Page 1 of 2
Weather alarm from Royal Netherlands Meteorological Institute (KNMI)
Posted: Monday 31 January 2022 15:31
by FireWizard
Hello All,
As the previous used weather alarm website http://www.meteoalarm.eu moved to a new European weather alarm site http://www.meteoalarm.org, also the RSS and ATOM feeds used by the python script, provided by @ycahome and all other solutions based on the old website, stopped working.
See: viewtopic.php?t=19519&start=100
As I used previously Node RED to parse the data and send it by MQTT to Domoticz, I created a new flow to do the same with the KNMI Website.
As the European website gets its data from the National Meteorological Bodies, I decided not to use the EU feeds, but the feed presented by KNMI.
So this post is only useful for those living in The Netherlands or those, who are interested in Dutch Weather alarms.
The Dutch website with the map can be visited at https://www.knmi.nl/nederland-nu/weer/w ... en/utrecht.
Insert your province, as Utrecht is the default,
The flow is presented in the picture below:
Some explanation of the working.
At the far left you will see an "Inject"node, which provides a 10 minute "tick". So the data to Domoticz is updated every 10 minutes.
It requests the data from the KNMI webfeed at https://cdn.knmi.nl/knmi/xml/rss/rss_KN ... wingen.xml
As this is XML data, it is sent through a XML node in order to convert it from a XML string to its JavaScript object representation.
This is used as input in a "Function" node. The Function takes care of the conversion to the Domoticz format.
The contents is as follows:
var i;
var desc;
var mod_desc;
var al_txt;
var no_al_txt;
for (i = 0; i < msg.payload.rss.channel[0].item.length; i++) {
    if (msg.payload.rss.channel[0].item[i].title[0] === "Waarschuwingen Gelderland") {
        desc = msg.payload.rss.channel[0].item[i].description[0];
        mod_desc = desc.replace(/(<([^>]+)>)/ig, '.'); // Modified description without HTML tags. Tags replaced by . (dot)
        no_al_txt = mod_desc.substring((mod_desc.indexOf(".") + 2), (mod_desc.indexOf(".", (mod_desc.indexOf(".") + 1)) + 1));
        al_txt = mod_desc.substring((mod_desc.indexOf("..") + 2), (mod_desc.indexOf("..", (mod_desc.indexOf("..") + 1)) + 1));
switch (desc.substring(5,desc.indexOf("."))) {
    case "Groen":
        msg.payload = { "command": "udevice", "idx": 395, "nvalue": 1, "svalue": no_al_txt };
        break;
   case "Geel" :
        msg.payload = { "command": "udevice", "idx": 395, "nvalue": 2, "svalue": al_txt };
        break;
    case "Oranje":
        msg.payload = { "command": "udevice", "idx": 395, "nvalue": 3, "svalue": al_txt };
        break;
    case "Rood":
        msg.payload = { "command": "udevice", "idx": 395, "nvalue": 4, "svalue": al_txt };
        break;
    default:
        msg.payload = { "command": "udevice", "idx": 395, "nvalue": 0, "svalue": "No Data available" };
        break;
return msg
The first lines are some variable declarations. Then we will see a "for" loop.
The user has to change line 7 and insert his/her own desired area (either a province or a coastal area).
It is followed by a "switch case" statement. The user has to replace the number after "idx" for his/her own IDX number of the Domoticz virtual "Alert" sensor.
Remark!
It has been tested with code green, code yellow and code orange.
However I did not see any code red, so we will have to wait in order to test.
