Trigger on different text values
Vomera
Post by Vomera »
Hi All,
I saw Meteoalarm didnt work anymore. So i got a new script that i found on this https://www.domoticz.com/forum/viewtopic.php?t=37919 (thank you for that)
With Meteoalarm i always trigger on text value. For example meteoalarm gives me Wind(3) or Wind(2) (Every time the same text value's), i show a warning on my dashboard with yellow block with wind symbol. (cant show an example because its down already) All text value's coded into the custum.js
Now i want to do that for the KNMI warning messages, but what i see is that the text value's are not the same and changing all the time.
Ofcourse if i use "Zware windstoten tot ongeveer 90 km/uur." it works :
	else if (device['Data']=="Zware windstoten tot ongeveer 90 km/uur."){
	block.addClass='warningyellow'
	block.icon = 'fas fa-wind'
	block.title = 'Wind'
Now i was thinking to trigger just on some words, for example Zware windstoten. But the == statement is not usable here
	else if (device['Data']=="Zware windstoten"){
I was thinking of using wildcards or maybe there is a statement with " else if device data contains" instead to collect all the data and put it in the custom.js. I will be a long list then.
Has anyone some advice?
Lokonli
Re: Trigger on different text values
Post by Lokonli »
You can use the JavaScript search method and a regular expression.
See https://www.google.com/url?sa=t&source= ... Um3DzpV2Ku
Verstuurd vanaf mijn AC2003 met Tapatalk
Vomera
Post by Vomera »
Here is example that works:
function getStatus_14146(block){
   var idx = block.idx;
   var device = block.device;
   var tekst = device['Data'];
   if(device['Data']=="No Data"){
	block.addClass='none'
	block.icon = 'far fa-thumbs-up'
	// geen actie
	else if (tekst.includes('geen waarschuwingen')){
	block.title = 'Geen Melding'
	// zware windstoten
	else if (tekst.includes('Kans op zware windstoten')){
ps. need some editing of the position of the block
Vomera
Post by Vomera »
Okay with loading the dashboard i need to use the code
But if there will be a new update, it doesnt change.
So i figure out that you also need to use the
function getChange_14146(block)
It means i have to copy for getStatus as also for the getChange. If i have 100 lines of code for the weather alarm, means i have 100 lines of the same code for getStatus and getChange.
Is there a way to combine it ?
For example, function getChange_14146(block), function getStatus_14146(block) {...}
// https://cdn.knmi.nl/knmi/xml/rss/rss_KNMIwaarschuwingen.xml
//  STATUS
	// geen actie
	// zware windstoten
	else if (tekst.includes('op zware windstoten')){
	// op zeer zware windstoten
	else if (tekst.includes('op zeer zware windstoten')){
	block.addClass='warningorange'
// einde status
Lokonli
Post by Lokonli »
You could achieve it by creating one common function as follows:
function updateKNMI(block) {
	// geen actie
	// zware windstoten
function getChange_14146(block) {
  updateKNMI(block);
  updateKNMI(block);
// einde status
But the getStatus function should be called always, and the getChange function on any change, so it's a surprising that it doesn't work like that. I'll do some tests.
Vomera
Post by Vomera »
I test it too, thats an other way to implement it. i was already looking to combine 2 function names
edit: test it, and it works
