Page 1 of 2
Zigate USB v.1 behaving differently after upgrade to 3.21
Posted: Thursday 13 January 2022 18:46
by JanZorz
Hey,
I suspect that this would be of interest to @pipiche
After upgrading Zigate USB v.1 to 3.21 - two of zigbee devices started to act strange. Konke switch (model 3AFE170100510001) and Tuya 4-way switch (TS0044).
When I press them once or twice or long press - everything works. However, they just randomly started sending commands to Zigate as if I would press them once, at random times - despite the fact that I removed Konke switch old binding and registered it fresh into Zigate.
2022-01-12 00:28:15.734 Zigate: UpdateDevice - ( 4w-sw-dl) 0:00
2022-01-12 04:30:52.457 Zigate: UpdateDevice - ( 4w-sw-dl) 0:00
2022-01-12 08:33:08.315 Zigate: UpdateDevice - ( 4w-sw-dl) 0:00
2022-01-12 16:37:20.883 Zigate: UpdateDevice - ( 4w-sw-dl) 0:00
2022-01-12 20:39:11.000 Zigate: UpdateDevice - ( 4w-sw-dl) 0:00
2022-01-13 04:44:11.559 Zigate: UpdateDevice - ( 4w-sw-dl) 0:00
2022-01-13 12:49:41.944 Zigate: UpdateDevice - ( 4w-sw-dl) 0:00
2022-01-13 16:52:08.714 Zigate: UpdateDevice - ( 4w-sw-dl) 0:00
2022-01-12 12:47:18.015 Zigate: UpdateDevice - ( Konke Switch) 0:00
2022-01-12 19:56:12.491 Zigate: UpdateDevice - ( Konke Switch) 0:00
2022-01-13 01:38:59.050 Zigate: UpdateDevice - ( Konke Switch) 0:00
2022-01-13 17:31:04.398 Zigate: UpdateDevice - ( Konke Switch) 0:00
On Tuya 4-way switch I can see that all led lights on the switch buttons goes on and then this log entry appears.
I figured out this because Konke switch was used to switch manually between "daylight" and "night" state and imagine the mayhem when all sort of things started happening in the house at 01:38am
Any idea what could be going on and/or how we could debug this? My wife is still mad at me because of events in the middle of the night and I would like to spare this to everyone else
Cheers and thnx, Jan
Re: Zigate USB v.1 behaving differently after upgrade to 3.21
Posted: Friday 14 January 2022 2:01
by JanZorz
And again this night, without touching those two devices whatsoever:
2022-01-14 00:56:48.145 Zigate: UpdateDevice - ( 4w-sw-dl) 0:00
2022-01-14 00:42:39.710 Zigate: UpdateDevice - ( Konke Switch) 0:00
WTH?
Cheers, Jan
Posted: Friday 14 January 2022 11:46
by pipiche
would it be possible to enable some debug and then drop me the log file ?
debug to be enabled are :
debugClusters
debugzigateCmd
This would produce some extensive logs (depending on how many devices you have)
Posted: Friday 14 January 2022 11:58
by JanZorz
30 devices...
Enabled both debugging options, lets see what I get into the log file.
Posted: Friday 14 January 2022 12:03
by pipiche
Just had a quick look, and from my understand the Konke cannot switch Off by itself.
But can you check the settings and especially "Number of sec after the Selector is reset to Off" ?
In case you have a value above 0 , this is reprents the number of seconds before putting the selector in an Off position
- Screenshot 2022-01-14 at 12.01.52.png (19.69 KiB) Viewed 1276 times
Posted: Friday 14 January 2022 13:11
by JanZorz
Tuya TS0044 just did that:
2022-01-14 13:03:40.173 Zigate: send_zigatecmd_raw - [12522] 0530 022d410101000a010402000b180101070000232c317429 None Queue Length: 1
2022-01-14 13:03:40.174 Zigate: _sendData to ZiGate NOW - [12522] 0530 022d410101000a010402000b180101070000232c317429
2022-01-14 13:03:40.226 Zigate: Transport - [12309] - Async 8012 Sqn: 66 Addr: 2d41 nPdu: 00 aPdu: 01
2022-01-14 13:03:40.278 Zigate: Decod8000 Received [ ] PacketType: 0530 TypeSqn: 01 sqn_app: 67/103 sqn_aps: 67/103 Status: [00] npd
u: 00 apdu: 02
2022-01-14 13:03:40.988 Zigate: send_zigatecmd_raw - [12523] 0100 022d410101000600000000010000 2d41 Queue Length: 1
2022-01-14 13:03:40.988 Zigate: sendData - Warning 0100/022d410101000600000000010000 already in queue this command is dropped
