Zigate with Tuya 4 in 1 Sensor : PIR - Temperature - Humidity- Light
Posted: Thursday 25 November 2021 14:50
Hello dears Domo-Zigater, Dear Pipiche,
I have a sensor with PIR + temperature humidity light and I managed to pair it with the Zigate :
Zigate reports it as "TS0202"
The 4 in 1 sensor exist under different name :
Tuya ZigBee – multi-capteur 4-in-1 PIR motion temperature : https://fr.aliexpress.com/item/1005001878974427.html
But also a CE version :
IMMAX NEO SMART MOTION SENSOR 4IN1 ZIGBEE 3.0
https://www.immax.cz/media/186/07502l-p ... QwNUZfMTg2
With the zigate is seems only 2 clusters are found : Motion and Tamper, I don't see Temperature, Humidity, and Lux
TS0202
ZG2 - TS0202_Motion-14b457fffe0e47fa-01
ZG2 - TS0202_Tamper-14b457fffe0e47fa-01
My zigate hardware version is ZiGate+ (v2)
Domoticz Zigate Plugin: 5.1.009
Firmware: 0320
The device in Zigate JSON :
20 :
Battery : 100
ConsistencyCheck : ""
Health : "Live"
IEEE : "14b457fffe0e4c35"
LQI : 50
MacCapa : Array[2] ["RFD","Battery"]
Model : "TS0202"
Param : "{}"
Status : "inDB"
WidgetList : Array[2] ["ZG2 - TS0202_Motion-coude1","ZG2 - TS0202_Tamper-14b457fffe0e4c35-01"]
ZDeviceName : ""
_NwkId : "b33e"
Version : "3"
ZDeviceName : ""
Status : "inDB"
SQN : "08"
Heartbeat : "1178"
RIA : "0"
LQI : 52
Battery : 100
Model : "TS0202"
ForceAckCommands : Array[0] []
MacCapa : "80"
Type : "Motion/Tamper"
ProfileID : "0104"
ZDeviceID : "0106"
App Version : ""
Attributes List : Object {}
DeviceType : "RFD"
HW Version : ""
Last Cmds : Array[10] [[125346,"02","d6f6","0100","0101000000000000010004"],[125347,"02","d6f6","0100","0101000000000000010005"],["None","02","d6f6","0100","0101000000000000010004"],["None","02","d6f6","0100","0101000000000000010005"],["None","02","d6f6","0100","0101000000000000010004"],["None","02","d6f6","0100","0101000000000000010005"],[125409,"02","d6f6","0100","0101000000000000010004"],[125410,"02","d6f6","0100","0101000000000000010005"],[125435,"02","99cb","0100","0101000000000000010004"],[125436,"02","99cb","0100","0101000000000000010005"]]
LogicalType : "End Device"
Manufacturer : ""
Manufacturer Name : "_TZ3210_jijr1sss"
NbEp : "3"
PowerSource : "Battery"
ReadAttributes : Object {"Ep":{"01":{"0000":{"TimeStamp":"25/11/2021 13:08:38","iSQN":{"0004":125435,"0005":125436},"Attributes":{"0004":"00","0005":"00"},"ZigateRequest":{}},"0001":{"TimeStamp":"25/11/2021 13:03:34","iSQN":{"0020":125344,"0021":125345},"Attributes":{"0020":"00","0021":"00"},"ZigateRequest":{}},"0500":{"TimeStamp":"25/11/2021 13:08:40","iSQN":{},"Attributes":{"0000":"00","0010":"00"},"ZigateRequest":{}}},"02":{"0000":{"TimeStamp":"25/11/2021 13:03:21","iSQN":{"0004":125330,"0005":125333},"Attributes":{"0004":"86","0005":"86"},"ZigateRequest":{}}},"03":{"0000":{"TimeStamp":"25/11/2021 13:03:23","iSQN":{"0004":125331,"0005":125334},"Attributes":{"0004":"86","0005":"86"},"ZigateRequest":{}},"0400":{"TimeStamp":"25/11/2021 14:45:28","iSQN":{},"Attributes":{"0000":"00"},"ZigateRequest":{}}}}}
ReceiveOnIdle : ""
Stack Version : ""
Stamp : Object {"time":1637847968.6929162,"Time":"2021-11-25 14:46:08","MsgType":"8011","LastSeen":"25/11/2021 14:46:08"}
ZCL Version : ""
Health : "Live"
Capability : Array[3] ["Reduced-Function Device","Standard security","NwkAddr should be allocated"]
RollingLQI : Array[11] [52,52,52,52,52,53,53,52,52,52,52]
Epv2 : Object {"01":{"ClusterIn":{"0000":{},"0001":{},"0500":{},"ef00":{}},"ClusterOut":{"0019":{},"000a":{}},"ProfileID":"0104","ZDeviceID":"0402"},"02":{"ClusterIn":{"0001":{},"0402":{},"0405":{}},"ClusterOut":{},"ProfileID":"0104","ZDeviceID":"0302"},"03":{"ClusterIn":{"0001":{},"0400":{}},"ClusterOut":{},"ProfileID":"0104","ZDeviceID":"0106"}}
