issue with os.execute
usky73
Domoticz version: 2021.1
Post by usky73 »
Hi all
I am reusing a script un dz.vents but facing issue with os.execute that is not working.
The command is working well in a terminal.
The domoticz is installed on a raspbery under buster.
the instruction is :
command = "/usr/bin/python3 "..scriptPython.." "..credentials.." "..fichierTemp.." &"
domoticz.log(command)
os.execute(command)
the command print in the log is : "/usr/bin/python3 /home/pi/domoticz/scripts/python/MyRenault.py /home/pi/domoticz/scripts/python/credentials.json /var/tmp/zoe.txt &"
What could be the issue ?
Thanks for your support
Domoticz version: 2025.1
Re: issue with os.execute
Try to run the command in a shell as root (eg with sudo) as Domoticz will do that too.
BTW it's better to use domoticz.executeShellCommand() instead of os.execute() see wiki:
https://www.domoticz.com/wiki/DzVents:_ ... _execution
usky73
Post by usky73 »
thanks a lot, it looks interesting. I will investigate.
UPDATED : Problem solved thanks to your 2 advices.
1- the issue becomes visible by using sudo in the terminal. I was able to see that it was missing a library for root.
2- the asynch lethod is much better !
Thanks again for your help.
Great, have fun!