2022-01-14 13:03:40.988 Zigate: send_zigatecmd_raw - [None] 0100 022d410101000600000000010000 2d41 Queue Length: 1
2022-01-14 13:03:40.989 Zigate: sendData - Warning 0100/022d410101000600000000010000 already in queue this command is dropped
2022-01-14 13:03:40.989 Zigate: send_zigatecmd_raw - [None] 0100 022d410101000600000000010000 2d41 Queue Length: 1
2022-01-14 13:03:41.893 Zigate: Decod8011 Received [12309] for Nwkid: 2d41 with status: 00 e_sqn: 0x66/102
2022-01-14 13:03:42.198 Zigate: _sendData to ZiGate NOW - [12523] 0100 022d410101000600000000010000
2022-01-14 13:03:42.198 Zigate: Decod8011 Received [12522] for Nwkid: 2d41 with status: 00 e_sqn: 0x67/103
2022-01-14 13:03:42.310 Zigate: Decod8000 Received [12523] PacketType: 0100 TypeSqn: 01 sqn_app: 63/99 sqn_aps: 68/104 Status: [00] npdu: 01 apdu: 01
2022-01-14 13:03:42.466 Zigate: ReadCluster - 0006 - 2d41/01 AttrId: 0000 AttrType: 10 Attsize: 0001 Status: 00 AttrValue: 00
2022-01-14 13:03:42.470 Zigate: UpdateDevice - ( 4w-sw-dl) 0:00
2022-01-14 13:03:42.471 Zigate: ReadCluster - ClusterId=0006 - reception General: On/Off: 00
2022-01-14 13:03:42.512 Zigate: Decod8011 Received [12523] for Nwkid: 2d41 with status: 00 e_sqn: 0x68/104
2022-01-14 13:03:44.126 Zigate: Transport - [12311] - Async 8012 Sqn: 69 Addr: 2d41 nPdu: 00 aPdu: 01
2022-01-14 13:03:44.129 Zigate: send_zigatecmd_raw - [12524] 0530 022d410101000a010402000b1800010700002330317429 None Queue Length: 1
2022-01-14 13:03:44.130 Zigate: _sendData to ZiGate NOW - [12524] 0530 022d410101000a010402000b1800010700002330317429
2022-01-14 13:03:44.234 Zigate: Decod8000 Received [ ] PacketType: 0530 TypeSqn: 01 sqn_app: 6a/106 sqn_aps: 6a/106 Status: [00] npdu: 00 apdu: 02
2022-01-14 13:03:44.286 Zigate: Decod8011 Received [12311] for Nwkid: 2d41 with status: 00 e_sqn: 0x69/105
2022-01-14 13:03:44.354 Zigate: Decod8011 Received [12524] for Nwkid: 2d41 with status: 00 e_sqn: 0x6a/106
2022-01-14 13:03:48.489 Zigate: send_zigatecmd_raw - [12525] 0530 025b120101000a010402000b18a401000000e234317429 None Queue Length: 1
2022-01-14 13:03:48.490 Zigate: _sendData to ZiGate NOW - [12525] 0530 025b120101000a010402000b18a401000000e234317429
2022-01-14 13:03:48.598 Zigate: Decod8000 Received [ ] PacketType: 0530 TypeSqn: 01 sqn_app: 6b/107 sqn_aps: 6b/107 Status: [00] npdu: 00 apdu: 01
Is that enough of data? I can send more if needed, just tell me the time-span before and after the event.
Cheers, Jan
Posted: Friday 14 January 2022 13:14
by JanZorz
pipiche wrote: Friday 14 January 2022 12:03
"Number of sec after the Selector is reset to Off" was (and still is) set to 0
Cheers, Jan
Posted: Friday 14 January 2022 13:16
by JanZorz
Interesting thing is that when this happens to Tuya TS0044 switch - all led lights behind all four buttons goes on for a second or two and then switches off... like if it was reset remotely or something similar...
Cheers, Jan
Posted: Friday 14 January 2022 13:17
by JanZorz
0:00 is basically the value of "1 Click".
Cheers, Jan
Posted: Friday 14 January 2022 14:10
by pipiche
JanZorz wrote: Friday 14 January 2022 13:11
u: 00 apdu: 02
Cheers, Jan
Indeed can you give me more log let say from 13:00 to 13:04
could you also provide me the export.json from > tools > tools > Plugin Devices List (RAW)
Posted: Friday 14 January 2022 14:17
by pipiche
Can you check the battery of those 2 devices.
I did test with the Konke, and I for instance remove the battery, and then put the battery's back. This generate such behaviour . So might a low battery could trigger that.
Posted: Friday 14 January 2022 14:50
by JanZorz
pipiche wrote: Friday 14 January 2022 14:10
2022-01-14 13:00:08.198 Zigate: ReadCluster - 0400 - c711/01 AttrId: 0000 AttrType: 21 Attsize: 0002 Status: 00 AttrValue: 0057
2022-01-14 13:00:08.198 Zigate: readCluster - 0400 - c711/01 Attr: 0000 Type: 21 Size: 0002 0057
2022-01-14 13:00:08.198 Zigate: ReadCluster - 0400 - c711/01 - LUX Sensor: 87/87
