Doorbell
Posted: Sunday 26 October 2014 21:45
by Brutus
Hi There,
I have added a Fibaro Universal Sensor to Domoticz. Now I have connected my doorbel to it and made some blocky events. This is working al great.
But the Doorbell switch stays Always on :?
When you change the type of switch to "on/off switch" you can add a off command after x seconds.
Why is this not possibe at the doorbell type of switch ? It makes no sence. The doorbell is a puch button so it needs te go off after is has been pushed.
I'm I thinking wrong or is there a other place I need to make some changes.
Thanks for any help.
Greetings Brutus.
Re: Doorbell
Posted: Monday 27 October 2014 19:43
by Brutus
I have made a blocky script that needs to turn off the doorbell switch. This also not work. The Doorbell keeps the status "group on".
So nobody has this same problem?
I have now made it a light switch but this is not normal I think.
Any help would be great.
Greetings Brutus.
Re: Doorbell
Posted: Monday 27 October 2014 20:13
by jackslayter
You can change by on/off Switch and add off delay
Re: Doorbell
Posted: Monday 27 October 2014 20:37
by Brutus
jackslayter wrote:You can change by on/off Switch and add off delay
Thnx for your reply.
Thats what I had done at my previous post. But why is there a doorbell type switch ?
Re: Doorbell
Posted: Wednesday 29 October 2014 12:06
by Brutus
Someone has set this topic as solved...
Is my question solved/answerd then?
To change the switch type from "doorbell" to "on/off" is not a solution for a function that is implemented for a doorbell.
So my question stays unanswerd:
Why does the Doobell type of switch stays on? And why can't we give an option like a normal "on/off" switch to switch it off after x seconds?
I can't find it anywhere.
Greetings Brutus.
Re: Doorbell
Posted: Wednesday 29 October 2014 12:33
by mbliek
Mine doorbell is shown like this.
Re: Doorbell
Posted: Wednesday 29 October 2014 13:06
by Brutus
mbliek wrote:Mine doorbell is shown like this.
Thats what I want to but what is the status of yours? When I have it like that and the doorbell is pressed the status is always on. So when the doorbell is pushed again nothing happens. Then I have to switch back to "on/off" switch and put it off.
Can it have to be related to this option?
Doorbell Command
Doorbell Command
Greetings Brutus.
Re: Doorbell
Posted: Wednesday 29 October 2014 14:28
by markk
Doorbells just work like this I think. I have quite a few PIR's that do the same. They always show on but it isn't really an issue for what I use them for. All I need them to do is report a "device change" and, yes, it will issue the on command every time it is activated, even if it is on already. You are obviously disappointed at the fact your doorbell always shows as "on" but I don't understand what this is preventing you from acheiving!
Re: Doorbell
Posted: Wednesday 29 October 2014 16:48
by Brutus
markk wrote:Doorbells just work like this I think. I have quite a few PIR's that do the same. They always show on but it isn't really an issue for what I use them for. All I need them to do is report a "device change" and, yes, it will issue the on command every time it is activated, even if it is on already. You are obviously disappointed at the fact your doorbell always shows as "on" but I don't understand what this is preventing you from acheiving!
My blocky event isn't going to working if you have a statement that is always on...
Greetings Brutus
Re: Doorbell
Posted: Wednesday 29 October 2014 17:10
by mbliek
Mine doorbell status is also On.
This blocky works for me, using it for a while now:
Re: Doorbell
Posted: Wednesday 29 October 2014 22:13
by Brutus
mbliek wrote:Mine doorbell status is also On.
Thnx Mbliek for your reply.
I have a similar blocky script. I only added a light switch that goes off after 10 seconds.
I have deleted my blocky and made a new one.
I have tested this several times now and it works :? I don't get it ;)
I have changed the blocky script with a "Else If" blocky were i can switch the light off. So for now it al works like I would.
I was wondering what the last line of your blocky does? :oops:
Thnx for the help so far.
Greetings Brutus
Re: Doorbell
Posted: Wednesday 29 October 2014 22:16
by mbliek
Your welcome. That last line is a command to pause my music player based on a raspberry with volumio and a hifiberry. See: http://volumio.org/forum/volumio-audio- ... t1839.html
Re: Doorbell
Posted: Wednesday 29 October 2014 22:23
by Brutus
mbliek wrote:Your welcome. That last line is a command to pause my music player based on a raspberry with volumio and a hifiberry. See: http://volumio.org/forum/volumio-audio- ... t1839.html
That looks Nice!
Thanks.
Greetings Brutus
Re: Doorbell
Posted: Saturday 20 February 2016 21:20
by marcoheijkoop
Thanks for sharing this.
Was looking for this after bying this one https://www.momotica.nl/accessoires/Deu ... ve-Deurbel
Re: Doorbell
Posted: Saturday 29 April 2017 13:26
by edgarhildering
ok, this thread is more than a year old. Well I had the same problem. I solved it by creating new logos for a doorbell Switch...
see attached file. use options Settings -> Custom Icons to upload
Enjoy, --Edgar
Re: Doorbell
Posted: Friday 13 July 2018 8:19
by nizaga
hi! i am having the same issue.
Just to make sure, you need a Switch Type (you can not use the doorbell domoticz device type) and you created new icons, right? you add a delay off to the switch in order to get back to off status, right?
And, what setting did you use for parameter No. 3 -> 3 – INPUT_BISTABLE?
0 – INPUT_NO (Normal Open)
1 – INPUT_NC (Normal Close)
2 – INPUT_MONOSTABLE
3 – INPUT_BISTABLE
Regards,