If everything is finished you will see:
And hopefully very soon:
The complete flow, you will find below:
[{"id":"6c6dcd5fb912ade7","type":"http request","z":"2275566b.451742","name":"","method":"GET","ret":"txt","paytoqs":"ignore","url":"https://cdn.knmi.nl/knmi/xml/rss/rss_KNMIwaarschuwingen.xml","tls":"","persist":false,"proxy":"","authType":"","senderr":false,"x":350,"y":460,"wires":[["74b6e54b66b937f2"]]},{"id":"206e54fce96bfcf8","type":"inject","z":"2275566b.451742","name":"10 Minute tick","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"600","crontab":"","once":true,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":140,"y":460,"wires":[["6c6dcd5fb912ade7"]]},{"id":"74b6e54b66b937f2","type":"xml","z":"2275566b.451742","name":"","property":"payload","attr":"","chr":"","x":530,"y":460,"wires":[["f1c7fef468771b6a"]]},{"id":"f1c7fef468771b6a","type":"function","z":"2275566b.451742","name":"Function","func":"var i;\nvar desc;\nvar mod_desc;\nvar al_txt;\nvar no_al_txt;\nfor (i = 0; i < msg.payload.rss.channel[0].item.length; i++) {\n    if (msg.payload.rss.channel[0].item[i].title[0] === \"Waarschuwingen Gelderland\") {\n        desc = msg.payload.rss.channel[0].item[i].description[0];\n        mod_desc = desc.replace(/(<([^>]+)>)/ig, '.'); // Modified description without HTML tags. Tags replaced by . (dot)\n        no_al_txt = mod_desc.substring((mod_desc.indexOf(\".\") + 2), (mod_desc.indexOf(\".\", (mod_desc.indexOf(\".\") + 1)) + 1));\n        al_txt = mod_desc.substring((mod_desc.indexOf(\"..\") + 2), (mod_desc.indexOf(\"..\", (mod_desc.indexOf(\"..\") + 1)) + 1));\n    }\n}\nswitch (desc.substring(5,desc.indexOf(\".\"))) {\n    case \"Groen\":\n        msg.payload = { \"command\": \"udevice\", \"idx\": 395, \"nvalue\": 1, \"svalue\": no_al_txt };\n        break;\n\n   case \"Geel\" :\n        msg.payload = { \"command\": \"udevice\", \"idx\": 395, \"nvalue\": 2, \"svalue\": al_txt };\n        break;\n\n    case \"Oranje\":\n        msg.payload = { \"command\": \"udevice\", \"idx\": 395, \"nvalue\": 3, \"svalue\": al_txt };\n        break;\n\n    case \"Rood\":\n        msg.payload = { \"command\": \"udevice\", \"idx\": 395, \"nvalue\": 4, \"svalue\": al_txt };\n        break;\n\n    default:\n        msg.payload = { \"command\": \"udevice\", \"idx\": 395, \"nvalue\": 0, \"svalue\": \"No Data available\" };\n        break;\n}\nreturn msg","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":700,"y":460,"wires":[["5b307902260f6b0a"]]},{"id":"5b307902260f6b0a","type":"mqtt out","z":"2275566b.451742","name":"Domoticz In","topic":"domoticz/in","qos":"","retain":"","respTopic":"","contentType":"","userProps":"","correl":"","expiry":"","broker":"2d06e6e96ce54335","x":890,"y":460,"wires":[]},{"id":"cae751d6c4047878","type":"comment","z":"2275566b.451742","name":"Meteoalarm KNMI","info":"","x":570,"y":400,"wires":[]},{"id":"2d06e6e96ce54335","type":"mqtt-broker","name":"Jonas_MQTT_Server","broker":"192.168.10.24","port":"1883","clientid":"","autoConnect":true,"usetls":false,"protocolVersion":"4","keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","birthMsg":{},"closeTopic":"","closeQos":"0","closePayload":"","closeMsg":{},"willTopic":"","willQos":"0","willPayload":"","willMsg":{},"sessionExpiry":""}]
Re: Weather alarm from Royal Netherlands Meteorological Institute (KNMI)
Posted: Monday 31 January 2022 17:46
by EdwinK
Thanks again. If I have everything up again, I'll try this
Posted: Tuesday 01 February 2022 23:39
by andreo
Thanks,
Successfully implemented the weather alarm, it works great. Now just waiting for the next storm, looking forward to it.
Posted: Friday 04 February 2022 16:18
by Vomera
Tnx for this! It's the first time i use node red. Didnt know i had it install it (but i use mqtt).
After some trying and figuring out how it works, i get the script working :D
Now indeed see which results it will give, because i want to use the value's with dashticz to give warning weather icons :D
Too bad meteoalarm is down.
Posted: Monday 21 February 2022 12:10
by EdwinK
In the 'debug' log I can see some changes, but the alert button doesn't change. I guess I have done something wrong with the MQTT settings, but can't figure out what/
Never mind. I was using the wrong MQTT plugin. Now the alert icon is changing.
Posted: Monday 21 February 2022 15:19
by FireWizard
@EdwinK,
So this issue is solved and the alert has been cleared?
Posted: Monday 21 February 2022 22:48
by EdwinK
Yes, I do receive alerts atm. :)
I like how the flow is working.
Posted: Tuesday 22 February 2022 19:51
by Jan Jansen
@FireWizard,
Thanks again for this nice addition!
