dimto transition time
barts2108
Post by barts2108 »
I recently included Ikea tradfri 30W driver for my working area in the kitchen, together with a matching on/off/dimmer button.
Light and button are paired with my conbee II on a raspberry pi, running beta channel of domoticz.
The driver has configurable option for transition time
0x0010 OnOff Transition Time u16 rw 10
When I change it to 100, and use the tradfri button, the dimming to 100% takes 10 seconds.
When I do a dimTo(100) from the dzVents scripting, the light reaches 100% within 1 second or so.
How can I change the transition time of the dimTo() command ?
Re: dimto transition time
This looks more a plugin issue then dzVents.
What happens if you set the dimlevel from 0 to 100 from the Domoticz User interface with the device widget?
barts2108
Post by barts2108 »
If I set the dimlevel from the Domoticz UI it also dims fast (looks like the same speed as the dimTo() )
Ok, than talk to the deconz plugin owner, perhaps he has an idea how to do this as dzVents sends the same command to your light as the UI widget.
https://domoticz.com/forum/viewtopic.php?f=68&t=25631
barts2108
Post by barts2108 »
Ok I will... if I get usefull info will feedback here.
jake
Post by jake »
In the zigbee2mqtt panel you can adjust the time to dim from one setpoint to another. Seems to work well
Maxx
Post by Maxx »
You can use the Hue API direct:
Put this script in global_data (use your Key):
    hue_colors_P = function(domoticz,status,bri_out,hue_out,sat_out,device,transition)
                        domoticz.log('Send switch command ')
                        local bridge = '192.168.1.161'
                        local tempUrl = 'http://'..bridge..'/api/xigTvboK2fVo6ld4sYXyp4gUzDLNKIXpUViF/lights/'.. device .. '/state'
                        local data = {on = status, bri = bri_out, hue = hue_out, sat = sat_out, transitiontime = transition}
			            domoticz.openURL({
				        url = tempUrl,
				        method = 'PUT',
				        callback = device,
				        postData = data
                    end,
barts2108
Post by barts2108 »
As far as i know i do not have zigbee2mqtt nor a hue bridge.
But i can check if the rest api for the tradfri driver accepts the json
barts2108
Post by barts2108 »
As expected : Tradfri does not accept any settings for hue bridge.
steeringwheel
Post by steeringwheel »
Stumbled upon this topic as I needed something similar. Ended up simulating a transition. Not as smooth as it could be as the steps go down 1 percent at a time. Script is attached as I'm getting the following error message when using 'code' tags:
You can’t post image, email or url links that are external to this domain. Please remove os., os., dz., dz., item., item., dz., item., dz., dz., dz., dz., dz. and dz.
dimmerTransition.txt
(1.3 KiB) Downloaded 135 times
steeringwheel
A better one if subsecond dim steps are not needed.
(1.3 KiB) Downloaded 98 times
To be complete a lot of zigbee platforms like Zigbee2MQTT and zigbee4Domoticz support zigbee settings for transition times for dimlevels and/or color changes. So look into your gateway settings first (not controlled by Domoticz). This solution is also more stable than using Domoticz to steer this.
