S0 PCM-5 Counter on Water
Posted: Friday 22 October 2021 21:49
by JanAtHome
Hey
I have connected a 5 channel S0 counter module (S0-PMC-5) via usb.
On channel 1 there is a water meter that gives neat pulses.
Now in domoticz I want to set this meter to water instead of energy.
This doesn't want to. Does anyone know if this is possible?
Hallo
Ik heb een 5 kanaals S0 teller module aangesloten (S0-PMC-5) via usb.
Op kanaal 1 zit een watermeter die netjes pulsen geeft.
Nu wil ik in domoticz deze meter instellen op water in plaats van energie.
Dit wil niet. Weet iemand of dit kan ?
Re: S0 PCM-5 Counter on Water
Posted: Sunday 28 November 2021 12:08
by JanAtHome
Hello Forum members
just an update.
The S0 counter now works fine, I was not shown the correct counter, the reason for this was that the hardware must allow new sensors.
So first set counter type, and then allow 5 min new sensors.
Then you see the correctly set counters.
