Hi Everyone,
Greeting from Portugal, I am new here at the forum and I need some help, so I have a heat pump (Saunier Duval SDHV19) and the energy consumption is a little bit high (30Kw/day), a year ago the consumption was worst, like 90Kw/day, after reading the manuals I saw that the thermostats could be used also on the interior, so I change all the parameters to use in the interior and the truth is the consumption decrease for almost 1/3, I guess is not enough, so that's why I am here, my idea is to use interior Temperature sensors in every room and somehow (average temperature of all rooms for example) control the heat pump.
Do you think that this is possible?
external connections:
https://ibb.co/sygLHrT
the connection with red, I guess we can install something to control.
https://ibb.co/vPL5v5L
Control heat pump with Sensors and Switch
fernandojsdias
