Variable only changes once
blackeagle
Post by blackeagle »
Hi All,
I have created a blockly where if one of us is at home after sunset, the living room lights turn on.
Also added a variable to be able to turn off the light.
When I start the variable with OFF, it does switch to ON.
But when the mobile phones disconnect (simulating leaving home) it does not go to the OFF state.
Am I missing something in the blocks?
madpatrick
Domoticz version: 2025.2
Re: Variable only changes once
Post by madpatrick »
Try remove the "iemand_thuis" = On on the ElseIf line
Basicly it doesn't matter which status this is having
blackeagle
The same result, when putting the variable manually to OFF, it switches once, then not anymore.
BennY
Post by BennY »
try it with the Green Label instead of the state On/Off.
At Logic, the Last Label with "()".
Benny
