Cancel action in dzvents script
JeroenG
Domoticz version: 20231
Post by JeroenG »
I have several lights which switch on in the morning on workingdays (mon-Fri) on specific times (i.e. hallway switches om at 06:10).
But sometimes I take a day off, and there is no reason why these ligth should be switched on (I hope to be stll in bed :) ).
My idea was to create a dummy switch (no_working_day) which I switch on before going to bed. But how can I use such to cancel the timed switchon event (which is on lightswitch in domoticz, no script)?
Any idea's?
Jeroen
user4563
Domoticz version: 2025.2
Re: Cancel action in dzvents script
Post by user4563 »
Yes, that will work. So basically if dummy switch state == off then <your existing schedule here>
If the dummy switch is on, then nothing happens.
However, you said the schedule is not in a script. If it's in Blockly, you can do the same there using If-Do logic.
Aeotec Z-Stick Gen5+
ZWave-JS-UI / Mosquitto MQTT
Domoticz for Android