2022-01-14 13:00:08.204 Zigate: UpdateDevice - (Zigate - lumi.sensor_motion.aq2_Lux-00158d00034d0b72-01) 87:87
2022-01-14 13:00:08.205 Zigate: ReadCluster - 0406 - c711/01 AttrId: 0000 AttrType: 18 Attsize: 0001 Status: 00 AttrValue: 01
2022-01-14 13:00:08.205 Zigate: ReadCluster - ClusterId=0406 - reception Occupancy Sensor: 01
2022-01-14 13:00:08.207 Zigate: UpdateDevice - (Senzor stopnisce - premikanje) 1:On
2022-01-14 13:00:15.151 Zigate: send_zigatecmd_raw - [12504] 0530 02bcb70101000a010402000b183c01000000e25f307429 None Queue Length: 1
2022-01-14 13:00:15.153 Zigate: _sendData to ZiGate NOW - [12504] 0530 02bcb70101000a010402000b183c01000000e25f307429
2022-01-14 13:00:15.259 Zigate: Decod8000 Received [ ] PacketType: 0530 TypeSqn: 01 sqn_app: 50/80 sqn_aps: 50/80 Status: [00] npdu: 00 apdu: 01
2022-01-14 13:00:15.259 Zigate: Decod8011 Received [12504] for Nwkid: bcb7 with status: 00 e_sqn: 0x50/80
2022-01-14 13:00:18.092 Zigate: ReadCluster - 0000 - e661/01 AttrId: ff01 AttrType: 42 Attsize: 001f Status: 00 AttrValue: 0121db0b0421a81305216c0006240200000000642994086521b7120a21b7bc
2022-01-14 13:00:18.092 Zigate: ReadCluster - 0000 ff01 Saddr: e661 ClusterData: 0121db0b0421a81305216c0006240200000000642994086521b7120a21b7bc
2022-01-14 13:00:18.093 Zigate: UpdateDevice - (Temp senzor Jakob - Temp+hum) 0:22.0;48.2;1
2022-01-14 13:00:18.094 Zigate: UpdateDevice - (Zigate - lumi.sens_Temp-00158d00063dd5bd-01) 22.0:22.0
2022-01-14 13:00:18.097 Zigate: UpdateDevice - (Temp senzor Jakob - Temp+hum) 0:22.0;47.9;1
2022-01-14 13:00:18.098 Zigate: UpdateDevice - (Zigate - lumi.sens_Humi-00158d00063dd5bd-01) 47.9:1
2022-01-14 13:00:27.410 Zigate: send_zigatecmd_raw - [12505] 0530 02b0880101000a010402000b185301000000e26b307429 None Queue Length: 1
2022-01-14 13:00:27.411 Zigate: _sendData to ZiGate NOW - [12505] 0530 02b0880101000a010402000b185301000000e26b307429
2022-01-14 13:00:27.518 Zigate: Transport - [12292] - Async 8012 Sqn: 51 Addr: 162b nPdu: 00 aPdu: 01
2022-01-14 13:00:27.519 Zigate: Decod8000 Received [ ] PacketType: 0530 TypeSqn: 01 sqn_app: 52/82 sqn_aps: 52/82 Status: [00] npdu: 00 apdu: 02
2022-01-14 13:00:27.519 Zigate: Decod8011 Received [12292] for Nwkid: 162b with status: 00 e_sqn: 0x51/81
2022-01-14 13:00:27.521 Zigate: Decod8011 Received [12505] for Nwkid: b088 with status: 00 e_sqn: 0x52/82
2022-01-14 13:00:35.787 Zigate: ReadCluster - 0400 - 6881/01 AttrId: 0000 AttrType: 21 Attsize: 0002 Status: 00 AttrValue: 85fa
2022-01-14 13:00:35.787 Zigate: readCluster - 0400 - 6881/01 Attr: 0000 Type: 21 Size: 0002 85fa
2022-01-14 13:00:35.787 Zigate: ReadCluster - 0400 - 6881/01 - LUX Sensor: 34298/2689
2022-01-14 13:00:35.789 Zigate: UpdateDevice - (Senzor svetlobe - okrogel) 2689:2689
2022-01-14 13:00:40.776 Zigate: ReadCluster - 0400 - 6881/01 AttrId: 0000 AttrType: 21 Attsize: 0002 Status: 00 AttrValue: 85f8
2022-01-14 13:00:40.776 Zigate: readCluster - 0400 - 6881/01 Attr: 0000 Type: 21 Size: 0002 85f8
2022-01-14 13:00:40.776 Zigate: ReadCluster - 0400 - 6881/01 - LUX Sensor: 34296/2688
2022-01-14 13:00:40.780 Zigate: UpdateDevice - (Senzor svetlobe - okrogel) 2688:2688
2022-01-14 13:00:52.071 Zigate: send_zigatecmd_raw - [12506] 0530 025b120101000a010402000b18a101000000e284307429 None Queue Length: 1
2022-01-14 13:00:52.072 Zigate: _sendData to ZiGate NOW - [12506] 0530 025b120101000a010402000b18a101000000e284307429
2022-01-14 13:00:52.179 Zigate: Decod8000 Received [ ] PacketType: 0530 TypeSqn: 01 sqn_app: 53/83 sqn_aps: 53/83 Status: [00] npdu: 00 apdu: 01
2022-01-14 13:00:52.180 Zigate: Decod8011 Received [12506] for Nwkid: 5b12 with status: 00 e_sqn: 0x53/83
2022-01-14 13:00:53.644 Zigate: send_zigatecmd_raw - [12507] 0530 02b0880101000a010402000b185401000000e285307429 None Queue Length: 1
2022-01-14 13:00:53.646 Zigate: _sendData to ZiGate NOW - [12507] 0530 02b0880101000a010402000b185401000000e285307429
