Battery
EddyG
Re: Battery
Post by EddyG »
There are several scripts on this forum that can regularly check battery levels.
Even in the dzVents example directory there is a script.
And if you really know Domoticz, you would know that in the device list you can search and sort.
And if I am not mistaken there is a warning on the device when battery is low.
Domoticz version: 2024.7
Re: Battery
Battery low should give a yellow color on the device widget.
thomasbaetge
Domoticz version: 2023.1
Re: Battery
Post by thomasbaetge »
Under 'Settings' - 'Other' you can specify a threshold for battery level. If batteries drop below, you will receive a warning notification.
What else could you wish for?
HM31
Re: Battery
Post by HM31 »
In domoticz documentation about the battery level notification setting https://www.domoticz.com/wiki/Applicati ... _Low_Level , it's mentionned that when value is set to 0, that means no notification.
I set the parameter to 0 but I still receive a notification for two Zipato keypads that incorrectly report battery level to 0.
Is there a way to stop this ? ... Of course as I use notifications for other purpose I don't want to disable any notification at all ;-)
