Page 1 of 2
Dashticz 3.9 - master
Posted: Thursday 10 February 2022 20:44
by Lokonli
Today I've released the new Dashticz 3.9 master version.
It contains functionality earlier released as beta version between April 10th, 2021 (v3.8.0) and February 10, 2022 (v3.8.11)
An overview of some highlights:
- New weather blocks
- weather.jpg (35.43 KiB) Viewed 4098 times
- Improved public transport block
- irailbebrussel.jpg (21.01 KiB) Viewed 4098 times
- Several graph related improvements, including support for displaying switch status
- Dial support added for blinds
- dialblinds.jpg (14.49 KiB) Viewed 4098 times
- Scaling of frame content
- Improved auto slide behavior
and several other smaller improvements and bugfixes.
A description of all changes can be found here:
https://dashticz.readthedocs.io/en/mast ... index.html
Upgrading
It's recommended to make a backup of your Dashticz folder first!
If you already running the master branch you can upgrade with the following command in the Dashticz folder:
If you are running the beta branch and you want to switch to master, then use the following commands:
In case you are upgrading from version 3.7.x or earlier and you used the automatic install, then I recommend to update the Dashticz Docker container as well by running the following commands after the upgrade:
I don't expect you'll encounter breaking changes when updating, however you may have to change some styling in custom.css for:
- Dial ring coloring and font size
- Public transport block
- Calendar event styling
- Weather block
The Dashticz documentation contains styling examples.
Re: Dashticz 3.9 - master
Posted: Thursday 10 February 2022 23:48
by heggink
Nice work! Many thanks.
Sent from my SM-G980F using Tapatalk
Posted: Friday 11 February 2022 8:07
by Doudy
Posted: Friday 11 February 2022 15:44
by Jimster
The amount of work you put in Dashticz is incredible. Thanks Lokonli!
Posted: Friday 11 February 2022 18:47
by HenriM
I always had next settings for Nefit Easy and this shows nice 'dial' with correct value for my Nefit Easy (theromostat) device:
// Nefit Setpoint
blocks[nefit_easy] = {}
blocks[nefit_easy]['width'] = 3;
blocks[nefit_easy]['show_lastupdate'] = false;
blocks[nefit_easy]['type'] = 'dial';
blocks[nefit_easy]['showunit'] = true;
blocks[nefit_easy]['lastupdate'] = true;
blocks[nefit_easy]['flash'] = true;
However after this 3.9 update the dial for Nefit Easy shows wrong value.
When I remove 'dial' from above block the correct value is shown.
Posted: Friday 11 February 2022 19:56
by Lokonli
HenriM wrote: Friday 11 February 2022 18:47
// Nefit Setpoint
Can you post the Domoticz json output of the Nefit device:
http://domoticz ip:port/json.htm?type=devices&rid=123
Replace 123 with the DOmoticz device id of your Nefit device.
Posted: Friday 11 February 2022 23:47
by HenriM
The JSON output of my Nefit device is:
ActTime 1644619552
AstrTwilightEnd "19:41"
AstrTwilightStart "06:09"
CivTwilightEnd "18:23"
CivTwilightStart "07:27"
DayLength "09:46"
NautTwilightEnd "19:03"
NautTwilightStart "06:48"
ServerTime "2022-02-11 23:45:52"
SunAtSouth "12:55"
Sunrise "08:02"
Sunset "17:49"
app_version "2022.1 (build 14166)"
result
0
AddjMulti 1
AddjMulti2 1
AddjValue 0
AddjValue2 0
BatteryLevel 255
CustomImage 0
Data "15.0"
Description ""
Favorite 1
HardwareDisabled false
HardwareID 7
HardwareName "Nefit Easy"
HardwareType "Nefit Easy HTTP server over LAN interface"
HardwareTypeVal 68
HaveTimeout false
ID "0010101"
LastUpdate "2022-02-11 23:45:34"
Name "Nefit Setpoint"
Notifications "false"
PlanID "2"
PlanIDs
0 2
1 16
Protected false
SetPoint "15.0"
ShowNotifications true
SignalLevel "-"
SubType "SetPoint"
Timers "false"
Type "Thermostat"
TypeImg "override_mini"
Unit 1
Used 1
XOffset "1904"
YOffset "1849"
idx "77"
status "OK"
title "Devices"
Posted: Saturday 12 February 2022 8:02
by sailmich
Again great work, I'm happy, blinds are supported. I have percentage blinds. With the dials I just can open or close them. No way to set them somewhere in between. How can I solve that.