PairingInProgress : false
SQN_000a : "07"
ConfigSource : "DeviceConf"
Ep : Object {"01":{"0000":{"0004":"_TZ3210_jijr1sss","0005":"TS0202"},"0001":{"0020":30,"0021":200},"0500":{"0002":"alarm1: 0, alaram2: 0, tamper: 0, battery: 0, Support Reporting: 0, restore Reporting: 0, trouble: 0, acmain: 0, test: 0, battdef: 0","0000":"01","0010":"00158d0005007208"},"Type":"Motion/Tamper","ClusterType":{"321":"Motion","322":"Tamper"},"0006":{"0000":"Cmd: 00, 02"}},"02":{"0000":{}},"03":{"0000":{},"0400":{"0000":57}}}
IASBattery : 100
ZDeviceVersion : "0001"
BatteryUpdateTime : "25/11/2021 13:03:33"
WriteAttributes : Object {"Ep":{"01":{"0000":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"0001":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"0500":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"0006":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}}},"02":{"0000":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}}},"03":{"0000":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"0400":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}}}}}
IAS : Object {"01":{"EnrolledStatus":1,"ZoneType":{},"ZoneTypeName":{},"ZoneStatus":{}}}
Max Buffer Size : "52"
Max Rx : "0052"
Max Tx : "0052"
Bind : Object {"01":{"0001":{"Target":"0000","Stamp":"25/11/2021 13:08:35","Phase":"binded","Status":"00","i_sqn":125433},"0500":{"Target":"0000","Stamp":"25/11/2021 13:08:36","Phase":"binded","Status":"00","i_sqn":125434}}}
NwkID : "b33e"
I found this in the log : ZG2 is my Zigate
2021-11-25 14:31:51.054 ZG2: (ZG2) inRawAps b33e/01 Cluster ef00 Manuf: /_TZ3210_jijr1sss Command: 06 Data: 00006b02000400000101 Payload:
19030600006b02000400000101 not processed !!!
2021-11-25 14:31:51.189 ZG2: (ZG2) UpdateDevice - (ZG2 - TS0202_Motion-coude1) 1:On
2021-11-25 14:31:51.201 ZG2: (ZG2) UpdateDevice - (ZG2 - TS0202_Tamper-14b457fffe0e4c35-01) 0:No Alert
2021-11-25 14:31:51.311 ZG2: (ZG2) inRawAps b33e/01 Cluster ef00 Manuf: /_TZ3210_jijr1sss Command: 06 Data: 00006c0200040000004a Payload:
19040600006c0200040000004a not processed !!!
2021-11-25 14:32:24.162 ZG2: (ZG2) Last update of the devices 201 Motion was 31.098698139190674 ago
2021-11-25 14:32:32.921 ZG2: (ZG2) UpdateDevice - (ZG2 - TS0202_Motion-coude1) 0:Off
2021-11-25 14:32:33.225 ZG2: (ZG2) Decode8095 - SQN: 09, Addr: b33e, Ep: 01, Cluster: 0006, Cmd: 00, Unknown: 02
2021-11-25 14:33:00.108 ZG2: (ZG2) UpdateDevice - (ZG2 - TS0202_Motion-14b457fffe0e47fa-01) 0:Off
2021-11-25 14:33:01.508 ZG2: (ZG2) inRawAps 0785/01 Cluster ef00 Manuf: /_TZ3210_jijr1sss Command: 06 Data: 00006e02000400000064 Payload:
19760600006e02000400000064 not processed !!!
2021-11-25 14:33:03.931 ZG2: (ZG2) inRawAps 0785/01 Cluster ef00 Manuf: /_TZ3210_jijr1sss Command: 06 Data: 00006b020004000000d3 Payload:
19780600006b020004000000d3 not processed !!!
2021-11-25 14:33:05.130 ZG2: (ZG2) inRawAps 0785/01 Cluster ef00 Manuf: /_TZ3210_jijr1sss Command: 06 Data: 00006c02000400000033 Payload:
19790600006c02000400000033 not processed !!!
Is there something I can do to have the temperature humidty etc ... ?
Thank you very much to your help,
TS0202
Firmware: 0320
20 :
Battery : 100
Health : "Live"
LQI : 50
Model : "TS0202"
Param : "{}"
Status : "inDB"
ZDeviceName : ""
_NwkId : "b33e"
Version : "3"
ZDeviceName : ""
Status : "inDB"
SQN : "08"
Heartbeat : "1178"
RIA : "0"
LQI : 52
Battery : 100
Model : "TS0202"
MacCapa : "80"
ProfileID : "0104"
ZDeviceID : "0106"
App Version : ""
DeviceType : "RFD"
HW Version : ""
Manufacturer : ""
NbEp : "3"
ReceiveOnIdle : ""
Stack Version : ""
ZCL Version : ""
Health : "Live"
SQN_000a : "07"
IASBattery : 100
Max Rx : "0052"
Max Tx : "0052"
NwkID : "b33e"