2022-01-14 13:00:53.751 Zigate: Decod8000 Received [ ] PacketType: 0530 TypeSqn: 01 sqn_app: 54/84 sqn_aps: 54/84 Status: [00] npdu: 00 apdu: 01
2022-01-14 13:00:53.751 Zigate: Decod8011 Received [12507] for Nwkid: b088 with status: 00 e_sqn: 0x54/84
2022-01-14 13:00:59.099 Zigate: ReadCluster - fcc0 - bcb7/01 AttrId: 00f7 AttrType: 41 Attsize: 003d Status: 00 AttrValue: 641000032815983900000000953959ba2b40963900000c45973900000000052107009a20100821160107270000000000000000092102070b20009b1001
2022-01-14 13:00:59.099 Zigate: ReadCluster fcc0 - bcb7/01 Attribute: 00f7 Type: 41 Size: 003d Data: 641000032815983900000000953959ba2b40963900000c45973900000000052107009a20100821160107270000000000000000092102070b20009b1001
2022-01-14 13:00:59.250 Zigate: ReadCluster - 0000 - 6bcc/01 AttrId: ff01 AttrType: 42 Attsize: 001d Status: 00 AttrValue: 0121810b0328090421a8130521b601062401000000000a21125b641000
2022-01-14 13:00:59.250 Zigate: ReadCluster - 0000 ff01 Saddr: 6bcc ClusterData: 0121810b0328090421a8130521b601062401000000000a21125b641000
2022-01-14 13:01:00.712 Zigate: ReadCluster - 0400 - 6881/01 AttrId: 0000 AttrType: 21 Attsize: 0002 Status: 00 AttrValue: 85f5
2022-01-14 13:01:00.712 Zigate: readCluster - 0400 - 6881/01 Attr: 0000 Type: 21 Size: 0002 85f5
2022-01-14 13:01:00.712 Zigate: ReadCluster - 0400 - 6881/01 - LUX Sensor: 34293/2686
2022-01-14 13:01:00.723 Zigate: UpdateDevice - (Senzor svetlobe - okrogel) 2686:2686
2022-01-14 13:01:08.578 Zigate: send_zigatecmd_raw - [12508] 0530 02bcb70101000a010402000b183e01000000e294307429 None Queue Length: 1
2022-01-14 13:01:08.579 Zigate: _sendData to ZiGate NOW - [12508] 0530 02bcb70101000a010402000b183e01000000e294307429
2022-01-14 13:01:08.690 Zigate: Decod8000 Received [ ] PacketType: 0530 TypeSqn: 01 sqn_app: 55/85 sqn_aps: 55/85 Status: [00] npdu: 00 apdu: 01
2022-01-14 13:01:08.691 Zigate: Decod8011 Received [12508] for Nwkid: bcb7 with status: 00 e_sqn: 0x55/85
2022-01-14 13:01:10.657 Zigate: ReadCluster - 0400 - 6881/01 AttrId: 0000 AttrType: 21 Attsize: 0002 Status: 00 AttrValue: 85f4
2022-01-14 13:01:10.658 Zigate: readCluster - 0400 - 6881/01 Attr: 0000 Type: 21 Size: 0002 85f4
2022-01-14 13:01:10.658 Zigate: ReadCluster - 0400 - 6881/01 - LUX Sensor: 34292/2685
2022-01-14 13:01:10.662 Zigate: UpdateDevice - (Senzor svetlobe - okrogel) 2685:2685
2022-01-14 13:01:15.650 Zigate: ReadCluster - 0400 - 6881/01 AttrId: 0000 AttrType: 21 Attsize: 0002 Status: 00 AttrValue: 85f2
2022-01-14 13:01:15.650 Zigate: readCluster - 0400 - 6881/01 Attr: 0000 Type: 21 Size: 0002 85f2
2022-01-14 13:01:15.651 Zigate: ReadCluster - 0400 - 6881/01 - LUX Sensor: 34290/2684
2022-01-14 13:01:15.654 Zigate: UpdateDevice - (Senzor svetlobe - okrogel) 2684:2684
2022-01-14 13:01:20.488 Zigate: Transport - [12089] - Async 8012 Sqn: 56 Addr: 162b nPdu: 00 aPdu: 01
2022-01-14 13:01:20.489 Zigate: Decod8011 Received [12089] for Nwkid: 162b with status: 00 e_sqn: 0x56/86
2022-01-14 13:01:25.294 Zigate: ReadCluster - 0402 - 4fd9/01 AttrId: 0000 AttrType: 29 Attsize: 0002 Status: 00 AttrValue: 08dc
2022-01-14 13:01:25.294 Zigate: readCluster - 0402 - 4fd9/01 Temperature Measurement: 22.7
2022-01-14 13:01:25.301 Zigate: ReadCluster - 0405 - 4fd9/01 AttrId: 0000 AttrType: 21 Attsize: 0002 Status: 00 AttrValue: 1062
2022-01-14 13:01:25.302 Zigate: ReadCluster - ClusterId=0405 - reception hum: 4194 - 41.9
2022-01-14 13:01:25.308 Zigate: ReadCluster - 0403 - 4fd9/01 AttrId: 0000 AttrType: 29 Attsize: 0002 Status: 00 AttrValue: 03d7
2022-01-14 13:01:25.308 Zigate: Cluster0403 - decoded value: from:03d7 to 983
2022-01-14 13:01:25.320 Zigate: UpdateDevice - (Zigate - lumi.weather_Temp+Hum+Baro-00158d0002f2f19c-01) 0:22.7;41.9;1;983.0;4
2022-01-14 13:01:25.331 Zigate: UpdateDevice - (Zigate - lumi.weather_Baro-00158d0002f2f19c-01) 0:983.0;4
2022-01-14 13:01:25.331 Zigate: ReadCluster - ClusterId=0403 - 0000 reception atm: 983
