Dashticz v3.8.6-beta
Lokonli
Post by Lokonli »
I just released Dashticz v3.8.6-beta
Main new feature:
You can now also add switch info to your graph. For instance, combine two temperature devices with the switch info indicating central heating is on:
This graph was created with the following block:
blocks['switchgraph'] = {
  devices: [
      31,
      27,
      17,
  debugButton: true,
  zoom: true,
  graph: 'line',
  legend : {
      l_17: 'CV On',
      te_31: 'Return temp',
      te_27: 'Room temp'
  lineFill: [true, false, false],
  datasetColors: ['rgba(44,130,201,0.5)', 'red', 'blue'],
Further, it contains some additional refactoring of the graph code and bug fixing (like generating the correct y axes labeling)
I made quite some changes to the code, and probably I overlooked a few use cases during testing. If you find issues with respect to the graphs please report them here, and I'll fix them as quickly as possible.
Doudy
Re: Dashticz v3.8.6-beta
Post by Doudy »
Where can I find the other modifications of this version?
Lokonli
Post by Lokonli »
Doudy wrote: Saturday 23 October 2021 8:51 Hello,
https://dashticz.readthedocs.io/en/beta ... nt-changes
Doudy
Post by Doudy »
pvklink
Domoticz version: latest b
Post by pvklink »
My garbage is not working anymore.
I use the manual installation of apache and dashticz as described in the wiki
This is my config on a rpi4b, latest beta os, latest beta dashticz.
config['garbage_mapping'] = {
    	rest: ['grof', 'grey', 'rest', 'grijs','grijze'],
    	gft: ['gft', 'tuin', 'refuse bin', 'green', 'groen', 'Biodégradables', 'snoei'],
    	pmd: ['plastic', 'pmd', 'verpakking', 'kunststof', 'valorlux'],
    	papier: ['papier', 'blauw', 'blue', 'recycling bin collection'],
    	kca: ['chemisch', 'kca','kga'],
    	brown: ['brown', 'verre'],
    	black: ['black', 'zwart'],
    	milieu: ['milieu'],
    	kerstboom: ['kerst'],};
config['garbage'] = {
    	gft: {kliko: 'green', code: '#FFFFFF', name: 'GFT (groene bak)', icon: 'img/garbage/kliko_green.png'},
    	pmd: {kliko: 'orange', code: '#FFFFFF', name: 'PMD', icon: 'img/garbage/kliko_orange.png'},
    	rest: {kliko: 'grey', code: '#FFFFFF', name: 'Restafval', icon: 'img/garbage/kliko_grey.png'},
    	papier: {kliko: 'blue', code: '#FFFFFF', name: 'Papier', icon: 'img/garbage/kliko_blue.png'},
    	kca: {kliko: 'red', code: '#FFFFFF', name: 'Chemisch afval', icon: 'img/garbage/kliko_red.png'},
    	brown: {kliko: 'brown', code: '#FFFFFF', name: 'Bruin', icon: 'img/garbage/kliko_brown.png'},
    	black: {kliko: 'black', code: '#FFFFFF', name: 'Zwart', icon: 'img/garbage/kliko_black.png'},
    	milieu: {kliko: 'yellow', code: '#FFFFFF', name: 'Geel', icon: 'img/garbage/kliko_yellow.png'},
    	kerstboom: {kliko: 'green', code: '#FFFFFF', name: 'Kerstboom', icon: 'img/garbage/tree.png'},};
blocks['mygarbage'] =
	icalurl: '',
	google_api_key:'',
	garbage_calendar_id: '',
	garbage_use_colors: 1,
	garbage_use_names: 1,
	garbage_icon_use_colors: 1,
	garbage_hideicon: 0,
	garbage_use_cors_prefix: 1,
	company: 'avalex',
	zipcode: '2286MA',
	street: 'Cornelia Schellingerlaan',
	housenumber: 15,
	housenumberadd: '',
	maxitems: 12,
	width: 5
columns[1] = {blocks: ['t_klimaat_buiten','weather_pvk',1285,1305,1250,1163,1303,1248,'2241_1','t_klimaat binnen','mytherm','wasmachine','p1_electra','t_nieuws','dvfam','mygarbage'], width: 3}
css
.garbage {height: 220px;width: 295px;}
.garbage .dt_state { height: 100%; overflow-y: auto}
apache/php
	sudo apt-get update -y
	sudo apt-get install -y apache2 php php-xml php-curl libapache2-mod-php
	sudo chmod 777 $homevolumes/dashticz
	sudo chmod 777 $homevolumes/pvkwebserver
	sudo ln -s $homevolumes/dashticz/ /var/www/html
	sudo systemctl restart apache2
dashtix pulled from git
Jablotron connection, Ikea
brandsrus
Post by brandsrus »
Traffic Block:
Schermafbeelding 2021-10-27 141545.png (91.19 KiB) Viewed 1687 times
In this case the A50 present twice but in the first case with the text 'There is no trafficinformation' but in the second case with a speedlimit check.
Is it possible to give A50 one time on this sheet? But is it possible to give an option to hide highways without any information?
@pvklink: Your home adress is visible in your code, maybe scramble this for your privacy.
Lokonli
Post by Lokonli »
pvklink wrote: Wednesday 27 October 2021 12:03 My garbage is not working anymore.
    	milieu: ['milieu'],
	icalurl: '',
	google_api_key:'',
	company: 'avalex',
	zipcode: '2286MA',
	housenumber: 15,
	housenumberadd: '',
	maxitems: 12,
	width: 5
css
apache/php
Avalex switched to a new garbage data provider (Ximmio). That means the Dashticz code needs to be updated. I already have a fix working here locally. I try to release it in the coming days.