Jan
Posted: Saturday 02 April 2022 9:29
by roelv
Hi FireWizard,
Thx for this nice application. I altered the last part of it, so it now delivers the Weatheralert status to my Pushover app instead of Domoticz. So I'm always notified of important weatherchanges on my cell phone. For this I changed the function node a bit (could still be improved though), added a filter and a Pushover node.
Pushover is very reliable and has lots of delivery and attention options and you pay only once for using it (about € 5). Instead you could also use a Telegram node via a (free) Telegram account.
Below: altered Function node
        "id": "f1c7fef468771b6a",
        "type": "function",
        "z": "953341bb9f649d8c",
        "name": "Function",
        "func": "var i;\nvar desc;\nvar mod_desc;\nvar al_txt;\nvar no_al_txt;\nfor (i = 0; i < msg.payload.rss.channel[0].item.length; i++) {\n    if (msg.payload.rss.channel[0].item[i].title[0] === \"Waarschuwingen Noord-Holland\") {\n        desc = msg.payload.rss.channel[0].item[i].description[0];\n        mod_desc = desc.replace(/(<([^>]+)>)/ig, '.'); // Modified description without HTML tags. Tags replaced by . (dot)\n        no_al_txt = mod_desc.substring((mod_desc.indexOf(\".\") + 2), (mod_desc.indexOf(\".\", (mod_desc.indexOf(\".\") + 1)) + 1));\n        al_txt = mod_desc.substring((mod_desc.indexOf(\"..\") + 2), (mod_desc.indexOf(\"..\", (mod_desc.indexOf(\"..\") + 1)) + 1));\n    }\n}\nswitch (desc.substring(5,desc.indexOf(\".\"))) {\n    case \"Groen\":\n        msg.payload = { \"Weercode Groen\": no_al_txt };\n        break;\n\n   case \"Geel\" :\n        msg.payload = { \"Weercode Geel\": al_txt };\n        break;\n\n    case \"Oranje\":\n        msg.payload = { \"Weercode Oranje\": al_txt };\n        break;\n\n    case \"Rood\":\n        msg.payload = { \"Weercode Rood\": al_txt };\n        break;\n\n    default:\n        msg.payload = { \"Geen gegevens\": no_al_txt };\n        break;\n}\nreturn msg",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 380,
        "y": 300,
        "wires": [
                "86127bc90d5bec32"
Below: added Filter node
        "id": "86127bc90d5bec32",
        "type": "rbe",
        "name": "",
        "func": "rbe",
        "gap": "",
        "start": "",
        "inout": "out",
        "septopics": true,
        "property": "payload",
        "topi": "topic",
        "x": 590,
        "y": 300,
        "wires": [
                "92459ad472b1531c",
                "4c85e09a56b801ce"
Below: Added Pushover node
        "id": "92459ad472b1531c",
        "type": "pushover",
        "name": "",
        "device": "",
        "title": "Weercode NH 1",
        "priority": "1",
        "sound": "bike",
        "url": "",
        "url_title": "",
        "html": false,
        "credentials": {},
        "x": 880,
        "y": 260,
        "wires": []
Posted: Saturday 02 April 2022 14:47
by FireWizard
Hi @roelv,
Thanks for sharing your application.
Perhaps it will inspire members of the Domoticz community.
Posted: Tuesday 01 August 2023 14:46
by Hansh
hello fire wizard
Your script runs in blocks.
I'm a bigger fan of dzvents for a variety of reasons.
The script you made inspired me to achieve the same result in dzvents.
I've created a new topic to avoid confusion
"KNMI weather alert with dzvents"
Of course I mentioned you as the source
regards
Hansh
Posted: Tuesday 01 August 2023 18:11
by FireWizard
Hello @Hansh,
No problem. It is nice that my web scraping in Node-RED inspired you to make something in dZVents.
Posted: Monday 13 November 2023 14:46
by FireWizard
To all users of the KNMI weather alarm application.
Since approx. 2 weeks I noted that the weather application is not updating its data anymore. This will not be visible for everybody, as it depends on the latest received data. So I looked for the reason and an alternative solution.
The application pulls its data from https://cdn.knmi.nl/knmi/xml/rss/rss_KN ... wingen.xml.
As this URL is still online, the application continues to use outdated data.
I did not find an acceptable alternative, at least to my opinion, other than scraping the data from https://www.knmi.nl/nederland-nu/weer/w ... gelderland or any other area. However, I am not really satisfied with it, as it will give a general weather alarm and not a regional weather alarm. So if a fog alarm is issued by KNMI for the province of e.g. Groningen, you will also get it in other areas.
