnen.', dz.PRIORITY_MEDIUM, dz.SOUND_PERSISTENT, nil, dz.NSS_TELEGRAM) --werkt goed
                    dz.log(item.name:gsub('Mobiel ', '') .. ' komt ook thuis. Er zijn nu ' .. activePhones .. ' mobiele telefoons binnen.', dz.LOG_DEBUG)
            -- this is when a phone leaves
            if activePhones > 0 then
                -- there is still somebody
                dz.notify(item.name:gsub('Mobiel ', '') .. ' vertrekt. Er zijn nu ' .. activePhones .. ' mobiele telefoons binnen.', dz.PRIORITY_MEDIUM, dz.SOUND_PERSISTENT, nil, dz.NSS_TELEGRAM) --werkt goed
                dz.log(item.name:gsub('Mobiel ', '') .. ' vertrekt.Er zijn nu ' .. activePhones .. ' mobiele telefoons binnen.', dz.LOG_DEBUG)
                -- everybody is gone
Make sure your code is in the correct scope.
Also, the script is executed once when a device change, so no need to compute the number of active phones many times, it won't change until the script is run another time because this or another trigger is hit.
Fredom
Post by Fredom »
boum wrote: Monday 07 March 2022 18:35 Like before, your chaining of if/then/else is faulty. You moved some things around and now there is no "else" clause for the "item.active" that's why "nobody is leaving"
local phones =
    'Mobiel Fred',
    'Mobiel Hanny',
    'Mobiel Mariska',
    'Mobiel Barney',
    'Mobiel Nils',
    'Mobiel Test',
    'Mobiel Mandy',
return
    active = true,
            devices = phones
    logging =
        marker = 'phones',
        if item.active then
Dear boum,
I hope to learn something from this.
Thanks a lot for your help
Yours sincerely,
Fred
