Possible to restart a Plugin ?
madpatrick
Domoticz version: 2025.2
Post by madpatrick »
Is it possibleto restart a plugin without restarting Domoticz.
The Somfy Plugin sometimes looses connection with the API site and give then a error that it is not able to login and stay this way.
2021-10-24 16:30:25.632 Error: Somfy Tahoma: (Somfy Tahoma) Tahoma error must reconnect
2021-10-24 16:30:26.244 Error: Somfy Tahoma: (Somfy Tahoma) 'onMessage' failed 'KeyError'.
2021-10-24 16:30:26.244 Error: Somfy Tahoma: (Somfy Tahoma) ----> Line 283 in '/var/domoticz/plugins/domoticz_tahoma_blind/plugin.py', function onMessage
2021-10-24 16:30:26.244 Error: Somfy Tahoma: (Somfy Tahoma) ----> Line 82 in '/var/domoticz/plugins/domoticz_tahoma_blind/plugin.py', function onMessage
2021-10-24 16:30:26.245 Error: Somfy Tahoma: (Somfy Tahoma) 'onMessage' failed 'KeyError'.
By restarting(reloading) the plugin is working againg (make it in the Hardware page non-active/active)
https://github.com/nonolk/domoticz_tahoma_blind
If it is possible, can i do this in the script?
pipiche
Re: Possible to restart a Plugin ?
Post by pipiche »
Yes, it is possible, but it is a bit weird as the plugin is going to kill itself to restart.
You have to use the Domoticz JSON API: https://www.domoticz.com/wiki/Domoticz_API/JSON_URL%27s
/json.htm?type=command&param=updatehardware
Domoticz version: 2025.1
For a restart I use the update button. Just select the hardware and click on update ( without changing anything).
madpatrick
Thnaks for the replies.
Is this possible to add this in the script ?
I'm a nono on Python, so any feedback will help
It is possible but needs some rework and an extra definition of the IP of your Domoticz installation.
But perhaps you can also enable the data timeout function in the hardware definition (menu Setup - Hardware)
If the plugin does not receive data during a defined time frame the plugin will be restarted by Domoticz.
madpatrick
waltervl wrote: Monday 25 October 2021 18:03 But perhaps you can also enable the data timeout function in the hardware definition (menu Setup - Hardware)
Thanks for the tip.
Unfortunately this does not the trick.
It restarts to often.
2021-10-26 01:29:49.819  Error: Somfy Tahoma hardware (8) nothing received for more than 5 Minutes!....
2021-10-26 01:29:50.819  Error: Restarting: Somfy Tahoma
2021-10-26 01:34:58.071  Error: Somfy Tahoma hardware (8) nothing received for more than 5 Minutes!....
2021-10-26 01:34:59.072  Error: Restarting: Somfy Tahoma
2021-10-26 01:40:06.382  Error: Somfy Tahoma hardware (8) nothing received for more than 5 Minutes!....
2021-10-26 01:40:07.382  Error: Restarting: Somfy Tahoma
I think because it makes a connection to the API site when i click a button.
When there is an error it will come up and needs to restart.
2021-10-26 10:02:43.051  Status: Somfy Tahoma: (Somfy Tahoma) Too much connections waiting before authenticating again
2021-10-26 10:02:53.070  Status: Somfy Tahoma: (Somfy Tahoma) Too much connections waiting before authenticating again
2021-10-26 10:03:03.088  Status: Somfy Tahoma: (Somfy Tahoma) Too much connections waiting before authenticating again
2021-10-26 10:03:13.056  Status: Somfy Tahoma: (Somfy Tahoma) Too much connections waiting before authenticating again
2021-10-26 10:03:23.075  Status: Somfy Tahoma: (Somfy Tahoma) Too much connections waiting before authenticating again
2021-10-26 10:03:33.093  Status: Somfy Tahoma: (Somfy Tahoma) Too much connections waiting before authenticating again
A timeout of 5 minutes is a little bit too fast in my opinion 30 or 60 minutes should be better.
Alternative road will be to find out why the error occurs , perhaps catch the error properly in Python so the plugin will not crash and needs to be restarted
madpatrick
waltervl wrote: Wednesday 27 October 2021 0:15 A timeout of 5 minutes is a little bit too fast in my opinion 30 or 60 minutes should be better.
The problems occurs when i want to activate the comand and it's makes connection to the Somfy website.
Then it returns an error (like above).
After getting this error it want to restart the plugin.
Propably it connects not to the site regurarly so it doesn't matter how long the delay is. (I think)
In the sctipy is see 2 routines for errors
        elif ((Status == 401) or (Status == 400)):
          strData = Data["Data"].decode("utf-8", "ignore")
          Domoticz.Error("Tahoma error must reconnect")
          self.logged_in = False
          self.cookie = None
          self.listenerId = None
          if ("Too many" in strData):
            Domoticz.Error("Too much connexions must wait")
            self.heartbeat = True
            return
          if ("Bad credentials" in strData):
            Domoticz.Error("Bad credentials please update credentials and restart plugin")
            self.heartbeat =  False
            return
Could this be adjusted ?
madpatrick
I think there is an other option
I've have a script in Dzventz which reads the log file for errors.
