Publish MQTT Dzvents
Cdzn
Post by Cdzn »
Hi. I have this script
	    devices = {
            'Переключатель котла'
	   timer =
		   {'every minute'}
	logging = { level = domoticz.LOG_DEBUG },
	execute = function(dz,item,device)
	local function sendMQTT(message, topic)
            local MQTTTopic = topic or 'domoticz/out'
            osCommand ( 'mosquitto_pub  -u Cdzn -P Qq123e9 ' ..  ' -t '  .. MQTTTopic .. " -m '" .. message .. "'")
    if item.isTimer then
    if (device.name == 'Переключатель котла' and device.active) then
        local myTopic = 'domoticz/out/' .. dz.devices('Переключатель котла').idx
            sendMQTT(myMessage, myTopic)
It should check if boiler switch is 'on' in domoticz and in espEasy is 'off' it should send 'On' command periodically. How to make it works? )
The reason is why i should do it, coz tonight boiler switch on and esp lost mqtt connection at the same time, so the command did not pass and i freeze(
Cdzn
Re: Publish MQTT Dzvents
Post by Cdzn »
Cdzn wrote: Tuesday 02 November 2021 8:07 Hi. I have this script
	    devices = {
	   timer =
		   {'every minute'}
I found a solution by repeating the switching command from Dzvents to espeasy. But if someone will help with mqtt publisher in dzvents i will appreciate it