Have a nice day
Posted: Saturday 12 February 2022 8:20
by heggink
I have the same for both blinds and curtains. For each, I made a virtual device that triggers a script that sets the right percentage. Much easier than trying to slide by hand for me...
Posted: Saturday 12 February 2022 9:37
by Lokonli
sailmich wrote: Saturday 12 February 2022 8:02
Have a nice day
Could you create a new topic for this? I'll answer there.
Posted: Saturday 12 February 2022 9:44
by Lokonli
HenriM wrote: Friday 11 February 2022 23:47
ActTime 1644619552
DayLength "09:46"
SunAtSouth "12:55"
Sunrise "08:02"
Sunset "17:49"
result
0
AddjMulti 1
AddjMulti2 1
AddjValue 0
AddjValue2 0
BatteryLevel 255
CustomImage 0
Data "15.0"
Description ""
Favorite 1
HardwareID 7
HardwareTypeVal 68
HaveTimeout false
ID "0010101"
PlanID "2"
PlanIDs
0 2
1 16
Protected false
SetPoint "15.0"
SignalLevel "-"
SubType "SetPoint"
Timers "false"
Type "Thermostat"
Unit 1
Used 1
XOffset "1904"
YOffset "1849"
idx "77"
status "OK"
title "Devices"
It is a Type: Thermostat and SubType: SetPoint. That should work, at least it works on my system.
Do you see a dial or a basic square block or something else ? (with dial type)
Which value is shown?
How did you define nefit_easy in CONFIG.js?
If you open DevTools in Chrome (Press F12), refresh Dashticz, and look into the console tab: which errors do you see?
Posted: Saturday 12 February 2022 10:35
by HenriM
var nefit_easy = 77;
// Nefit Setpoint
This is what my IOS app shows
https://eye-vision.homeip.net/wp-conten ... G_0593.PNG
This is what is shown in Dashticz with: blocks[nefit_easy]['type'] = 'dial';
https://eye-vision.homeip.net/wp-conten ... t_Easy.jpg
This is what is shown in Dashticz when I comment out: //blocks[nefit_easy]['type'] = 'dial';
ActTime 1644658235
AstrTwilightEnd "19:43"
AstrTwilightStart "06:08"
CivTwilightEnd "18:25"
CivTwilightStart "07:26"
DayLength "09:50"
NautTwilightEnd "19:04"
NautTwilightStart "06:46"
ServerTime "2022-02-12 10:30:35"
SunAtSouth "12:55"
Sunrise "08:00"
Sunset "17:50"
result
0
AddjMulti 1
AddjMulti2 1
AddjValue 0
AddjValue2 0
BatteryLevel 255
CustomImage 0
Data "18.5"
Description ""
Favorite 1
HardwareID 7
HardwareTypeVal 68
HaveTimeout false
ID "0010101"
LastUpdate "2022-02-12 10:30:19"
PlanID "2"
PlanIDs
0 2
1 16
Protected false
SetPoint "18.5"
SignalLevel "-"
SubType "SetPoint"
Timers "false"
Type "Thermostat"
Unit 1
Used 1
XOffset "1904"
YOffset "1849"
idx "77"
status "OK"
title "Devices"
In Console of Firefox I see next error of interest
With previous version of Dashticz (with same CONFIG.js) it works correctly.