This script can detect a Somfy error so i can update the Hardware by Disable and then Enable ?
	local scriptVersion = 'Versie 1.01'
	scriptVar = "-=# Domoticz ErrorLog #=-"
return
    on          = {
                    httpResponses   = { scriptVar,},
                    timer           = {"every 10 minutes"},
                    devices         = {502},
    logging     =  {
                    level  = domoticz.LOG_INFO,
                    marker = scriptVar,
    data        = {
                    lastlogtime =
                    initial = 0
    execute = function(dz, item)
    local searchStr = 'Error: Somfy Tahoma'          -- Change to reflect the messages you want to catch
    local ignoreStrings = -- Enter all strings to be ignored in this table
            'CheckAuthToken',
    local function trueError(str)
            for _, ignore in ipairs(ignoreStrings) do
                if str:find(ignore) then return false end
            return true
    local function askDomoticzForLogLines()
            local lastLogTime = dz.data.lastlogtime            -- get time last logrequest
            local logLevel    = 4                            -- loglevel (1=normal,2=Status,4=error,268435455=all
            local jsonString  = "/json.htm?type=command" .. "&param=getlog" .. "&lastlogtime=" .. tostring(lastLogTime) .. "&loglevel=" .. tostring(logLevel)
            dz.openURL(
                url = dz.settings["Domoticz url"] .. jsonString,
                callback = scriptVar
            dz.data.lastlogtime = os.time()        -- store current Time as seconds from epoch
    local function findString()
           if item.json.result then               -- Only when there are errormessages in the log
               local rt = item.json.result
               for i = #rt, 1, -1 do                 -- traverse backwards to get latest violation first
                    local msg = rt[i].message
                    if msg:find('%s%s' .. searchStr) and trueError(msg) then return msg end
        if item.isDevice or item.isTimer then
            askDomoticzForLogLines()                     -- get the relevant loglines
        elseif item.json then
            --dz.log("Show ALL: \n" .. item.data,dz.LOG_INFO)
            local line = findString()
            if line then
                dz.log("Log " .. searchStr .. " found! ",dz.LOG_INFO)
                dz.openURL({url = 'http://192.168.1.234:9200/json.htm?type=command&param=updatehardware&htype=94&name=Somfy%20Tahoma&enabled=false&idx=8&port=0&loglevel=7&Mode6=Normal&datatimeout=0&extra=tahomaIO&loglevel=268435455&username=xxxxxxxxx&password=xxxxxxxx3',
        method = 'POST',}
                dz.openURL({url = 'http://192.168.1.234:9200/json.htm?type=command&param=updatehardware&htype=94&name=Somfy%20Tahoma&enabled=true&idx=8&port=0&loglevel=7&Mode6=Normal&datatimeout=0&extra=tahomaIO&loglevel=268435455&username=xxxxxxxxx&password=xxxxxxxx',
        method = 'POST',}
                dz.notify("Log " .. line .. " found! ",dz.PRIORITY_HIGH)
                dz.log("No (new) occurrences of string " .. searchStr .. " in the domoticz log ",dz.LOG_INFO)
            dz.log("Access problem to log. Data found: " .. item.data,dz.LOG_ERROR)
The problem now is that the to OpenURL commands are to quick after each other.
IS it possible to get a delay between them ?
JanJaap
Domoticz version: Dev
Post by JanJaap »
All,
To my humble opinion restarting automatically a plugin is fighting symptoms rather then solving the root cause of the issue, which seems that connections are being opened. I've scanned quickly though the plugin and it looks like the author would be better of using the python requests library to handle the communication. You can add a time out to the API calls, build a retry and just throw a nicely handled error (rather then letting the app crash). Check my Goodwe plugin for examples when needed (not sure it the author is reading here).
madpatrick
Unfortunately is the writter not supporting the plugin anymore.
So if somebody support on adjusting the plugin a lot of users will be happy
JanJaap
Post by JanJaap »
Hi guys,
I love to help out but I do not have any Somfy hardware so I can't test any changes. If one of you guys creates a branch and tells me how to signup somewhere then I can have a go at it. Hopefully that is then enough to get to basis stuff to work.
madpatrick
Hello JanJaap
Good to hear you want to help.
I can setup a branch on Github if needed.
The only issue could be the connection to Somfy.
You need to register with a Somfy box first as far as i know.
For testing i can give you access to my Somfy account, but this will activate my screens during testing 😋
JanJaap
Post by JanJaap »
All right please set up the branch, I'll push some changes later this week. Will probably create some log files to capture the responses. Can you describe on your branch github page the setup process or at least the link for the somfy account? I'll see where I get with only an account and no device....
madpatrick
Hello JanJaap,
I'll send you a PM
JanCeuleers
Post by JanCeuleers »
My hunch as to why the errors occur and the devices go unresponsive (which, by the way, is also happening to me in V1.0.9 of the plugin) is as follows:
I recently added 4 more devices to my Domoticz install. I already had a few Tuya devices active. The plugin's method of adding devices adds all devices found in the Tuya (or Smart Life, ...) account in Domoticz, including the ones that already existed. So the result is that each physical device has multiple entries in Domoticz's device table, and it can be hard to know which-ones are current.