(So this issue is not related to 3.8.6 itself.)
Lokonli
Post by Lokonli »
    	milieu: ['milieu'],
	icalurl: '',
	google_api_key:'',
	company: 'avalex',
	zipcode: '2286MA',
	housenumber: 15,
	housenumberadd: '',
	maxitems: 12,
	width: 5
css
apache/php
Should work again with latest beta. Can you test?
(just execute a 'git pull' in the Dashticz folder)
pvklink
Post by pvklink »
Great!
do i have to change the company name in the config from avalex to the Ximmio?
pvklink
Post by pvklink »
ohh, it works! i used the old avalex value..
THANKSSSSSSSSSS, veryyyyy happy!
Little question (does dashticz supports name resolving, so i can use a host name for the domoticz server as specifiek in /etc/hosts in the config file instead of an ip-adress
pvklink
Post by pvklink »
Only the styling does not work anymore.
I thought that the mapping do some translations from GREY to rest
But they dont. I also changed item "grey: two times from grey to GREY to see if that works, but noop
    	rest: ['grof', 'GREY', 'rest', 'grijs','grijze'],
    	milieu: ['milieu'],
    	rest: {kliko: 'GREY', code: '#FFFFFF', name: 'Restafval', icon: 'img/garbage/kliko_grey.png'},
pvklink
Post by pvklink »
solved it by making a new block with content from others on this forum
blocks['mygarbage'] =	{
	company: 'avalex',
	zipcode: xxxxxx',
	street: 'xxx',
	housenumber: xx,
	housenumberadd: '',
	layout: 1,
	image: '',
	url: 'https://www.avalex.nl/kalender/',
	newwindow: 1,
        width: 5,
	hideicon: 0,
	icon_use_colors:1,
	use_colors:0,
        use_names: 1,
	garbage_mapping: {
    		milieu: ['milieu'],
	    	kerstboom: ['kerst'],},
	garbage: {
	    	kerstboom: {kliko: 'green', code: '#FFFFFF', name: 'Kerstboom', icon: 'img/garbage/tree.png'},},
	maxitems: 12,
	width: 5,
Maikel76
Domoticz version: 2022.1
Post by Maikel76 »
Lokonli wrote: Friday 22 October 2021 18:26 I just released Dashticz v3.8.6-beta
Main new feature:
  devices: [
      31,
      27,
      17,
  debugButton: true,
  zoom: true,
  graph: 'line',
  legend : {
      l_17: 'CV On',
      te_27: 'Room temp'
Goodmorning Lokonli,
I just updated to v3.8.6 and verified
Unfortunately I cannot get it to work, the AC on bar/filled line is not showing, its always 0
This is the code that I put;
blocks['my_graph'] = {
         title: 'Avg temp',
         devices: [13, 95, 97, 69],
         graph: 'line',
         graphTypes: ['hu','te','te','te','l'],
 //      lineTension: 0.4,
         width: 8,
         height: '125px',
         zoom: true,
         legend: {hu_13: 'hum', te_13: 'now', te_95: 'avg', te_97: 'set', l_69: 'AC on'},
         lineFill: [false, false, false, false, true],
         datasetColors: ['white', 'orange','yellow','red','rgba(44,130,201,0.5)'],
         debug: true
I think the issue is idx 13 which is a multisensor consisting of 13_1 for hu and 13_2 for te
I tried a whole couple of different variations
this is the output when AC is on
  "mountPoint": "#block_19",
  "block": {
    "width": 8,
    "datasetColors": [
      "white",
      "orange",
      "yellow",
      "red",
      "rgba(44,130,201,0.5)"
    "axisRight": false,
    "axisAlternate": true,
    "barWidth": 0.9,
    "beginAtZero": false,
    "borderDash": [],
    "borderWidth": 2,
    "buttonsBorder": "white",
    "buttonsColor": "black",
    "buttonsFill": "white",
    "buttonsIcon": "#686868",
    "buttonsMarginX": 2,
    "buttonsMarginY": 0,
    "buttonsPadX": 6,
    "buttonsPadY": 2,
    "buttonsRadius": 0,
    "buttonsShadow": false,
    "buttonsSize": 14,
    "buttonsText": false,
    "cartesian": "linear",
    "custom": false,
    "customHeader": false,
    "debugButton": true,
    "displayFormats": false,
    "drawOrderDay": false,
    "drawOrderLast": false,
    "drawOrderMonth": false,
    "flash": false,
    "fontColor": "white",
    "format": true,
    "gradients": false,
    "graph": "line",
    "graphTypes": [
      "hu",
      "te",
      "te",
      "te",
      "l"
    "groupBy": false,
    "groupByDevice": false,
    "height": "125px",
    "iconColour": "grey",
    "interval": 1,
    "legend": {
      "hu_13": "hum",
      "te_13": "now",
      "te_95": "avg",
      "te_97": "set",
      "l_69": "AC on"
    "lineFill": [
      false,
      false,
      false,
      false,
      true
    "lineTension": 0.1,
    "maxTicksLimit": null,