The P1 SmartMeter shows dial correctly.
Posted: Saturday 12 February 2022 11:36
by madpatrick
I noticing problem with 1 page on my Dashticz since the recent update.
I've a frame for my LMS page, but it is not responding on the tablet any more.
I hear the click when i touch the tablet, but nothing is happening.
Opening the page on a normal browser works without problems
This my config
buttons.slidehome = {
key: "Home",
width: 12,
title:"Home Screen",
slide:1,
icon: 'fas fa-home'}
frames.slide4 = {frameurl:"http://192.168.1.1:9000/", height: '540',scrollbars : false, width:12}
columns['slide4_1'] = {blocks: [frames.slide4,buttons.slidehome], width: 12}
Posted: Saturday 12 February 2022 13:35
by madpatrick
Reply to my previous post.
It looks the problems is on every even page, page 2 & 4
If i make page 5 & 6 with the same slide, page 5 is working and 6 not
------------- UPDATE ----------
The parameter Slide_effect was the problem.
Don't know why, because i've this not changed for months
slide effect 'Cube' is the problem
Changed this to 'Slide' and everything is working again
Posted: Saturday 12 February 2022 15:35
by sailmich
Lokonli wrote: Saturday 12 February 2022 9:37
Have a nice day
Did it.
posting.php?mode=reply&t=38017#preview
Posted: Saturday 12 February 2022 17:17
by Lokonli
HenriM wrote: Saturday 12 February 2022 10:35
// Nefit Setpoint
ActTime 1644658235
DayLength "09:50"
SunAtSouth "12:55"
Sunrise "08:00"
Sunset "17:50"
result
0
AddjMulti 1
AddjMulti2 1
AddjValue 0
AddjValue2 0
BatteryLevel 255
CustomImage 0
Data "18.5"
Description ""
Favorite 1
HardwareID 7
HardwareTypeVal 68
HaveTimeout false
ID "0010101"
PlanID "2"
PlanIDs
0 2
1 16
Protected false
SetPoint "18.5"
SignalLevel "-"
SubType "SetPoint"
Timers "false"
Type "Thermostat"
Unit 1
Used 1
XOffset "1904"
YOffset "1849"
idx "77"
status "OK"
title "Devices"
On what kind of system/OS do you use Firefox?
The XML error is a bit strange. I don't see it on my system.
Could you create a dummy Thermostat device and dummy Temperature device in Domoticz and check whether they are displayed correctly in Dashticz? (as dial)
Can you also open the url you showed (
http://user:[email protected]:84/tpl/dial.tpl?22) in a separate browser window, and post the output here?
Posted: Sunday 13 February 2022 8:23
by HenriM
I use Firefox on Windows 11, but the same happens on MacBook Air with Monterey 12.1.