So I mailed with KNMI:
(In Dutch)
Sinds dinsdag 31 oktober, 22:32:00 u, wordt de XML file (https://cdn.knmi.nl/knmi/xml/rss/rss_KN ... wingen.xml) niet meer bijgewerkt. Betekent dit, dat deze XML feed niet meer beschikbaar is of is dit een storing?
Bij voorbaat dank voor een antwoord.
Met vriendelijke groet.
And I received the following response from KNMI:
Beste
Dank voor uw bericht. Het klopt dat de RSS feeds offline zijn gezet.
We zijn aan het kijken of er een alternatief voorhanden is.
U hoort nog van ons.
Met vriendelijke groet,
As this means that the application still works, but that the received data is useless, I will post my alternative in a next post.
Also other applications, which use the RSS/XML feed will not receive the correct data.
As soon as I do receive an answer from KNMI, I will post it here, in order to keep the Domoticz community updated.
If someone knows a better alternative (URL) to retrieve the data from, please post it here.
Posted: Monday 13 November 2023 15:18
by Toulon7559
The 'problem' is more general than just missing the Alarm-information:
see this Dutch weblink.
The most professional way to get hold of KNMI's Data is via their DeveloperWebportal, but that is not easy.
A simpler and still available, alternatieve access to KNMI's weather-alert information is via weerlive.nl
You need an APIkey, but then get a JSON-file, e.g. by means of following lua-script-line which by geolocation-coordinates is dedicated to a place of your choice.
result=os.capture('curl -s "http://weerlive.nl/api/json-data-10min.php?key='..api_key..'&locatie='..coord..'
Demonstration-url:
https://weerlive.nl/api/json-data-10min.php?key=demo&locatie=Amsterdam
Application is free upto a certain quotum of calls per day:
if exceeding the limit, then no further reception of useful info for that day.
Paid API-key is possible, and has plenty more volume.
What you next need is a data-extraction from that JSON-file, as I already realised for myself with a variant of this lua-script.
The JSON-file has a field called 'alarm'
When alarm = 0, then Code = Green and field alarmtxt empty
For alarm = 1, you get in field alarmtxt the text of KNMI's alarm-alert
Not only alarmtxt provided in that JSON-file, but also for the selected geolocation the actual data, and forecast data for 3 days.
Posted: Monday 13 November 2023 15:19
by FireWizard
As I mentioned already in my previous post I will share a new Node-RED flow, that uses web scraping from
https://www.knmi.nl/nederland-nu/weer/w ... gelderland or any other area (12 provinces and 3 coastal areas), if you use the correct name in the URL
The page shows the following:
I use the text in the upper left corner (in this case "Code geel") and as alarm text I use the first sentence under the header (in this case "Vanmiddag zware windstoten).
In this case the widget looks as follows:
Other texts are possible, but be aware, that these are not to long , as it will not look nice.
Screenshot_weather_alarm_long text.png (100.67 KiB) Viewed 6791 times
This is the reason I use only the first sentence.
As said earlier this information is visible as soon as for one of the areas KNMI issues a weather alarm so it may not apply to your region.
Please find the Node-RED flow below.
Do not forget to insert your own IDX number and the configuration of the MQTT server.
        "id": "f280c34267f25b07",
        "type": "tab",
        "label": "Meteoalarm",
        "disabled": false,
        "info": "",
        "env": []
        "id": "47228895277fa36c",
        "type": "http request",
        "z": "f280c34267f25b07",
        "name": "Request KNMI Weeralarm",
        "method": "GET",
        "ret": "txt",
        "paytoqs": "ignore",
        "url": "https://www.knmi.nl/nederland-nu/weer/waarschuwingen/gelderland",
        "tls": "",
        "persist": false,
        "proxy": "",
        "insecureHTTPParser": false,
        "authType": "",
        "senderr": false,
        "headers": [],
        "x": 420,
        "y": 160,
        "wires": [
                "d54e838f89afb841"
        "id": "2042c5058b479a35",
        "type": "comment",
        "name": "Meteoalarm KNMI",
        "info": "",
        "x": 690,
        "y": 100,
        "wires": []
        "id": "8859f56f79c115f3",
        "type": "inject",
        "name": "10 Minute tick",
        "props": [
                "p": "payload"
        "repeat": "600",
        "crontab": "",
        "once": true,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "payloadType": "date",