    "method": 1,
    "pointBorderColor": [
      "grey"
    "pointBorderWidth": 0,
    "pointRadius": 0,
    "pointStyle": false,
    "range": "initial",
    "refresh": 300,
    "reverseTime": false,
    "sortDevices": false,
    "spanGaps": false,
    "stacked": false,
    "title": "Avg temp",
    "tooltiptotal": false,
    "zoom": true,
    "type": "my_graph",
    "devices": [
      13,
      95,
      97,
      69
    "debug": true,
    "c": 1,
    "key": "my_graph"
  "key": "my_graph",
  "name": "graph",
  "callbacks": {
    "timeoutList": [],
    "intervalList": [
      99
    "subscriptionList": [
      null,
      null,
      null,
      null,
      null
  "$mountPoint": {
    "0": {},
    "length": 1
  "graphDevices": [
      "AddjMulti": 1,
      "AddjMulti2": 1,
      "AddjValue": 0,
      "AddjValue2": 0,
      "BatteryLevel": 100,
      "CustomImage": 0,
      "Data": "28.0 C, 54 %",
      "Description": "",
      "DewPoint": "17.83",
      "Favorite": 1,
      "HardwareDisabled": false,
      "HardwareID": 2,
      "HardwareName": "Aeotec Zwave USB stick",
      "HardwareType": "OpenZWave USB",
      "HardwareTypeVal": 21,
      "HaveTimeout": false,
      "Humidity": 54,
      "HumidityStatus": "Comfortable",
      "ID": "0401",
      "LastUpdate": "2021-11-11 14:01:05",
      "Name": "TempHum",
      "Notifications": "false",
      "PlanID": "0",
      "PlanIDs": [
        0
      "Protected": false,
      "ShowNotifications": true,
      "SignalLevel": "-",
      "SubType": "WTGR800",
      "Temp": 28,
      "Timers": "false",
      "Type": "Temp + Humidity",
      "TypeImg": "temperature",
      "Unit": 0,
      "Used": 1,
      "XOffset": "0",
      "YOffset": "0",
      "idx": 13,
      "trend": 2,
      "Data0": "28.0 C, 54 %",
      "currentValue": "28.0 C, 54 %",
      "name": "TempHum",
      "sensor": "temp",
      "subtype": "WTGR800",
      "title": "TempHum",
      "txtUnit": "°C",
      "txtUnits": [],
      "type": "Temp + Humidity",
      "decimals": 1,
      "method": 1
      "AddjMulti": 1,
      "AddjMulti2": 1,
      "AddjValue": 0,
      "AddjValue2": 0,
      "BatteryLevel": 255,
      "CustomImage": 0,
      "Data": "26.5 C",
      "Description": "",
      "Favorite": 1,
      "HardwareID": 4,
      "HardwareName": "VirtualSwitches",
      "HardwareType": "Dummy (Does nothing, use for virtual switches only)",
      "HardwareTypeVal": 15,
      "ID": "140AF",
      "LastUpdate": "2021-11-11 12:55:02",
      "Name": "Temp_Avg",
      "PlanID": "0",
      "PlanIDs": [
        0
      "Protected": false,
      "SignalLevel": "-",
      "SubType": "LaCrosse TX3",
      "Temp": 26.5,
      "Timers": "false",
      "Type": "Temp",
      "Unit": 1,
      "Used": 1,
      "XOffset": "0",
      "YOffset": "0",
      "idx": 95,
      "trend": 3,
      "Data0": "26.5 C",
      "currentValue": "26,5 °C",
      "name": "Temp_Avg",
      "sensor": "temp",
      "subtype": "LaCrosse TX3",
      "title": "Temp_Avg",
      "txtUnit": "°C",
      "txtUnits": [],
      "type": "Temp",
      "decimals": 1,
      "method": 1
      "AddjMulti": 1,
      "AddjMulti2": 1,
      "AddjValue": 0,
      "AddjValue2": 0,
      "CustomImage": 0,
      "Data": "27.0 C",
      "Description": "",
      "Favorite": 1,
      "HardwareID": 4,
      "ID": "140B1",
      "LastUpdate": "2021-11-11 14:00:03",
      "Name": "MinTempACcelc",
      "PlanID": "0",
      "PlanIDs": [
        0
      "Protected": false,
      "SignalLevel": "-",
      "Temp": 27,
      "Timers": "false",
      "Type": "Temp",
      "Unit": 1,
      "Used": 1,
      "XOffset": "0",
      "YOffset": "0",
      "idx": 97,
      "trend": 1,
      "Data0": "27.0 C",
      "currentValue": "27,0 °C",
      "name": "MinTempACcelc",
      "sensor": "temp",
      "title": "MinTempACcelc",
      "txtUnit": "°C",
      "txtUnits": [],
      "type": "Temp",
      "decimals": 1,
      "method": 1
      "AddjMulti": 1,
      "AddjMulti2": 1,
      "AddjValue": 0,
      "AddjValue2": 0,
      "CustomImage": 16,
      "Data": "On",
      "Description": "",
      "DimmerType": "none",
      "Favorite": 1,
      "HardwareID": 4,
      "HaveDimmer": true,
      "HaveGroupCmd": true,
      "ID": "00014095",
      "Image": "Cooling",
      "IsSubDevice": false,
      "LastUpdate": "2021-11-11 13:57:36",
