How to change AddDBLogEntry parameter on existing counters?
andrehj
Domoticz version: 2026.4
Post by andrehj »
I intend to add yesterdays data to the P1 smart meter counter via a bash script.
Problem is that I have to set the AddDBLogEntry parameter to true to do that.
According to the manual I have to do that via a python plugin, as follows:
Domoticz.Device(Name="MyCounter", Unit=1, Type=0xfa, Subtype=0x01, Options={"AddDBLogEntry" : "true").Create()
But I think that line creates a new device (not a big problem, but how do I prevent creating this device over and over?), and I haven't got a clue what I have to fill in for Type and Subtype.
And what what would a minimum plugin look like that only contains the line above?
Ideal would be an easier way to set this AddDBLogEntry parameter...
Thanks in advance for any help.
breizhcat
Re: How to change AddDBLogEntry parameter on existing counters?
Post by breizhcat »
Hello
You can try to use API/Json provide by Domoticz.
https://www.domoticz.com/wiki/Domoticz_ ... mart_meter
You have to provide device Id and values. Then no device will be created and the current device will be updated.
BR
andrehj
Post by andrehj »
Thanks, but that gives me two problems:
1. The counter only goes up. So if yesterday's value was 10 kWh, and today's value is 11 kWh, today's value will show as 1 kWh in Domoticz
2. The values come from a different system, which only calculates them after midnight. And when I enter them via the default json call (without a date), they will be assigned to the wrong date (one day later).
Both problems can be solved if I can use the method which lets me enter the historic data in the database, with the right date attached. However, to be able to do that I have to set the AddDBLogEntry parameter to true... But how?
breizhcat
Post by breizhcat »
AFAIK AddDBLogEntry option is avaible only when you create your own plugin and your devices. Once it's created you juste have to manage data.
Another way to achieve this maybe: Update the domoticz.db file with sql statement. You won't be tied to the device and free to add any kind of entries. But, yes there is a but, you have to be sure about your data because you will be working directly on the database.
