trouble installing monit!
Arkie
Post by Arkie »
I'm trying to install monit, but i cannot start it!
pi@domoticzpi ~ $ monit reload
monit: The control file '/etc/monit/monitrc' must be owned by you.
[code#
set httpd port 2812 and
use address 192.168.0.184 # only accept connection from localhost
allow 0.0.0.0/0.0.0.0 # allow localhost to connect to the server and
allow admin:monit # require user 'admin' with password 'monit'
# allow @monit # allow users of group 'monit' to connect (rw)
# allow @users readonly # allow users of group 'users' to connect readonly
][/code]
What am i doing wrong, i first made a ramdisk with the wiki
So i changed "var/log/monit.log" to var/tmp/log/monit.log"
regards
Synology DS412+
Philips Hue
Fibaro
Logitech Hamony elite
Foscam 9804 ip cam
RFXtrx433E USB 433.92MHz
ZXT 120 eu AC controller
Heatmiser NEO stat thermostats and Hub
jackslayter
Domoticz version: stable
Re: trouble installing monit!
Post by jackslayter »
Try with
sudo monit reload
RPi2 + RFLink, Domoticz
Chacon - micromodule 200w, remote 3b, 2x module 1000w, remote 16b, smoke detector, door contact, 2x 3500w plug
Oregon - 3x Thgr122Nx / OWL - CM180 / TRC02_2 RGB / Cheap - PiR, door contact, Temp Hum / 4x REVOLT NC5461
Arkie
Post by Arkie »
ok that works 8-) but now i get the next fault:
monit: Error opening the log file '/var/tmp/log/monit.log' for writing -- No such file or directory
I changed this to the RAM space i made with the wiki :var/tmp or should this be different?
regards
Synology DS412+
Philips Hue
Fibaro
Foscam 9804 ip cam
simonrg
Domoticz version: 3.8807
Post by simonrg »
It looks like the directory /var/tmp/log doesn't exist as monit will create the monit.log files, so either go into /var/tmp and mkdir log or just change occurences of /var/tmp/log/monit.log to /var/tmp/monit.log.
Arkie
Post by Arkie »
thanx for the help it works, very happy :D
Synology DS412+
Philips Hue
Fibaro
Foscam 9804 ip cam
gizmocuz
Post by gizmocuz »
Did you got the email notifications to work ?
I had some trouble with it, can post my config
Arkie
Post by Arkie »
I don't have a gmail account, so did not config it.
When domoticz restarts after a crash i'm glad it restarts, don't have to know it :lol:
regards
Synology DS412+
Philips Hue
Fibaro
Foscam 9804 ip cam
Heisenberg
Post by Heisenberg »
sorry for bringing up this old thread, but I get the same error message. Hope someone can point me into the right direction?
pi@domoticzpi ~ $ sudo monit reload
pi@domoticzpi ~ $ monit status
pi@domoticzpi ~ $
Raspberry Pi Type B
Raspberry Pi Type B2
RFXCOMtrx433e
bizziebis
Domoticz version: 3.8805
Post by bizziebis »
Try
sudo service monit start
LJ80
Post by LJ80 »
Oke trying to install monit because domoticz keeps going offline.
I thought maybe with monit see what happens, because also now we complete new install domoticz goes offline manytimes.
When trying to install monit, after i changed seconds to 300 and madeup ipadress.
In putty I get these messages:
pi@raspberrypi ~ $ monit
pi@raspberrypi ~ $ monit status
pi@raspberrypi ~ $ sudo monit
/etc/monit/monitrc:119: Error: syntax error '192.168.1.55'
pi@raspberrypi ~ $ sudo monit status
pi@raspberrypi ~ $
What am i doing wrong?
LJ80
Post by LJ80 »
who can help me please...
bizziebis
Post by bizziebis »
I think you made a mistake in this part:
set httpd port 2812
use address 12.34.56.789  # only accept connection from localhost
Can you post the part where you put "192.168.1.55" in?
LJ80
Post by LJ80 »
I have now this :
use address localhost 192.168.1.1  # only accept connection from localhost
allow localhost 0.0.0.0/0.0.0.0     # allow localhost to connect to the server and
admin @monit           # allow users of group 'monit' to connect (rw)
And after checking status in putty I get this:
pi@raspberrypi ~ $ sudo service monit start
[ ok ] Starting daemon monitor: monit.
/etc/monit/monitrc:119: Error: syntax error '192.168.1.1'
So i still did not get this work.... :x
Wing
Post by Wing »
try this:
set httpd port 2812
use address 192.168.1.1 			 # only accept connection from localhost
allow localhost 192.168.1.1/255.255.255.0    	 # allow localhost to connect to the server and
# admin @monit           				# allow users of group 'monit' to connect (rw)
Flitske
Post by Flitske »
Hi guys,
Just pulling an old thread out from the attic :)
I'm trying to get Monit to work. Followed the wiki on domoticz but i get to the part of setting up the webserver which doesn't work on my computer.
I'm trying to open the webpage but it doesn't load, i get the "ERR_CONNECTION_REFUSED" message.
So i tried to see if Monit was running and the reply that i got from my command: "Monit status" was "Cannot open the control file '/etc/monit/monitrc' -- Permission denied" Anyone know what i'm doing wrong here??
Tried setting up the permission using: "sudo chmod 777 /etc/monit/monitrc" command. That didn't fix the problem, it only mad it worse because now i got the message "/etc/monit/monitrc:58: syntax error '!'
The control file '/etc/monit/monitrc' must have permissions no more than -rwx------ (0700); right now permissions are -rwxrwxrwx (0777)."
Please help. Thanks in advance
Users browsing this forum: Amazon [Bot] and 1 guest