      "Level": 0,
      "LevelInt": 0,
      "MaxDimLevel": 100,
      "Name": "AC",
      "PlanID": "0",
      "PlanIDs": [
        0
      "Protected": false,
      "SignalLevel": "-",
      "Status": "On",
      "StrParam1": "",
      "StrParam2": "",
      "SubType": "Switch",
      "SwitchType": "On/Off",
      "SwitchTypeVal": 0,
      "Timers": "false",
      "Type": "Light/Switch",
      "TypeImg": "lightbulb",
      "Unit": 1,
      "Used": 1,
      "UsedByCamera": false,
      "XOffset": "0",
      "YOffset": "0",
      "idx": 69,
      "Data0": "On",
      "currentValue": "On",
      "name": "AC",
      "sensor": "",
      "subtype": "Switch",
      "title": "AC",
      "txtUnit": "level",
      "txtUnits": [],
      "type": "Light/Switch",
      "decimals": 0,
      "method": 1
  "decimals": 1,
  "graphIdx": "block_19",
  "lastRefreshTime": 1636614145,
  "range": "last",
  "params": [
    "type=graph&sensor=temp&idx=13&range=day&method=1",
    "type=graph&sensor=temp&idx=95&range=day&method=1",
    "type=graph&sensor=temp&idx=97&range=day&method=1",
    "type=lightlog&idx=69"
  "txtUnits": [],
  "data": {
    "result": [
        "d": "2021-11-11 10:05",
        "hu_13": "58",
        "te_13": 27.6,
        "te_95": 26.1,
        "te_97": 27
        "d": "2021-11-11 10:10",
        "hu_13": "59",
        "te_13": 27.7,
        "te_95": 26.1,
        "te_97": 27
        "d": "2021-11-11 10:15",
        "hu_13": "59",
        "te_13": 27.8,
        "te_95": 26.1,
        "te_97": 27
        "d": "2021-11-11 10:20",
        "hu_13": "59",
        "te_13": 27.8,
        "te_95": 26.1,
        "te_97": 27
        "d": "2021-11-11 10:25",
        "hu_13": "59",
        "te_13": 27.9,
        "te_95": 26.1,
        "te_97": 27
        "d": "2021-11-11 10:30",
        "hu_13": "59",
        "te_13": 27.9,
        "te_97": 27
        "d": "2021-11-11 10:35",
        "hu_13": "59",
        "te_13": 28,
        "te_97": 27
        "d": "2021-11-11 10:40",
        "hu_13": "59",
        "te_13": 28,
        "te_97": 27
        "d": "2021-11-11 10:45",
        "hu_13": "59",
        "te_13": 28,
        "te_97": 27
        "d": "2021-11-11 10:49:08",
        "l_69": 0
        "d": "2021-11-11 10:50",
        "hu_13": "59",
        "te_13": 28,
        "te_97": 27
        "d": "2021-11-11 10:55",
        "hu_13": "55",
        "te_13": 27.4,
        "te_97": 27
        "d": "2021-11-11 11:00",
        "hu_13": "57",
        "te_13": 26.5,
        "te_97": 27
        "d": "2021-11-11 11:05",
        "hu_13": "58",
        "te_13": 26.2,
        "te_97": 27
        "d": "2021-11-11 11:10",
        "hu_13": "61",
        "te_13": 25.5,
        "te_97": 27
        "d": "2021-11-11 11:10:02",
        "l_69": 0
        "d": "2021-11-11 11:15",
        "hu_13": "60",
        "te_13": 25.9,
        "te_95": 26.8,
        "te_97": 27
        "d": "2021-11-11 11:20",
        "hu_13": "59",
        "te_13": 26.4,
        "te_95": 26.8,
        "te_97": 27
        "d": "2021-11-11 11:25",
        "hu_13": "59",
        "te_13": 26.8,
        "te_95": 26.8,
        "te_97": 27
        "d": "2021-11-11 11:30",
        "hu_13": "58",
        "te_13": 27.3,
        "te_95": 26.8,
        "te_97": 27
        "d": "2021-11-11 11:35",
        "hu_13": "58",
        "te_13": 27.5,
        "te_95": 26.8,
        "te_97": 27
        "d": "2021-11-11 11:40",
        "hu_13": "58",
        "te_13": 27.6,
        "te_95": 26.8,
        "te_97": 27
        "d": "2021-11-11 11:41:07",
        "l_69": 0
        "d": "2021-11-11 11:45",
        "hu_13": "58",
        "te_13": 27.8,
        "te_95": 26.4,
        "te_97": 27
        "d": "2021-11-11 11:50",
        "hu_13": "57",
        "te_13": 26.4,
        "te_95": 26.4,
        "te_97": 27
        "d": "2021-11-11 11:55",
        "hu_13": "58",
        "te_13": 26.1,
        "te_95": 26.4,
        "te_97": 27
        "d": "2021-11-11 12:00",
        "hu_13": "54",
        "te_13": 25.6,
        "te_95": 26.4,
        "te_97": 27
        "d": "2021-11-11 12:01:07",
        "l_69": 0
        "d": "2021-11-11 12:05",
        "hu_13": "60",
        "te_13": 25.4,
        "te_95": 26.5,
        "te_97": 27
        "d": "2021-11-11 12:10",
        "hu_13": "59",
        "te_13": 26.5,
        "te_95": 26.5,
