Dashticz - v3.8.9 beta
Posted: Thursday 23 December 2021 12:07
by Lokonli
A new Dashticz release with the following functionality:
* Scaling of frame content
- framescale.jpg (48.06 KiB) Viewed 2131 times
Use the new block parameters 'scale2fit' and 'aspectratio' to define the scaling and height adjustment.
* Dials now also support blinds
- dialblinds.jpg (14.49 KiB) Viewed 2131 times
See release notes and documentation via:
https://dashticz.readthedocs.io/en/beta ... 23-12-2021
Re: Dashticz - v3.8.9 beta
Posted: Friday 24 December 2021 10:04
by madpatrick
Hi Lokonli,
Is it possible to make the text size a bit bigger ?
When i try
The dial is meshed up a bit
Also is it possible to make the dial a bit larger
Width 3 is a bit to big and width 2 a bit to small
I'm trying to get 5 dial in 1 row
And is it possible to add Title to the Selector dial?
- Dial.png (25.45 KiB) Viewed 2082 times
Something like this ?
Posted: Monday 27 December 2021 13:21
by epost
I have updated from version 3.8.7 to version 3.8.9
As a result, the decimals have changed and the comma has become a period.
How can I change this back to the old format?
Posted: Monday 27 December 2021 20:18
by Krenstik
use a : decimals: 1, id dial text.....
Posted: Tuesday 28 December 2021 12:11
by Lokonli
madpatrick wrote: Friday 24 December 2021 10:04
Hi Lokonli,
When i try
I've made a little update.
Now you can change the up/down text size via:
.up .text, .down .text {
font-size: 200%
Posted: Tuesday 28 December 2021 12:21
by madpatrick
Thanks.
It is working on my PC screen, but on my tablet is remains unchanged
font-size: 40px !important
Is it possible to adjust the text in the middle also
Posted: Tuesday 28 December 2021 12:57
by epost
Hi Lokonli,
Do you also have a solution for the Gas dial.
Decimals: 1 doesn't work here.
blocks['Gasmeter'] = {
idx: 464,
title: 'Gas',
type: 'dial',
values: [{value:'Counter', decimals: 0, unit:' m3'}],
setpoint: 5,
min: 0,
max: 10,
width: 6,
shownumbers: true,
showring: true,
animation: false,
showunit:true
Posted: Tuesday 28 December 2021 13:44
by Lokonli
madpatrick wrote: Tuesday 28 December 2021 12:21
Thanks.
It works on my tables (android and iOS). Can it be that the screen resolution is relatively high? Then probably the 40px may still be rather small.
Try with relative size:
To change all the font sizes in a blinds button:
This probably is a bit too big for a two line middle row. You could add:
Posted: Tuesday 28 December 2021 14:26
by Lokonli
epost wrote: Tuesday 28 December 2021 12:57
Hi Lokonli,
idx: 464,
title: 'Gas',
type: 'dial',
setpoint: 5,
min: 0,
max: 10,
width: 6,
shownumbers: true,
showring: true,
animation: false,
showunit:true
I've made a small fix. Update Dashticz with 'git pull'.
The following will work:
idx: 464,
title: 'Gas',
type: 'dial',
setpoint: 5,
min: 0,
max: 10,
width: 6,
shownumbers: true,
showring: true,
animation: false,
showunit:true,
decimals: 1
Posted: Tuesday 28 December 2021 14:41
by madpatrick
Lokonli wrote: Tuesday 28 December 2021 13:44
Thanks.
Now it is working !
The resulotion of the tablet is 1280x800. but i think the 8" is a bit small for my eyes......
Do you think it is possible to add a title to the selector dials?
That would make it perfect for me.
Posted: Tuesday 28 December 2021 15:56
by epost
Hi Lokonli,
The Gas dial now works as before.
Thank You very much
I have another item that changed after the update.
The decimal comma has been replaced by a period
blocks['zolder'] = {
idx: 510,
title: 'Zolder',
type: 'dial',
setpoint: 20,
min: 5,
max: 45,
width: 6,
shownumbers: true,
showring: true,
showunit: true,
last_update: true,
animation: false
Posted: Tuesday 28 December 2021 19:41
by Lokonli
epost wrote: Tuesday 28 December 2021 15:56
Hi Lokonli,
Thank You very much
idx: 510,
title: 'Zolder',
type: 'dial',
setpoint: 20,
min: 5,
max: 45,
width: 6,
shownumbers: true,
showring: true,
showunit: true,
last_update: true,
animation: false
Should work again with latest beta.
Posted: Tuesday 28 December 2021 20:30
by epost
Lokonli,
The decimal comma works perfectly
Thank You very much
Posted: Wednesday 29 December 2021 9:33
by besix
Welcome
I want to add the "usage" value from such a device to a regular switch
Json
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"BatteryLevel" : 255,
"CounterToday" : "0 kWh",
"CustomImage" : 0,
"Data" : "0.020 kWh",
"Description" : "",
"EnergyMeterMode" : "0",
"Favorite" : 0,
"HardwareDisabled" : false,
"HardwareID" : 6,
"HardwareName" : "Shelly",
"HardwareType" : "Shelly MQTT",
"HardwareTypeVal" : 94,
"HaveTimeout" : false,
"ID" : "shelly1pm-84CCA8ACB7B8-0-energy",
"LastUpdate" : "2021-12-28 15:18:07",
"Name" : "Pompa Pob\u00f3r",
"Notifications" : "false",
"PlanID" : "2",
"PlanIDs" :
2
"Protected" : false,
"ShowNotifications" : true,
"SignalLevel" : "-",
"SubType" : "kWh",
"SwitchTypeVal" : 0,
"Timers" : "false",
"Type" : "General",
"TypeImg" : "current",
"Unit" : 4,
"Usage" : "0 Watt",
"Used" : 1,
"XOffset" : "363",
"YOffset" : "503",
"idx" : "15"
How to do it with this example ?
blocks['sw1'] = {
idx: 1056,
type:'dial',
values: [
idx: 1057,
isNeedle: true
width: 6,
showring: true,
shownumbers: true,
min: 0,
max: 10
The switch has an idx of 12 and Shelly from Usage has an idx of 15
How do I put idx 15 in values [
gives me "DATE"
Posted: Wednesday 29 December 2021 10:37
by Lokonli
I would expect by adding the value parameter and setting idx correctly, like:
values: [
idx: 15,
isNeedle: true,
value: 'Usage'
Posted: Wednesday 29 December 2021 11:49
by besix
Perfectly
Thank you very much
Posted: Wednesday 29 December 2021 13:50
by madpatrick
Hi Lokonli,
Another question (sorry for the many questions)
When I push 1 dial on or off the test will dissapear.
Same when i test it on my pc wih the mouse, but then i will come back if the mouse the not on the dial
What can this be ?
This is my custom.css for these dials
.dial-center .value {color: white !important;font-size: 130% !important;}
.dial .device {font-size: 14px;padding-top: 10px !important}
and i used in config.js
to remove the icon due to limited space on my small tablet
