Global or local variable
Bobbie
Post by Bobbie »
Standard is a variable a global variable. But when I call a variable in a "If then" Statement the variable is NIL. Outside the actual "If then" statement I declare the variable x.
How to use a variable in the whole program and not only in the "If then"statement?.
example to determine the variable x
	if  (devicechanged['RemoteWK2'] == "Off")  then
	    print(' Switch is Off')
	    x = 1
	    print(' X = : '  .. x .. ' ');
	if  (devicechanged['RemoteWK2'] == "On")  then
	     print('Switch is On')
print(x)
Error code in log: Error: EventSystem: in test-lua: [string "commandArray = {}..."]:12: attempt to concatenate a nil value (global 'x')
Thx
Last edited by Bobbie on Wednesday 17 November 2021 17:03, edited 1 time in total.
jannl
Domoticz version: 2026.1.x
Re: Global or local variable
Post by jannl »
Don't you give the answer yourselves?
Declare the variable before the first if-statement.
Bobbie
Post by Bobbie »
Thanks for your reply.
I give the variable "1"when the switch is pressed Off ( in the first IF-THEN).
In the second IF-THEN, I call the variable X when the switch is pressed On. --> The error comes with NIL..
Of course I can start before the first IF-THEN with x = 0.
But When x become 1 in the first IF-THEN, after the loop at the end x = 0 again. There is no error.. but x = always 0 now..
I want to see de value of x in the second IF-THEN when I press the On button..
The program is just a sample for testing.
Last edited by Bobbie on Wednesday 17 November 2021 12:45, edited 1 time in total.
jannl
Post by jannl »
In lua:
local x
To declare a variable without giving a value. I would suggest to give a value though.
Jan