        "te_97": 27
        "d": "2021-11-11 12:15",
        "hu_13": "58",
        "te_13": 26.9,
        "te_95": 26.5,
        "te_97": 27
        "d": "2021-11-11 12:20",
        "hu_13": "58",
        "te_13": 27.2,
        "te_95": 26.5,
        "te_97": 27
        "d": "2021-11-11 12:25",
        "hu_13": "58",
        "te_13": 27.4,
        "te_95": 26.5,
        "te_97": 27
        "d": "2021-11-11 12:30",
        "hu_13": "58",
        "te_13": 27.7,
        "te_95": 26.5,
        "te_97": 27
        "d": "2021-11-11 12:33:06",
        "l_69": 0
        "d": "2021-11-11 12:35",
        "hu_13": "58",
        "te_13": 27.8,
        "te_95": 26.5,
        "te_97": 27
        "d": "2021-11-11 12:40",
        "hu_13": "55",
        "te_13": 27.3,
        "te_95": 26.5,
        "te_97": 27
        "d": "2021-11-11 12:45",
        "hu_13": "57",
        "te_13": 26.4,
        "te_95": 26.5,
        "te_97": 27
        "d": "2021-11-11 12:50",
        "hu_13": "54",
        "te_13": 25.6,
        "te_95": 26.5,
        "te_97": 27
        "d": "2021-11-11 12:55",
        "hu_13": "60",
        "te_13": 25.4,
        "te_95": 26.5,
        "te_97": 27
        "d": "2021-11-11 12:55:02",
        "l_69": 0
        "d": "2021-11-11 13:00",
        "hu_13": "59",
        "te_13": 25.6,
        "te_95": 26.5,
        "te_97": 27
        "d": "2021-11-11 13:05",
        "hu_13": "58",
        "te_13": 26.1,
        "te_95": 26.5,
        "te_97": 27
        "d": "2021-11-11 13:10",
        "hu_13": "57",
        "te_13": 26.9,
        "te_95": 26.5,
        "te_97": 27
        "d": "2021-11-11 13:15",
        "hu_13": "57",
        "te_13": 27.2,
        "te_95": 26.5,
        "te_97": 27
        "d": "2021-11-11 13:20",
        "hu_13": "57",
        "te_13": 27.5,
        "te_95": 26.5,
        "te_97": 27
        "d": "2021-11-11 13:25",
        "hu_13": "57",
        "te_13": 27.8,
        "te_95": 26.5,
        "te_97": 27
        "d": "2021-11-11 13:30",
        "hu_13": "56",
        "te_13": 28.1,
        "te_95": 26.5,
        "te_97": 27
        "d": "2021-11-11 13:35",
        "hu_13": "56",
        "te_13": 28.2,
        "te_95": 26.5,
        "te_97": 27
        "d": "2021-11-11 13:40",
        "hu_13": "56",
        "te_13": 28.3,
        "te_95": 26.5,
        "te_97": 27
        "d": "2021-11-11 13:45",
        "hu_13": "56",
        "te_13": 28.4,
        "te_95": 26.5,
        "te_97": 27
        "d": "2021-11-11 13:50",
        "hu_13": "56",
        "te_13": 28.5,
        "te_95": 26.5,
        "te_97": 27
        "d": "2021-11-11 13:55",
        "hu_13": "56",
        "te_13": 28.6,
        "te_95": 26.5,
        "te_97": 27
        "d": "2021-11-11 13:57:36",
        "l_69": 0
        "d": "2021-11-11 14:00",
        "hu_13": "56",
        "te_13": 28.6,
        "te_97": 27
    "status": "OK",
    "title": "Graph day"
  "realrange": "day",
  "dataFilterCount": 4,
  "dataFilterUnit": "hours",
  "groupBy": false,
  "ylabels": [
    "°C",
    "°C",
    "°C",
    "level"
  "keys": [
    "hu",
    "te",
    "l"
  "ykeys": [
    "hu_13",
    "te_13",
    "te_95",
    "te_97",
    "l_69"
  "txtUnit": "°C",
  "chartctx": {},
  "_width": 825.333,
  "loadingTooltip": false
"l_69": 0 should be 'On', either the AC is on or off it will show 0
idx 69 is a virtual switch
problem is I cannot get AC on to display the same as in your example graph
Do you have suggestions for me?
Edit: I just tested with a real device instead of a virtual device and it does exactly the same (so instead of l_69 i used l_1 which is a z-wave dev)
Edit2: I put the switch as first in the legend array and I see the problem now, I think you can only use a switch with a level indicator, like a dimmer (level 0-100). My values on the right y-axis go from 1.0 to -1.0
I will make another virtual device that i will give level 1 or 100 and put that device in the graph, but that will probably be tomorrow
I let it run for a while to test
Scripting is my passion, dzVents, LUA, Bash
Dashticz v3.10.7 Beta --Raspbian Buster
Lokonli
Post by Lokonli »
I assumed that all switches have a level.
Can you post the output of:
http://domoticz-ip:port/json.htm?type=lightlog&idx=69
Maikel76
Post by Maikel76 »
Lokonli wrote: Thursday 11 November 2021 21:32 I assumed that all switches have a level.