2022-01-14 13:01:25.334 Zigate: ReadCluster - 0403 - 4fd9/01 AttrId: 0014 AttrType: 28 Attsize: 0001 Status: 00 AttrValue: ff
2022-01-14 13:01:25.334 Zigate: Cluster0403 - decoded value: from:ff to 255
2022-01-14 13:01:25.334 Zigate: ReadCluster - 4fd9/01 ClusterId=0403 - Scale 0014: ff
2022-01-14 13:01:25.337 Zigate: ReadCluster - 0403 - 4fd9/01 AttrId: 0010 AttrType: 29 Attsize: 0002 Status: 00 AttrValue: 266e
2022-01-14 13:01:25.338 Zigate: Cluster0403 - decoded value: from:266e to 9838
2022-01-14 13:01:25.340 Zigate: UpdateDevice - (Zigate - lumi.weather_Temp+Hum+Baro-00158d0002f2f19c-01) 0:22.7;41.9;1;983.8;4
2022-01-14 13:01:25.343 Zigate: UpdateDevice - (Zigate - lumi.weather_Baro-00158d0002f2f19c-01) 0:983.8;4
2022-01-14 13:01:25.344 Zigate: ReadCluster - 4fd9/01 ClusterId=0403 - Scaled value 0010: 266e
2022-01-14 13:01:28.065 Zigate: send_zigatecmd_raw - [12509] 0100 07bcb7010107020000000003000002000301 bcb7 Queue Length: 1
2022-01-14 13:01:28.065 Zigate: send_zigatecmd_raw - [12510] 0100 07bcb7010107020000000003030203030306 bcb7 Queue Length: 2
2022-01-14 13:01:28.065 Zigate: send_zigatecmd_raw - [12511] 0100 07bcb7011507020000000003000002000301 bcb7 Queue Length: 3
2022-01-14 13:01:28.065 Zigate: send_zigatecmd_raw - [12512] 0100 07bcb7011507020000000003030203030306 bcb7 Queue Length: 4
2022-01-14 13:01:28.067 Zigate: _sendData to ZiGate NOW - [12509] 0100 07bcb7010107020000000003000002000301
2022-01-14 13:01:28.171 Zigate: Decod8000 Received [12509] PacketType: 0100 TypeSqn: 01 sqn_app: 5c/92 sqn_aps: 57/87 Status: [00] np
du: 00 apdu: 00
2022-01-14 13:01:28.172 Zigate: _sendData to ZiGate NOW - [12510] 0100 07bcb7010107020000000003030203030306
2022-01-14 13:01:28.176 Zigate: ReadCluster - 0702 - bcb7/01 AttrId: 0000 AttrType: 25 Attsize: 0006 Status: 00 AttrValue: 000000000a06
2022-01-14 13:01:28.176 Zigate: Cluster0702 - MsgAttrID: 0000 MsgAttType: 25 DataLen: 0006 Data: 000000000a06 decodedValue: 2566
2022-01-14 13:01:28.176 Zigate: compute_conso - 0000 Power 2566, div: 1000 --> 2566.0 Watts
2022-01-14 13:01:28.176 Zigate: Cluster0702 - 0x0000 CURRENT_SUMMATION_DELIVERED Value: 000000000a06 Conso: 2566.0
2022-01-14 13:01:28.180 Zigate: ReadCluster - 0702 - bcb7/01 AttrId: 0200 AttrType: 18 Attsize: 0001 Status: 00 AttrValue: 00
2022-01-14 13:01:28.180 Zigate: Cluster0702 - MsgAttrID: 0200 MsgAttType: 18 DataLen: 0001 Data: 00 decodedValue: 0
2022-01-14 13:01:28.180 Zigate: Cluster0702 - Status: Ok
2022-01-14 13:01:28.183 Zigate: ReadCluster - 0702 - bcb7/01 AttrId: 0301 AttrType: 22 Attsize: 0004 Status: 00 AttrValue: 00000001
2022-01-14 13:01:28.183 Zigate: Cluster0702 - MsgAttrID: 0301 MsgAttType: 22 DataLen: 0004 Data: 00000001 decodedValue: 1
2022-01-14 13:01:28.183 Zigate: Cluster0702 - bcb7/01 Multiplier: 1
2022-01-14 13:01:28.279 Zigate: Decod8000 Received [12510] PacketType: 0100 TypeSqn: 01 sqn_app: 5d/93 sqn_aps: 58/88 Status: [00] npdu: 00 apdu: 00
2022-01-14 13:01:28.279 Zigate: _sendData to ZiGate NOW - [12511] 0100 07bcb7011507020000000003000002000301
2022-01-14 13:01:28.283 Zigate: ReadCluster - 0702 - bcb7/01 AttrId: 0302 AttrType: 22 Attsize: 0004 Status: 00 AttrValue: 000003e8
2022-01-14 13:01:28.283 Zigate: Cluster0702 - MsgAttrID: 0302 MsgAttType: 22 DataLen: 0004 Data: 000003e8 decodedValue: 1000
2022-01-14 13:01:28.283 Zigate: Cluster0702 - bcb7/01 Divisor: 1000
2022-01-14 13:01:28.286 Zigate: ReadCluster - 0702 - bcb7/01 AttrId: 0303 AttrType: 18 Attsize: 0001 Status: 00 AttrValue: 23
2022-01-14 13:01:28.286 Zigate: Cluster0702 - MsgAttrID: 0303 MsgAttType: 18 DataLen: 0001 Data: 23 decodedValue: 35
2022-01-14 13:01:28.286 Zigate: Cluster0702 - bcb7/01 Summation Formatting: 35
2022-01-14 13:01:28.290 Zigate: ReadCluster - 0702 - bcb7/01 AttrId: 0306 AttrType: 18 Attsize: 0001 Status: 00 AttrValue: 00
2022-01-14 13:01:28.290 Zigate: Cluster0702 - MsgAttrID: 0306 MsgAttType: 18 DataLen: 0001 Data: 00 decodedValue: 0
