Script Dzvents to read values from webpage [Solved]
javalin
Domoticz version: 4.10717
Post by javalin »
Dear all,
I would like to get somes values from a weather station website and store these data into Domoticz.
The API request is :
http://centronautico.cm-faro.pt/report.php
Lines 65 and 66 from html reponse are Wind Speed and Wind Gust:
<td class="ws3">3</td>
<td class="ws3">5</td>
Line 68 is Wind Direction:
<img src="images/wd_SE.gif" alt="SE" /></td>
This is my code lines but, how I could read the html reponse to dump in dzvents?
local scriptVar = 'getWidInfo'
return
    on =
        timer =
            'every minute',
        httpResponses =
            scriptVar,
    logging =
        level = domoticz.LOG_DEBUG,
        marker = scriptVar,
    execute = function(dz, item)
        if item.isTimer or item.isDevice then
            dz.openURL(
                url = "http://centronautico.cm-faro.pt/report1.php",
                method = 'GET',
                callback = scriptVar,
    elseif item.ok then -- statusCode == 2xx
Thank you in advance.
Domoticz version: 2025.1
Re: Script Dzvents to read values from webpage
I think the following topic should give you some hints. But I personally lack the knowledge. viewtopic.php?t=25321
javalin
Post by javalin »
Thank you waltervl, I had tried to make the script with LUA following that post before create this one. I am not able to run socket.http after installed.
Here is another scripts that goes through html data.
DzVents is build on Lua so native Lua functions will also work in DzVents..
https://domoticz.com/forum/viewtopic.ph ... 54#p223354
javalin
Post by javalin »
I have got to adapt the waaren script to extract the data from the weather station that I want. Thank you very much waltervl for your help and to waaren, wherever you are, a big hug.