Thanks for the reply and sure, here it is;
HaveDimmer	true
HaveGroupCmd	true
HaveSelector	false
result
0
Data	"Off"
Date	"2021-11-12 12:54:43"
Level	0
MaxDimLevel	100
Status	"Off"
User	"EventSystem//home/pi/domoticz/dzVents/runtime/dzVents.lua"
idx	"661728"
1
Data	"On"
Date	"2021-11-12 12:32:54"
Level	0
Status	"On"
idx	"661681"
2
Data	"Off"
Date	"2021-11-12 12:12:51"
Level	0
Status	"Off"
idx	"661642"
3
Data	"On"
Date	"2021-11-12 12:04:51"
Level	0
Status	"On"
idx	"661635"
4
Data	"Off"
Date	"2021-11-12 11:43:56"
Level	0
Status	"Off"
idx	"661621"
5
Data	"On"
Date	"2021-11-12 11:23:26"
Level	0
Status	"On"
idx	"661565"
6
Data	"Off"
Date	"2021-11-12 07:50:02"
Level	0
Status	"Off"
idx	"661434"
7
Data	"On"
Date	"2021-11-12 07:45:02"
Level	0
Status	"On"
idx	"661422"
8
Data	"Off"
Date	"2021-11-11 22:53:00"
Level	0
Status	"Off"
idx	"661125"
9
Data	"On"
Date	"2021-11-11 22:33:00"
Level	0
Status	"On"
idx	"661045"
10
Data	"Off"
Date	"2021-11-11 22:03:50"
Level	0
Status	"Off"
idx	"660947"
11
Data	"On"
Date	"2021-11-11 21:41:00"
Level	0
Status	"On"
idx	"660873"
12
Data	"Off"
Date	"2021-11-11 21:13:01"
Level	0
Status	"Off"
idx	"660783"
13
Data	"On"
Date	"2021-11-11 20:53:01"
Level	0
Status	"On"
idx	"660736"
14
Data	"Off"
Date	"2021-11-11 20:30:02"
Level	0
Status	"Off"
idx	"660682"
15
Data	"On"
Date	"2021-11-11 20:09:15"
Level	0
Status	"On"
idx	"660641"
16
Data	"Off"
Date	"2021-11-11 19:09:41"
Level	0
Status	"Off"
idx	"660576"
17
Data	"On"
Date	"2021-11-11 19:01:02"
Level	0
Status	"On"
idx	"660536"
18
Data	"Off"
Date	"2021-11-11 18:29:03"
Level	0
Status	"Off"
idx	"660447"
19
Data	"On"
Date	"2021-11-11 18:09:03"
Level	0
Status	"On"
idx	"660402"
20
Data	"Off"
Date	"2021-11-11 17:29:03"
Level	0
Status	"Off"
idx	"660311"
21
Data	"On"
Date	"2021-11-11 16:28:04"
Level	0
Status	"On"
User	"Admin (IP: 192.168.88.188)"
idx	"660163"
22
Data	"Off"
Date	"2021-11-11 16:20:02"
Level	0
Status	"Off"
idx	"660134"
23
Data	"On"
Date	"2021-11-11 16:13:04"
Level	0
Status	"On"
idx	"660123"
24
Data	"Off"
Date	"2021-11-11 15:48:08"
Level	0
Status	"Off"
idx	"660094"
25
Data	"On"
Date	"2021-11-11 15:25:05"
Level	0
Status	"On"
idx	"660057"
26
Data	"Off"
Date	"2021-11-11 15:05:05"
Level	0
Status	"Off"
idx	"660040"
27
Data	"On"
Date	"2021-11-11 14:45:05"
Level	0
Status	"On"
idx	"660010"
28
Data	"Off"
Date	"2021-11-11 14:20:02"
Level	0
Status	"Off"
idx	"659983"
29
Data	"On"
Date	"2021-11-11 13:57:36"
Level	0
Status	"On"
idx	"659952"
30
Data	"Off"
Date	"2021-11-11 12:55:02"
Level	0
Status	"Off"
idx	"659883"
31
Data	"On"
Date	"2021-11-11 12:33:06"
Level	0
Status	"On"
idx	"659873"
32
Data	"Off"
Date	"2021-11-11 12:01:07"
Level	0
Status	"Off"
idx	"659862"
33
Data	"On"
Date	"2021-11-11 11:41:07"
Level	0
Status	"On"
idx	"659851"
34
Data	"Off"
Date	"2021-11-11 11:10:02"
Level	0
Status	"Off"
idx	"659822"
35
Data	"On"
Date	"2021-11-11 10:49:08"
Level	0
Status	"On"
idx	"659794"
36
Data	"Off"
Date	"2021-11-11 09:25:09"
Level	0
Status	"Off"
idx	"659739"
37
Data	"On"
Date	"2021-11-11 09:05:09"
Level	0
Status	"On"
idx	"659723"
38
Data	"Off"
Date	"2021-11-11 08:05:09"
Level	0
Status	"Off"
idx	"659651"
39
Data	"On"
Date	"2021-11-11 07:45:02"
Level	0
Status	"On"
idx	"659621"
40
Data	"Off"
Date	"2021-11-10 22:41:16"
Level	0
Status	"Off"
idx	"659283"
41
Data	"On"
Date	"2021-11-10 22:21:16"
Level	0
Status	"On"
idx	"659252"
42
Data	"Off"
Date	"2021-11-10 21:50:02"
Level	0
Status	"Off"
idx	"659184"
43
Data	"On"
Date	"2021-11-10 21:29:17"
Level	0
Status	"On"
idx	"659143"
44
Data	"Off"
Date	"2021-11-10 21:09:17"
Level	0
Status	"Off"
idx	"659103"
45
Data	"On"
Date	"2021-11-10 20:49:17"
Level	0
Status	"On"
idx	"659062"
46
Data	"Off"
Date	"2021-11-10 20:29:17"
Level	0
Status	"Off"
idx	"659018"
47
Data	"On"
Date	"2021-11-10 20:06:00"
Level	0
Status	"On"
idx	"658970"
48
Data	"Off"
Date	"2021-11-10 17:05:01"
Level	0
Status	"Off"
