piority and sound with pushover notifications  [Solved]
JdoTMM
Post by JdoTMM »
After using domoticz for several years now i'm ready for Lua and DZvents :)
Google and this forum are my friends and I have some DZVents working. Only thing I'm having problems with is the priority system within DZVents and the sound with Pushover.
I am getting notifications on pushover without problems, only problem I have is that I can't get the high priority or sound selection working.
Things i've done so far:
I set Pushover to use siren sound for high priority sound and enabled "Always use default for high-priority" and "Play high-priority as alarm" (also with these settings disabled).
The code I use for the notification part:
domoticz.notify('Brandalarm ' .. name .. ' is al ' .. minutes .. ' minuten geleden afgegaan.', domoticz.PRIORITY_EMERGENCY, domoticz.SOUND_ALIEN)
Tried it with and without the domoticz.SOUND part, used PRIORITY_HIGH as well. But pushover only uses the default sound.
I'm at a loss, I just can't get it to work.
Am I doing something wrong or is it broken?
Any help is appreciated
1 Aeotec ZW090, 2 FIB FGDW002, 1 FIB FGMS001, 3 FIB FGSD002,
4 Neo CoolCam Power plug, 1 Popp 004407, 1 FIB FGS222
1 NodOn CRC-3-1-00, DeConz, Milight, Tuya
mgugu
Re: piority and sound with pushover notifications  [Solved]
Post by mgugu »
First notify parameter should be the topic. Try
domoticz.notify('Domoticz', 'Brandalarm ' .. name .. ' is al ' .. minutes .. ' minuten geleden afgegaan.', domoticz.PRIORITY_EMERGENCY, domoticz.SOUND_ALIEN)
JdoTMM
Post by JdoTMM »
mgugu wrote: Wednesday 05 January 2022 10:46 First notify parameter should be the topic. Try
Thanks mgugu!
That fixed my problem :D