This is the output of
{{#*inline "dialitems"}}
<div class="extra {{animation}} {{#unless showvalue}}novalue{{/unless}}">
{{#each info}}
<div class="item {{this.addClass}} {{this.deviceStatus}}">
{{#if this.label}}
<div class="itemlabel">{{this.label}}</div>
{{/if}}
<div class="dataunit">
{{#unless this.image}}
<i class="{{this.icon}}"></i>
{{else}}
<img src="img/{{this.image}}">
{{/unless}}
<span class="data">{{this.data}}</span>
<span class="unit">{{this.unit}}</span>
</div>
</div>
{{/each}}
</div>
{{#if lastupdate}}
<span class="info {{#unless hasSetpoint}}nosetpoint{{/unless}} {{animation}}">{{lastupdate}}</span>
{{/if}}
{{/inline}}
{{#*inline "dialdevice"}}
<span class="device {{animation}}" style="color:{{color}};">{{name}}</span>
{{/inline}}
<div class="dial {{size}} {{#if fixed}}fixed{{/if}} {{active}} {{addclass}} {{deviceStatus}}" style="font-size: {{fontsize}}px;--dial-color: {{rgba}};">
<div class="slice {{#if split}}{{slice}}{{/if}} primary {{class}}">
<div class="bar"></div>
<div class="fill"></div>
</div>
<div class="dial-container">
<div id="face{{id}}" class="dial-face">
<div class="dial-numbers">
{{#if numbers}}
{{#each numbers as |number|}}
<span class="number seg_{{../range}}_{{../numbers.length}}_{{@index}}">{{number}}</span>
{{/each}}
{{/if}}
</div>
</div>
{{#unless fixed}}
<div class="draggable">
<div class="dial-needle" style="--dial-color: {{color}};--needle-length: {{needleL}}px;--needle-width: {{needleW}}px;"></div>
</div>
{{/unless}}
<div id="{{id}}" class="dial-center {{on}}" style="--dial-rgba: {{rgba}};{{#if onoff}}background: transparent; box-shadow: none;{{/if}}">
{{#if controller}}
<div class="dial-menu {{#if name}}hastitle{{/if}}">
<ul class="status" style="--dial-color: {{color}};">
{{#each options as |opt|}}
<li class="text" data-val="{{opt.val}}">{{opt.text}}</li>
{{/each}}
</ul>
</div>
{{#if name}}
<div class="dial-menu-title-background"></div>
<div class="dial-menu-title" style="--dial-color: {{color}};">
{{name}}
</div>
{{/if}}
{{else if onoff}}
<div class="dial-switch">
<input type="checkbox" {{checked}}>
<div class="switch-face">
{{> dialdevice}}
{{#if showvalue}}
<i class="{{iconSwitch}} icon-off"></i>
{{/if}}
{{> dialitems}}
</div>
</div>
{{else}}
<div class="dial-display">
{{> dialdevice}}
{{#if showvalue}}
<div class="value-unit">
<span class="value" style="--dial-color: {{color}};">{{valueformat}}</span>
{{#if showunit}}
<span class="unit" style="--dial-color: {{color}};">{{unitvalue}}</span>
{{/if}}
</div>
{{/if}}
{{> dialitems}}
</div>
{{/if}}
</div>
</div>
</div>
I hope I will be able to provide results of dummy thermostat later this day.
Posted: Sunday 13 February 2022 8:39
by HenriM
Later this day is very soon
My Temperature sensors (using Xiaomi) are showing correctly as Dial:
https://eye-vision.homeip.net/wp-conten ... ratuur.jpg
I have then created dummy Thermostat/Setpoint device in Domoticz:
https://eye-vision.homeip.net/wp-conten ... mostat.jpg
This also displays incorrectly in Dashticz (would expect value 20.5 (see above)):
Seems something going wrong with Thermostat/Setpoint dial type with my system. I am using latest beta of Domoticz (2022.1 (build 14182). Domoticz runs on separate Raspberry Pi. I use Dashticz on my Debian Server (10 - Buster). I checked on Windows 11 and MacBook with Firefox and they both show it incorrectly.
In total I have 10 dial-types. Is it possible that something goes wrong in Dashticz regarding 'look-up' of the device?
Posted: Sunday 13 February 2022 19:58
by TroisSix
Hi Lokonli,
Thank you so much for all your work on Dashticz, it's vital for ma children and I (not waf enough for my wife, it will never be lol)
For information, I was on beta for several months and always up to date, and I just did an update of the bera today.
Since then, Dahsticz cannot be displayed on my iPad, did you changed anything vital bteween last beta -1 and the actual beta from today?
So I just changed to the master version, and all is working fine, I don't touch anything from now
Perhaps something important changed between last beta version -1 and last beta version?
I can do some tests if you want till you don't change the master
Posted: Sunday 13 February 2022 21:57
by Lokonli
I made some changes to the development environment for the beta version. I'll do some more tests on iPad.
