Edit switch activates device?
Posted: Monday 08 November 2021 10:38
by sciurius
I have a witch device (lamp) with two timers.
- scrot20211108103244.png (15.13 KiB) Viewed 664 times
When I click on the first timer, e.g. to change it, the lamp immedeately switches on. One minute later, another "on" event is generated.
- scrot20211108103729.png (7.33 KiB) Viewed 664 times
Strangely, when I click on the second timer, no "off" events are generated.
Is this normal behaviour?
Re: Edit switch activates device?
Posted: Monday 08 November 2021 11:25
by sammyke007
I can confirm this. When editing timers with an ON command, the light turns on after clicking the rule.
Posted: Monday 08 November 2021 22:34
by sciurius
Do you also get the second 'ON' after 64 seconds?
Posted: Tuesday 09 November 2021 8:45
by sciurius
Worse: The 'off' function of the timer doesn't seem to work at all. The lamp switches on as instructed but the off timer never goes off.
I can switch the lamp off (and on) from the widget on the 'Switches' panel without problems.
The lamp is connected via the Tuya plugin.
Posted: Monday 15 November 2021 19:18
by sciurius
The last couple of days the 'off' timer has worked properly so there may be something else going on. Small disruptions in connectivity, maybe.
Posted: Monday 15 November 2021 20:11
by user4563
Just to add, I am on the same v 2021.1 but on Windows not RPi and couldn't recreate this.
Posted: Monday 15 November 2021 20:56
Could be feedback of MQTT or python plugin.