2022-01-14 13:01:28.290 Zigate: Cluster0702 - Divisor: Electric Metering
2022-01-14 13:01:28.387 Zigate: Decod8000 Received [12511] PacketType: 0100 TypeSqn: 01 sqn_app: 5e/94 sqn_aps: 59/89 Status: [00] npdu: 00 apdu: 00
2022-01-14 13:01:28.387 Zigate: _sendData to ZiGate NOW - [12512] 0100 07bcb7011507020000000003030203030306
2022-01-14 13:01:28.494 Zigate: Decod8000 Received [12512] PacketType: 0100 TypeSqn: 01 sqn_app: 5f/95 sqn_aps: 5a/90 Status: [00] npdu: 00 apdu: 00
2022-01-14 13:01:37.419 Zigate: send_zigatecmd_raw - [12513] 0530 025b120101000a010402000b18a201000000e2b1307429 None Queue Length: 1
2022-01-14 13:01:37.421 Zigate: _sendData to ZiGate NOW - [12513] 0530 025b120101000a010402000b18a201000000e2b1307429
2022-01-14 13:01:37.525 Zigate: Decod8000 Received [ ] PacketType: 0530 TypeSqn: 01 sqn_app: 5b/91 sqn_aps: 5b/91 Status: [00] npdu: 00 apdu: 01
2022-01-14 13:01:37.525 Zigate: Decod8011 Received [12513] for Nwkid: 5b12 with status: 00 e_sqn: 0x5b/91
2022-01-14 13:01:38.108 Zigate: send_zigatecmd_raw - [12514] 0100 07bcb701010b040000000001050b bcb7 Queue Length: 1
2022-01-14 13:01:38.110 Zigate: _sendData to ZiGate NOW - [12514] 0100 07bcb701010b040000000001050b
2022-01-14 13:01:38.191 Zigate: Decod8000 Received [12514] PacketType: 0100 TypeSqn: 01 sqn_app: 60/96 sqn_aps: 5c/92 Status: [00] npdu: 00 apdu: 00
2022-01-14 13:01:38.194 Zigate: ReadCluster - 0b04 - bcb7/01 AttrId: 050b AttrType: 29 Attsize: 0002 Status: 00 AttrValue: 0000
2022-01-14 13:01:38.194 Zigate: ReadCluster 0b04 - bcb7/01 Attribute: 050b Type: 29 Size: 0002 Data: 0
2022-01-14 13:01:38.194 Zigate: ReadCluster 0b04 - bcb7/01 Power 0
2022-01-14 13:01:40.562 Zigate: ReadCluster - 0400 - 6881/01 AttrId: 0000 AttrType: 21 Attsize: 0002 Status: 00 AttrValue: 85f0
2022-01-14 13:01:40.562 Zigate: readCluster - 0400 - 6881/01 Attr: 0000 Type: 21 Size: 0002 85f0
2022-01-14 13:01:40.562 Zigate: ReadCluster - 0400 - 6881/01 - LUX Sensor: 34288/2683
2022-01-14 13:01:40.570 Zigate: UpdateDevice - (Senzor svetlobe - okrogel) 2683:2683
2022-01-14 13:01:44.445 Zigate: ReadCluster - 0400 - 40ce/01 AttrId: 0000 AttrType: 21 Attsize: 0002 Status: 00 AttrValue: 003d
2022-01-14 13:01:44.445 Zigate: readCluster - 0400 - 40ce/01 Attr: 0000 Type: 21 Size: 0002 003d
2022-01-14 13:01:44.445 Zigate: ReadCluster - 0400 - 40ce/01 - LUX Sensor: 61/61
2022-01-14 13:01:44.449 Zigate: UpdateDevice - (Senzor svetlobe - Jan pisarna) 61:61
2022-01-14 13:01:44.450 Zigate: ReadCluster - 0406 - 40ce/01 AttrId: 0000 AttrType: 18 Attsize: 0001 Status: 00 AttrValue: 01
2022-01-14 13:01:44.450 Zigate: ReadCluster - ClusterId=0406 - reception Occupancy Sensor: 01
2022-01-14 13:01:44.452 Zigate: UpdateDevice - (Senzor premikanja - Jan pisarna) 1:On
2022-01-14 13:01:47.874 Zigate: ReadCluster - 0000 - 162b/01 AttrId: ff01 AttrType: 42 Attsize: 002b Status: 00 AttrValue: 64100003281e98390000000095397ba0a03e052128009a2000082122130727000000000000000009210307
2022-01-14 13:01:47.874 Zigate: ReadCluster - 0000 ff01 Saddr: 162b ClusterData: 64100003281e98390000000095397ba0a03e052128009a2000082122130727000000000000000009210307
2022-01-14 13:01:50.494 Zigate: ReadCluster - 0400 - 6881/01 AttrId: 0000 AttrType: 21 Attsize: 0002 Status: 00 AttrValue: 85ed
2022-01-14 13:01:50.494 Zigate: readCluster - 0400 - 6881/01 Attr: 0000 Type: 21 Size: 0002 85ed
2022-01-14 13:01:50.494 Zigate: ReadCluster - 0400 - 6881/01 - LUX Sensor: 34285/2681
2022-01-14 13:01:50.499 Zigate: UpdateDevice - (Senzor svetlobe - okrogel) 2681:2681
2022-01-14 13:01:58.963 Zigate: send_zigatecmd_raw - [12515] 0530 02bcb70101000a010402000b183f01000000e2c6307429 None Queue Length: 1
2022-01-14 13:01:58.964 Zigate: _sendData to ZiGate NOW - [12515] 0530 02bcb70101000a010402000b183f01000000e2c6307429
2022-01-14 13:01:59.071 Zigate: Decod8000 Received [ ] PacketType: 0530 TypeSqn: 01 sqn_app: 5d/93 sqn_aps: 5d/93 Status: [00] npdu: 00 apdu: 01
