Error: Frient (Develco) SMSZB-120 en HESB-120
Posted: Monday 14 February 2022 20:39
I have two Frient HESZB-120 heat detectors installed (recognized and installed as Develco HESZB-120), both work within Domoticz and the plugin. However in the Domoticz log appears the repeating error messages
"2022-02-14 20:14:33.897 Error: Zigbee2MQTT: Brandmelder (keuken): can not process binary item "test"
2022-02-14 20:14:33.898 Error: Zigbee2MQTT: Brandmelder (keuken): can not process numeric item "max_duration"
2022-02-14 20:14:33.899 Error: Zigbee2MQTT: Brandmelder (keuken): can not process binary item "alarm"
2022-02-14 20:14:33.899 Error: Zigbee2MQTT: Brandmelder (keuken): can not process binary item "fault"
2022-02-14 20:14:34.006 Error: Zigbee2MQTT: Brandmelder (schuur): can not process binary item "test"
2022-02-14 20:14:34.006 Error: Zigbee2MQTT: Brandmelder (schuur): can not process numeric item "max_duration"
2022-02-14 20:14:34.007 Error: Zigbee2MQTT: Brandmelder (schuur): can not process binary item "alarm"
2022-02-14 20:14:34.007 Error: Zigbee2MQTT: Brandmelder (schuur): can not process binary item "fault"
2022-02-14 20:14:34.182 Error: Zigbee2MQTT: Brandmelder (huiskamer): can not process binary item "test"
2022-02-14 20:14:34.182 Error: Zigbee2MQTT: Brandmelder (huiskamer): can not process numeric item "max_duration"
2022-02-14 20:14:34.182 Error: Zigbee2MQTT: Brandmelder (huiskamer): can not process binary item "alarm"
2022-02-14 20:14:34.183 Error: Zigbee2MQTT: Brandmelder (huiskamer): can not process binary item "fault"
The detectors themselves work ok when I test them with a cigarette lighter or smoke (that's the only way to test and simulate a alarm signal in Domoticz because the test button doesn't
I hoped that the error messages will go away with the new recent updates, but not.
RaspberryPi 3b
Domoticz Version: 2022.1
Python Version: 3.7.3
Plugin Version 3.1.0.-beta
Zigbee2mqtt v.1.23.0 (zStack12 20190608)
Zigbee CC2531 coordinator USB-dongle
What could be the problem ?
Thanks in advance !
Regards, Theo (NL).
RaspberryPi 3b
Thanks in advance !
Regards, Theo (NL).
