Virtual Sensor Switch On/Off only for status not for activation
Aroby
Post by Aroby »
Is it possible to show a "On" or Off" status without the possibility to operate the virtual sensor?
For example when I use a virtual switch you can operate it but that is not the idea. It's only for presenting the status. I tried to use the protected option but in that case a Lua script can't change it either.
or when I use a virtual sensor - text. it's possible to show the "on" or Off" status. But in that case You don't see an icon change when activated.
What do you use to overcome this?
EddyG
Re: Virtual Sensor Switch On/Off only for status not for activation
Post by EddyG »
From the dzVents Wiki "silent(): Function. No follow-up events will be triggered: mySwitch.switchOff().silent()."
Do you mean this?
Aroby
Post by Aroby »
The idea is to show an "Off" or "On" state only. Without being able to click on it and accidentally toggle it (like with a virtual switch). A Lua script in the background should be able to change the state.
Domoticz version: 2024.7
Edit the dummy switch to a sensor switch like Contact, Door contact, Motion sensor etc. I believe those cannot be switched from User interface. You can change the Icon to the desired one.
https://www.domoticz.com/wiki/Dummy_for ... h_Subtypes
Aroby
Post by Aroby »
Thanks for the quick reply. I will test it.