2022-01-14 13:01:59.071 Zigate: Decod8011 Received [12515] for Nwkid: bcb7 with status: 00 e_sqn: 0x5d/93
2022-01-14 13:02:02.296 Zigate: send_zigatecmd_raw - [12516] 0530 02b0880101000a010402000b185501000000e2ca307429 None Queue Length: 1
2022-01-14 13:02:02.297 Zigate: _sendData to ZiGate NOW - [12516] 0530 02b0880101000a010402000b185501000000e2ca307429
2022-01-14 13:02:02.404 Zigate: Decod8000 Received [ ] PacketType: 0530 TypeSqn: 01 sqn_app: 5e/94 sqn_aps: 5e/94 Status: [00] npdu: 00 apdu: 01
2022-01-14 13:02:02.404 Zigate: Decod8011 Received [12516] for Nwkid: b088 with status: 00 e_sqn: 0x5e/94
2022-01-14 13:02:10.423 Zigate: ReadCluster - 0400 - 6881/01 AttrId: 0000 AttrType: 21 Attsize: 0002 Status: 00 AttrValue: 85ea
2022-01-14 13:02:10.423 Zigate: readCluster - 0400 - 6881/01 Attr: 0000 Type: 21 Size: 0002 85ea
2022-01-14 13:02:10.423 Zigate: ReadCluster - 0400 - 6881/01 - LUX Sensor: 34282/2679
2022-01-14 13:02:10.428 Zigate: UpdateDevice - (Senzor svetlobe - okrogel) 2679:2679
2022-01-14 13:02:16.469 Zigate: Transport - [12303] - Async 8012 Sqn: 5f Addr: 162b nPdu: 00 aPdu: 01
2022-01-14 13:02:16.521 Zigate: Decod8011 Received [12303] for Nwkid: 162b with status: 00 e_sqn: 0x5f/95
2022-01-14 13:02:18.104 Zigate: send_zigatecmd_raw - [12517] 0100 07bcb70101000800000000010000 bcb7 Queue Length: 1
2022-01-14 13:02:18.104 Zigate: send_zigatecmd_raw - [12518] 0100 07bcb70101000600000000010000 bcb7 Queue Length: 2
2022-01-14 13:02:18.106 Zigate: _sendData to ZiGate NOW - [12517] 0100 07bcb70101000800000000010000
2022-01-14 13:02:18.198 Zigate: Decod8000 Received [12517] PacketType: 0100 TypeSqn: 01 sqn_app: 61/97 sqn_aps: 60/96 Status: [00] npdu: 00 apdu: 00
2022-01-14 13:02:18.206 Zigate: _sendData to ZiGate NOW - [12518] 0100 07bcb70101000600000000010000
2022-01-14 13:02:18.306 Zigate: Decod8000 Received [12518] PacketType: 0100 TypeSqn: 01 sqn_app: 62/98 sqn_aps: 61/97 Status: [00] npdu: 00 apdu: 00
2022-01-14 13:02:18.310 Zigate: ReadCluster - 0006 - bcb7/01 AttrId: 0000 AttrType: 10 Attsize: 0001 Status: 00 AttrValue: 00
2022-01-14 13:02:18.311 Zigate: ReadCluster - ClusterId=0006 - reception General: On/Off: 00
2022-01-14 13:02:58.443 Zigate: send_zigatecmd_raw - [12519] 0530 02bcb70101000a010402000b184001000000e202317429 None Queue Length: 1
2022-01-14 13:02:58.445 Zigate: _sendData to ZiGate NOW - [12519] 0530 02bcb70101000a010402000b184001000000e202317429
2022-01-14 13:02:58.555 Zigate: Decod8000 Received [ ] PacketType: 0530 TypeSqn: 01 sqn_app: 62/98 sqn_aps: 62/98 Status: [00] npdu: 00 apdu: 01
2022-01-14 13:02:58.555 Zigate: Decod8011 Received [12519] for Nwkid: bcb7 with status: 00 e_sqn: 0x62/98
2022-01-14 13:03:00.273 Zigate: ReadCluster - 0400 - 6881/01 AttrId: 0000 AttrType: 21 Attsize: 0002 Status: 00 AttrValue: 85e7
2022-01-14 13:03:00.273 Zigate: readCluster - 0400 - 6881/01 Attr: 0000 Type: 21 Size: 0002 85e7
2022-01-14 13:03:00.273 Zigate: ReadCluster - 0400 - 6881/01 - LUX Sensor: 34279/2677
2022-01-14 13:03:00.278 Zigate: UpdateDevice - (Senzor svetlobe - okrogel) 2677:2677
2022-01-14 13:03:09.497 Zigate: Transport - [12306] - Async 8012 Sqn: 63 Addr: 162b nPdu: 00 aPdu: 01
2022-01-14 13:03:09.498 Zigate: Decod8011 Received [12306] for Nwkid: 162b with status: 00 e_sqn: 0x63/99
2022-01-14 13:03:13.941 Zigate: send_zigatecmd_raw - [12520] 0530 02b0880101000a010402000b185601000000e211317429 None Queue Length: 1
2022-01-14 13:03:13.942 Zigate: _sendData to ZiGate NOW - [12520] 0530 02b0880101000a010402000b185601000000e211317429
2022-01-14 13:03:14.051 Zigate: Decod8000 Received [ ] PacketType: 0530 TypeSqn: 01 sqn_app: 64/100 sqn_aps: 64/100 Status: [00] npdu: 00 apdu: 01
2022-01-14 13:03:14.051 Zigate: Decod8011 Received [12520] for Nwkid: b088 with status: 00 e_sqn: 0x64/100
2022-01-14 13:03:21.261 Zigate: send_zigatecmd_raw - [12521] 0530 025b120101000a010402000b18a301000000e219317429 None Queue Length: 1
