Domoticz crashing constantly
bernard038
Post by bernard038 »
Hello All,
As of this afternoon Domoticz is crashing evert few minutes. I am using a Raspberry Pi with Buster installed. In the crashlog I've found these lines:
Thread 28 (Thread 0xaa8f9220 (LWP 13078)):
#0  __waitpid (options=0, stat_loc=0xaa8f7fc8, pid=13939) at ../sysdeps/unix/sysv/linux/waitpid.c:30
#1  __waitpid (pid=13939, stat_loc=0xaa8f7fc8, options=0) at ../sysdeps/unix/sysv/linux/waitpid.c:25
#2  0x0028b14c in dumpstack_gdb(bool) ()
#3  0x0028b718 in signal_handler(int, siginfo_t*, void*) ()
#4  <signal handler called>
#5  raise (sig=11) at ../sysdeps/unix/sysv/linux/raise.c:50
#6  <signal handler called>
#7  0xb5d74724 in ?? () from /usr/lib/arm-linux-gnueabihf/libpython3.7m.so
#8  0xb5d74714 in ?? () from /usr/lib/arm-linux-gnueabihf/libpython3.7m.so
Backtrace stopped: previous frame identical to this frame (corrupt stack?)
Does anyone know how to solve this issue?
Re: Domoticz crashing constantly
This is not enough information, what is thread 28? It is in the top of the crash log.
Perhaps it is related to your earlier corrupt database issue.. viewtopic.php?f=6&t=37458&p=282810#p282810
Could also be a faulty power supply or SD card....
bernard038
Maybe it is / was the database being corrupted. However I had fixed the issue earlier. Restored domoticz.db, removed some plugins generating errors, and now lets seen what happens in the coming days..
