Error Device created after MQTT AD
McMelloW
Domoticz version: V2024.1
Post by McMelloW »
Raspberry Pi 3B+ Buster
Domoticz build 13949
Shelly 2.5 flashed with Tasmota v10.1.0
After Auto creation of the Device, the following errors
2021-12-18 18:48:08.096 Error: MQTT: Unhandled state received '{"Time":"2021-12-18T18:48:08","Uptime":"0T01:04:38","UptimeSec":3878,"Heap":27,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":1,"POWER1":"OFF","POWER2":"OFF","Wifi":{"AP":1,"SSId":"MyNetwork","BSSId":"28:FF:3E:1A:53:CB","Channel":6,"Mode":"11n","RSSI":78,"Signal":-61,"LinkCount":1,"Downtime":"0T00:00:03"}}' (692E91_SHT_1/Shelly-01U)
2021-12-18 18:48:08.220 Error: MQTT: Exception: in Json::Value::resolveReference(key, end): requires objectValue!
2021-12-18 18:48:08.221 Error: MQTT: Exception: in Json::Value::resolveReference(key, end): requires objectValue!
2021-12-18 18:48:08.222 Error: MQTT: Exception: in Json::Value::resolveReference(key, end): requires objectValue!
2021-12-18 18:48:08.245 Error: MQTT: Exception: in Json::Value::resolveReference(key, end): requires objectValue!
2021-12-18 18:48:08.246 Error: MQTT: Exception: in Json::Value::resolveReference(key, end): requires objectValue!
Anybody a clue where this comes from and how to handle this?
Greetings McMelloW
jvdz
Domoticz version: 4.107
Re: Error Device created after MQTT AD
Post by jvdz »
The First one will be fixed in the next version. Is that an TASMOTA device?
For the other errors we will need the offending MQTT TOPIC and PAYLOAD messages to be able to check what is happening. In case they aren't CONFIG topic, we also likely need the CONFIG MQTT message for the offending device.
Jos
McMelloW
Post by McMelloW »
jvdz wrote: Saturday 18 December 2021 20:25 The First one will be fixed in the next version. Is that an TASMOTA device?
Jos
Thanks for your reply.
Yes it is a Shelly 2.5 flashed with Tasmota v10.1.0 - Domoticz is at build 13949.
The Shelly is the first device created with auto detection after (Setoption19 1) on the Tasmota console. At this moment only this error message every 5-6 min.
2021-12-18 21:03:08.326 Error: MQTT: Unhandled state received '{"Time":"2021-12-18T21:03:08","Uptime":"0T03:19:38","UptimeSec":11978,"Heap":27,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":1,"POWER1":"OFF","POWER2":"OFF","Wifi":{"AP":1,"SSId":"VGV751954873C","BSSId":"28:FF:3E:1A:53:CB","Channel":6,"Mode":"11n","RSSI":74,"Signal":-63,"LinkCount":1,"Downtime":"0T00:00:03"}}' (692E91_SHT_1/Shelly-01U)
In which next version will this be fixed? Domoticz or Tasmota
Greetings McMelloW
jvdz
Post by jvdz »
Yes the "Unhandled state received" error from TASMOTA will soon (probably in a couple of days) be fixed. Just need to finish the 3 line mod and make a PR. :)
..But what about the other errors you get? I do not recognize them.
McMelloW
Post by McMelloW »
jvdz wrote: Saturday 18 December 2021 22:01 Yes the "Unhandled state received" error from TASMOTA will soon (probably in a couple of days) be fixed. Just need to finish the 3 line mod and make a PR. :)
OK, I will watch Tasmota for the update.
The other messages were gone when did a (setoption19 0) on the device. Set it again to 1 the messages appear again.
Greetings McMelloW
jvdz
Post by jvdz »
PR is made for issue #5072 .
McMelloW
Post by McMelloW »
jvdz wrote: Saturday 18 December 2021 23:45 PR is made for issue #5072 .
Thanks, disabled debug in the MQTT hardware to avoid all the extra messages.
Greetings McMelloW
McMelloW
Post by McMelloW »
jvdz wrote: Saturday 18 December 2021 23:45 PR is made for issue #5072.
Hi jvdz, I see PR #5072 is gone or done. But when this will be available in a compiled version?
Greetings McMelloW
jvdz
Post by jvdz »
I don't know as that only happens when @gizmocuz pushes the right buttons... :-)
McMelloW
Post by McMelloW »
Hallo Jos,
At this moment I am on build 14052. When I change the loglevel of the MQTT Auto Discovery Client Gateway with LAN interface enabled Error the following error messages still appear again. Disabling Error in the loglevel stops this messages.
2022-01-15 12:06:36.773 Error: MQTT: Exception: in Json::Value::resolveReference(key, end): requires objectValue!
2022-01-15 12:06:36.774 Error: MQTT: Exception: in Json::Value::resolveReference(key, end): requires objectValue!
2022-01-15 12:06:56.678 Error: MQTT: Exception: in Json::Value::resolveReference(key, end): requires objectValue!
2022-01-15 12:06:56.679 Error: MQTT: Exception: in Json::Value::resolveReference(key, end): requires objectValue!
I am not sure, but I guess after split og MQTT and MQTT AD hardware the PR #5072 is not done on both hardware objects. Any clue or solution.
Greetings McMelloW
gizmocuz
Post by gizmocuz »
@McMellowW Please do not cross post on the forum and github, use either of the two
Lets continue on github
McMelloW
Post by McMelloW »
gizmocuz wrote: Saturday 15 January 2022 12:52 @McMellowW Please do not cross post on the forum and github, use either of the two
OK, I will
Greetings McMelloW
