How read Sonos data every minute
Johan1974
Post by Johan1974 »
How can I read the status of my sonos every minute in a dzvents script, and make the values ​​visible in a switch.?
I read the data from the sonos with 'http://192.168.1.21:5005/state' and get the following data:
{"volume":15,"mute":false,"equalizer":{"bass":0,"treble":4,"loudness":true,"speechEnhancement":false,"nightMode":false},"currentTrack":{"artist":"Radio 10","title":"Rod Stewart - Da Ya Think I'm Sexy","albumArtUri":"/getaa?s=1&u=x-sonosapi-stream%3atunein%253a7073%3fsid%3d303%26flags%3d8224%26sn%3d1","duration":0,"uri":"x-sonosapi-stream:tunein%3a7073?sid=303&flags=8224&sn=1","trackUri":"x-sonosapi-stream:tunein%3a7073?sid=303&flags=8224&sn=1","type":"radio","stationName":"Radio 10","absoluteAlbumArtUri":"http://192.168.1.156:1400/getaa?s=1&u=x-sonosapi-stream%3atunein%253a7073%3fsid%3d303%26flags%3d8224%26sn%3d1"},"nextTrack":{"artist":"","title":"","album":"","albumArtUri":"","duration":0,"uri":""},"trackNo":1,"elapsedTime":259,"elapsedTimeFormatted":"00:04:19","playbackState":"PLAYING","playMode":{"repeat":"none","shuffle":false,"crossfade":false},"sub":{"gain":-4,"crossover":0,"polarity":0,"enabled":true}}
And for example, if then stationName = "Radio 10" the dummy selector with the name "Station" is set to 20
Domoticz version: 2025.1
Re: How read Sonos data every minute
Why would you like to have it in a switch? Is a text sensor not easier to handle? Just put the info in text and ready...
There is a Sonos Python plugin (no longer maintained) but should still work. I am not sure it does what you want.
viewtopic.php?f=65&t=18710
To put the text into a text sensor use the following script:
		timer = {
			'every minute' -- just an example to trigger the request
		httpResponses = {
			'Sonostrigger' -- must match with the callback passed to the openURL command
	logging = {
		level = domoticz.LOG_INFO,
		marker = 'template',
		if (item.isTimer) then
			domoticz.openURL({
				url = 'http://192.168.1.21:5005/state',
				method = 'GET',
				callback = 'Sonostrigger', -- see httpResponses above.
		if (item.isHTTPResponse) then
			if (item.ok) then
				if (item.isJSON) then
                    -- local Testdata = '{"volume":15,"mute":false,"equalizer":{"bass":0,"treble":4,"loudness":true,"speechEnhancement":false,"nightMode":false},"currentTrack":{"artist":"Radio 10","title":"Rod Stewart - Da Ya Think Im Sexy","albumArtUri":"/getaa?s=1&u=x-sonosapi-stream%3atunein%253a7073%3fsid%3d303%26flags%3d8224%26sn%3d1","duration":0,"uri":"x-sonosapi-stream:tunein%3a7073?sid=303&flags=8224&sn=1","trackUri":"x-sonosapi-stream:tunein%3a7073?sid=303&flags=8224&sn=1","type":"radio","stationName":"Radio 10","absoluteAlbumArtUri":"http://192.168.1.156:1400/getaa?s=1&u=x-sonosapi-stream%3atunein%253a7073%3fsid%3d303%26flags%3d8224%26sn%3d1"},"nextTrack":{"artist":"","title":"","album":"","albumArtUri":"","duration":0,"uri":""},"trackNo":1,"elapsedTime":259,"elapsedTimeFormatted":"00:04:19","playbackState":"PLAYING","playMode":{"repeat":"none","shuffle":false,"crossfade":false},"sub":{"gain":-4,"crossover":0,"polarity":0,"enabled":true}}'
					-- local rt        = domoticz.utils.fromJSON(Testdata)
					-- local someValue = rt.currentTrack.artist  -- just an example
					local someValue = item.json.currentTrack.stationName
					-- update some device in Domoticz
					domoticz.devices('MyTextDevice').updateText(someValue)
					domoticz.log('Text: ' .. someValue , domoticz.LOG_INFO)
				domoticz.log('There was a problem handling the request', domoticz.LOG_ERROR)
				domoticz.log(item, domoticz.LOG_ERROR)
Johan1974
Post by Johan1974 »
I made a Text dummy called 'SonosTest'
The text that becomes visible in the dummy is "nil" and not the value of the volume..
 				domoticz.devices('SonosTest').updateText(volume)
You cannot put volume directly in the update string
You have to read it first from the Json
Eg
local someValue = item.json.volume
Johan1974
Post by Johan1974 »
I changed everything, but I still get the text 'nil' in the dummy.
		timer = {
		httpResponses = {
	logging = {
			domoticz.openURL({
				method = 'GET',
			if (item.ok) then
Change line
Into
domoticz.devices('SonosTest').updateText(someValue)