2022-01-14 13:03:21.262 Zigate: _sendData to ZiGate NOW - [12521] 0530 025b120101000a010402000b18a301000000e219317429
2022-01-14 13:03:21.367 Zigate: Decod8000 Received [ ] PacketType: 0530 TypeSqn: 01 sqn_app: 65/101 sqn_aps: 65/101 Status: [00] npdu: 00 apdu: 01
2022-01-14 13:03:21.367 Zigate: Decod8011 Received [12521] for Nwkid: 5b12 with status: 00 e_sqn: 0x65/101
2022-01-14 13:03:35.130 Zigate: ReadCluster - 0400 - 6881/01 AttrId: 0000 AttrType: 21 Attsize: 0002 Status: 00 AttrValue: 85ea
2022-01-14 13:03:35.130 Zigate: readCluster - 0400 - 6881/01 Attr: 0000 Type: 21 Size: 0002 85ea
2022-01-14 13:03:35.130 Zigate: ReadCluster - 0400 - 6881/01 - LUX Sensor: 34282/2679
2022-01-14 13:03:35.138 Zigate: UpdateDevice - (Senzor svetlobe - okrogel) 2679:2679
2022-01-14 13:03:40.278 Zigate: Decod8000 Received [ ] PacketType: 0530 TypeSqn: 01 sqn_app: 67/103 sqn_aps: 67/103 Status: [00] npdu: 00 apdu: 02
2022-01-14 13:03:48.600 Zigate: Decod8011 Received [12525] for Nwkid: 5b12 with status: 00 e_sqn: 0x6b/107
2022-01-14 13:03:55.106 Zigate: ReadCluster - 0400 - 6881/01 AttrId: 0000 AttrType: 21 Attsize: 0002 Status: 00 AttrValue: 85ed
2022-01-14 13:03:55.106 Zigate: readCluster - 0400 - 6881/01 Attr: 0000 Type: 21 Size: 0002 85ed
2022-01-14 13:03:55.106 Zigate: ReadCluster - 0400 - 6881/01 - LUX Sensor: 34285/2681
2022-01-14 13:03:55.111 Zigate: UpdateDevice - (Senzor svetlobe - okrogel) 2681:2681
export.json in pm (post length restriction
Cheers, Jan
Posted: Friday 14 January 2022 14:58
by JanZorz
pipiche wrote: Friday 14 January 2022 14:17
In Zigate dashboard when I check for battery levels - Konke switch is on 80%, TS0044 is on 100%...
Cheers, Jan
Posted: Friday 14 January 2022 15:25
by pipiche
can you enable debugInput and debugPairing in addition, as I suspect the device to send a Device Annoucement
Posted: Friday 14 January 2022 16:00
by JanZorz
pipiche wrote: Friday 14 January 2022 15:25
Done. Will post the log when it happens again.
Cheers, Jan
Posted: Monday 17 January 2022 12:54
by JanZorz
JanZorz wrote: Friday 14 January 2022 16:00
Cheers, Jan
Due to large size of the log - I sent it to you in PM.
Cheers, Jan
Posted: Monday 24 January 2022 12:48
by JanZorz
@pipiche - any luck with finding what's going on in my log files?
Through more observation - I came to few more conclusions:
- Tuya 4way switch kind of works because if you click the button it sends 1:00 value and not 0:00 as it is sent during those hiccups - so if you don't use 0:00 in any rules or triggers - you're fine. However it's annoying when hiccup occurs because all led lights go on for couple of seconds and in the night you have a switch on the wall that starts blinking for no reason.
- Konke switch: that is basically useless as if you press it once (one click) it sends 0:00 and that's the same as when hiccup occurs.
I'm wondering if those random events are connected to something that controller sends or are initiated by the device? Prior to Zigate firmware upgrade this did not happen, however.
Cheers, Jan
Posted: Monday 24 January 2022 12:56
by pipiche
I didn’t get your logs
But as they are end device based on battery they don’t listen to incoming messages outside of the pairing process ( which I suspect is the case, but this is something which has to be initiated by the device).
Can you try to change the location and put them closed to the coordinator
Posted: Monday 24 January 2022 13:19
by JanZorz
pipiche wrote: Monday 24 January 2022 12:56
Ah, crap... I sent you logs on 17th January, but instead of putting you as recipient there was just me in to: field. Sorry. I sent you logs again, did you receive them now?
Cheers, Jan
Posted: Monday 24 January 2022 13:44
by pipiche
no issue, please do try on the recent beta version (from now). I have push a protection to prevent handling the device annoucement.