idx	"658784"
49
Data	"On"
Date	"2021-11-10 17:02:56"
Level	0
Status	"On"
idx	"658778"
50
Data	"Off"
Date	"2021-11-10 17:01:58"
Level	0
Status	"Off"
idx	"658775"
51
Data	"On"
Date	"2021-11-10 17:01:56"
Level	0
Status	"On"
idx	"658774"
52
Data	"Off"
Date	"2021-11-10 17:01:22"
Level	0
Status	"Off"
idx	"658769"
53
Data	"On"
Date	"2021-11-10 17:01:07"
Level	0
Status	"On"
idx	"658764"
54
Data	"Off"
Date	"2021-11-10 16:40:55"
Level	0
Status	"Off"
idx	"658703"
55
Data	"On"
Date	"2021-11-10 16:20:51"
Level	0
Status	"On"
idx	"658660"
56
Data	"Off"
Date	"2021-11-10 16:00:04"
Level	0
Status	"Off"
idx	"658633"
57
Data	"On"
Date	"2021-11-10 15:37:21"
Level	0
Status	"On"
idx	"658590"
58
Data	"Off"
Date	"2021-11-10 15:17:21"
Level	0
Status	"Off"
idx	"658565"
59
Data	"On"
Date	"2021-11-10 14:57:21"
Level	0
Status	"On"
idx	"658542"
60
Data	"Off"
Date	"2021-11-10 14:37:21"
Level	0
Status	"Off"
idx	"658503"
61
Data	"On"
Date	"2021-11-10 14:17:21"
Level	0
Status	"On"
idx	"658469"
62
Data	"Off"
Date	"2021-11-10 13:49:22"
Level	0
Status	"Off"
idx	"658447"
63
Data	"On"
Date	"2021-11-10 13:29:22"
Level	0
Status	"On"
idx	"658401"
64
Data	"Off"
Date	"2021-11-10 12:50:02"
Level	0
Status	"Off"
idx	"658356"
65
Data	"On"
Date	"2021-11-10 12:29:22"
Level	0
Status	"On"
idx	"658344"
66
Data	"Off"
Date	"2021-11-10 11:45:23"
Level	0
Status	"Off"
idx	"658233"
67
Data	"On"
Date	"2021-11-10 11:25:23"
Level	0
Status	"On"
idx	"658208"
68
Data	"Off"
Date	"2021-11-10 10:17:24"
Level	0
Status	"Off"
idx	"658100"
69
Data	"On"
Date	"2021-11-10 09:57:24"
Level	0
Status	"On"
idx	"658035"
70
Data	"Off"
Date	"2021-11-10 08:41:25"
Level	0
Status	"Off"
idx	"657841"
71
Data	"On"
Date	"2021-11-10 08:21:25"
Level	0
Status	"On"
idx	"657773"
72
Data	"Off"
Date	"2021-11-10 08:00:46"
Level	0
Status	"Off"
User	"Admin (IP: 192.168.88.190)"
idx	"657692"
73
Data	"On"
Date	"2021-11-10 07:28:42"
Level	0
Status	"On"
idx	"657588"
74
Data	"Off"
Date	"2021-11-09 22:29:32"
Level	0
Status	"Off"
idx	"657372"
75
Data	"On"
Date	"2021-11-09 22:09:32"
Level	0
Status	"On"
idx	"657332"
76
Data	"Off"
Date	"2021-11-09 21:48:21"
Level	0
Status	"Off"
idx	"657287"
77
Data	"On"
Date	"2021-11-09 21:27:55"
Level	0
Status	"On"
idx	"657253"
78
Data	"Off"
Date	"2021-11-09 21:07:51"
Level	0
Status	"Off"
idx	"657210"
79
Data	"On"
Date	"2021-11-09 20:46:41"
Level	0
Status	"On"
idx	"657157"
80
Data	"Off"
Date	"2021-11-09 20:26:21"
Level	0
Status	"Off"
idx	"657094"
81
Data	"On"
Date	"2021-11-09 20:06:15"
Level	0
Status	"On"
idx	"657018"
82
Data	"Off"
Date	"2021-11-09 19:03:01"
Level	0
Status	"Off"
idx	"656930"
83
Data	"On"
Date	"2021-11-09 18:41:35"
Level	0
Status	"On"
idx	"656877"
84
Data	"Off"
Date	"2021-11-09 18:21:35"
Level	0
Status	"Off"
idx	"656841"
85
Data	"On"
Date	"2021-11-09 18:01:35"
Level	0
Status	"On"
idx	"656799"
86
Data	"Off"
Date	"2021-11-09 17:41:35"
Level	0
Status	"Off"
idx	"656754"
87
Data	"On"
Date	"2021-11-09 17:21:33"
Level	0
Status	"On"
idx	"656714"
88
Data	"Off"
Date	"2021-11-09 17:00:49"
Level	0
Status	"Off"
idx	"656660"
89
Data	"On"
Date	"2021-11-09 16:40:25"
Level	0
Status	"On"
idx	"656595"
90
Data	"Off"
Date	"2021-11-09 16:20:02"
Level	0
Status	"Off"
idx	"656577"
91
Data	"On"
Date	"2021-11-09 16:05:02"
Level	0
Status	"On"
idx	"656556"
92
Data	"Off"
Date	"2021-11-09 15:45:02"
Level	0
Status	"Off"
idx	"656521"
93
Data	"On"
Date	"2021-11-09 15:25:02"
Level	0
Status	"On"
idx	"656488"
94
Data	"Off"
Date	"2021-11-09 15:05:02"
Level	0
Status	"Off"
idx	"656458"
95
Data	"On"
Date	"2021-11-09 14:45:02"
Level	0
Status	"On"
idx	"656435"
96
Data	"Off"
Date	"2021-11-09 14:25:01"
Level	0
Status	"Off"
idx	"656404"
97
Data	"On"
Date	"2021-11-09 14:02:55"
Level	0
Status	"On"
idx	"656372"
98
Data	"Off"
Date	"2021-11-09 13:37:38"
Level	0
Status	"Off"
idx	"656345"
99
Data	"On"
Date	"2021-11-09 13:16:09"
Level	0
Status	"On"
idx	"656328"
100