        "x": 160,
        "y": 160,
        "wires": [
                "47228895277fa36c"
        "id": "86349c071e6759a9",
        "type": "function",
        "name": "Function",
        "func": "switch (msg.payload[0]) {\n\n    case \"Code groen\":\n        msg.payload = { \"command\": \"udevice\", \"idx\": 28, \"nvalue\": 1, \"svalue\": msg.payload[1].slice(0, msg.payload[1].indexOf(\".\") + 1) };\n        break;\n\n   case \"Code geel\" :\n        msg.payload = { \"command\": \"udevice\", \"idx\": 28, \"nvalue\": 2, \"svalue\": msg.payload[1].slice(0, msg.payload[1].indexOf(\".\") + 1) };\n        break;\n\n    case \"Code oranje\":\n        msg.payload = { \"command\": \"udevice\", \"idx\": 28, \"nvalue\": 3, \"svalue\": msg.payload[1].slice(0, msg.payload[1].indexOf(\".\") + 1) };\n        break;\n\n    case \"Code rood\":\n        msg.payload = { \"command\": \"udevice\", \"idx\": 28, \"nvalue\": 4, \"svalue\": msg.payload[1].slice(0, msg.payload[1].indexOf(\".\") + 1) };\n        break;\n\n    default:\n        msg.payload = { \"command\": \"udevice\", \"idx\": 28, \"nvalue\": 0, \"svalue\": \"No Data available\" };\n        break;\n}\nreturn msg",
        "outputs": 1,
        "timeout": "",
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 900,
        "y": 160,
        "wires": [
                "66949beb9bcff093"
        "id": "66949beb9bcff093",
        "type": "mqtt out",
        "name": "Domoticz In",
        "topic": "domoticz/in",
        "qos": "",
        "retain": "",
        "respTopic": "",
        "contentType": "",
        "userProps": "",
        "correl": "",
        "expiry": "",
        "broker": "108bbff65a6cdbf3",
        "x": 1090,
        "y": 160,
        "wires": []
        "id": "d54e838f89afb841",
        "type": "html",
        "name": "Code/Text Select",
        "outproperty": "payload",
        "tag": "div.alert__heading,p",
        "ret": "text",
        "as": "single",
        "x": 690,
        "y": 160,
        "wires": [
                "86349c071e6759a9"
        "id": "108bbff65a6cdbf3",
        "type": "mqtt-broker",
        "name": "",
        "broker": "192.168.10.51",
        "port": "1883",
        "clientid": "",
        "autoConnect": true,
        "usetls": false,
        "protocolVersion": "4",
        "keepalive": "60",
        "cleansession": true,
        "autoUnsubscribe": true,
        "birthTopic": "",
        "birthQos": "0",
        "birthPayload": "",
        "birthMsg": {},
        "closeTopic": "",
        "closeQos": "0",
        "closePayload": "",
        "closeMsg": {},
        "willTopic": "",
        "willQos": "0",
        "willPayload": "",
        "willMsg": {},
        "userProps": "",
        "sessionExpiry": ""
Posted: Monday 13 November 2023 15:33
by FireWizard
Hello @Toulon7559,
Thanks for your response. I am aware of this and this could be indeed an alternative if KNMI does not offer another solution.
Alarm text is the same as I use, at least the first line.
alarm 0 is indeed Code Green and alarm 1 is Code Yellow.
What is Code Orange and Code Red?
Posted: Monday 13 November 2023 15:42
by Toulon7559
Unfortunately Weerlive.nl only signals by alarm=1 THAT an Alarm is valid, not the sublevel for Code-colours Orange, Yellow and Red.
At this moment, to get that level of detail we must become able to access the data at KNMI's DeveloperPortal:
some work to be done to make it easy, but once we have found a way, a bounty of data becomes accessible ..............
Posted: Monday 13 November 2023 15:44
There is also https://feeds.meteoalarm.org/feeds/mete ... etherlands that still shows the info based on KNMI data
Posted: Monday 13 November 2023 16:00
by Toulon7559
Walter,
Indeed from that weblink it is even possible to get alarm-text per province, but data-extraction from the output rss-information is more challenging than extraction from weerlive.nl
;-) Perhaps better apply the time, intelligence and energy to get access to KNMI's DeveloperPortal?
Posted: Monday 13 November 2023 16:16
by FireWizard
@waltervl and @Toulon7559,
Walter,
I looked to the meteoalarm.org website as well, but their map differs from the KNMI map.
If you look now, all areas show a code "yellow". The meteoalarm.org map does not issue a warning for the 3 coastal provinces (!) and Noord-Brabant.
That looks strange. I trust the KNMI map more than the Meteoalarm.org map.
Toulon7559
The developers portal is maybe the best option and I will certainly have a look to the possibilities.
I'll keep you updated.