Data	"Off"
Date	"2021-11-09 08:55:01"
Level	0
Status	"Off"
idx	"656218"
101
Data	"On"
Date	"2021-11-09 08:53:41"
Level	0
Status	"On"
idx	"656210"
102
Data	"Off"
Date	"2021-11-09 08:33:41"
Level	0
Status	"Off"
idx	"656133"
103
Data	"On"
Date	"2021-11-09 08:13:28"
Level	0
Status	"On"
idx	"656080"
104
Data	"Off"
Date	"2021-11-08 23:37:47"
Level	0
Status	"Off"
idx	"655906"
105
Data	"On"
Date	"2021-11-08 23:16:47"
Level	0
Status	"On"
idx	"655883"
106
Data	"Off"
Date	"2021-11-08 22:38:35"
Level	0
Status	"Off"
idx	"655818"
107
Data	"On"
Date	"2021-11-08 22:30:02"
Level	0
Status	"On"
idx	"655790"
108
Data	"Off"
Date	"2021-11-08 22:10:02"
Level	0
Status	"Off"
idx	"655744"
109
Data	"On"
Date	"2021-11-08 21:50:02"
Level	0
Status	"On"
idx	"655704"
110
Data	"Off"
Date	"2021-11-08 21:30:02"
Level	0
Status	"Off"
idx	"655651"
111
Data	"On"
Date	"2021-11-08 21:10:02"
Level	0
Status	"On"
idx	"655607"
112
Data	"Off"
Date	"2021-11-08 20:50:01"
Level	0
Status	"Off"
idx	"655515"
113
Data	"On"
Date	"2021-11-08 20:29:54"
Level	0
Status	"On"
idx	"655452"
114
Data	"Off"
Date	"2021-11-08 20:09:50"
Level	0
Status	"Off"
idx	"655393"
115
Data	"On"
Date	"2021-11-08 19:49:50"
Level	0
Status	"On"
idx	"655370"
116
Data	"Off"
Date	"2021-11-08 19:29:50"
Level	0
Status	"Off"
idx	"655299"
117
Data	"On"
Date	"2021-11-08 19:09:11"
Level	0
Status	"On"
idx	"655215"
118
Data	"Off"
Date	"2021-11-08 18:37:51"
Level	0
Status	"Off"
idx	"655121"
119
Data	"On"
Date	"2021-11-08 18:17:51"
Level	0
Status	"On"
idx	"655095"
120
Data	"Off"
Date	"2021-11-08 17:57:51"
Level	0
Status	"Off"
idx	"655079"
121
Data	"On"
Date	"2021-11-08 17:37:51"
Level	0
Status	"On"
idx	"655053"
122
Data	"Off"
Date	"2021-11-08 17:15:02"
Level	0
Status	"Off"
idx	"654981"
123
Data	"On"
Date	"2021-11-08 16:55:02"
Level	0
Status	"On"
idx	"654931"
124
Data	"Off"
Date	"2021-11-08 16:35:02"
Level	0
Status	"Off"
idx	"654883"
125
Data	"On"
Date	"2021-11-08 16:15:02"
Level	0
Status	"On"
idx	"654854"
126
Data	"Off"
Date	"2021-11-08 15:55:01"
Level	0
Status	"Off"
idx	"654826"
127
Data	"On"
Date	"2021-11-08 15:33:53"
Level	0
Status	"On"
idx	"654785"
128
Data	"Off"
Date	"2021-11-08 15:13:53"
Level	0
Status	"Off"
idx	"654767"
129
Data	"On"
Date	"2021-11-08 14:53:53"
Level	0
Status	"On"
idx	"654713"
130
Data	"Off"
Date	"2021-11-08 14:33:53"
Level	0
Status	"Off"
idx	"654672"
131
Data	"On"
Date	"2021-11-08 14:11:24"
Level	0
Status	"On"
idx	"654637"
132
Data	"Off"
Date	"2021-11-08 10:02:48"
Level	0
Status	"Off"
idx	"654460"
133
Data	"On"
Date	"2021-11-08 09:41:57"
Level	0
Status	"On"
idx	"654397"
134
Data	"Off"
Date	"2021-11-08 09:21:57"
Level	0
Status	"Off"
idx	"654344"
135
Data	"On"
Date	"2021-11-08 09:00:04"
Level	0
Status	"On"
idx	"654285"
136
Data	"Off"
Date	"2021-11-08 08:40:01"
Level	0
Status	"Off"
idx	"654230"
137
Data	"On"
Date	"2021-11-08 08:19:16"
Level	0
Status	"On"
idx	"654186"
138
Data	"Off"
Date	"2021-11-07 23:09:46"
Level	0
Status	"Off"
idx	"654004"
139
Data	"On"
Date	"2021-11-07 23:02:04"
Level	0
Status	"On"
idx	"653968"
140
Data	"Off"
Date	"2021-11-07 22:41:22"
Level	0
Status	"Off"
idx	"653904"
141
Data	"On"
Date	"2021-11-07 22:20:15"
Level	0
Status	"On"
idx	"653827"
142
Data	"Off"
Date	"2021-11-07 22:00:03"
Level	0
Status	"Off"
idx	"653773"
143
Data	"On"
Date	"2021-11-07 21:40:02"
Level	0
Status	"On"
idx	"653711"
144
Data	"Off"
Date	"2021-11-07 21:19:59"
Level	0
Status	"Off"
idx	"653622"
145
Data	"On"
Date	"2021-11-07 20:59:55"
Level	0
Status	"On"
idx	"653558"
146
Data	"Off"
Date	"2021-11-07 20:39:22"
Level	0
Status	"Off"
idx	"653461"
147
Data	"On"
Date	"2021-11-07 20:18:06"
Level	0
Status	"On"
idx	"653413"
148
Data	"Off"
Date	"2021-11-07 19:58:06"
Level	0
Status	"Off"
idx	"653358"
149
Data	"On"
Date	"2021-11-07 19:38:06"
Level	0
Status	"On"
idx	"653293"
150
Data	"Off"
Date	"2021-11-07 19:18:06"
Level	0
Status	"Off"
idx	"653226"
151
Data	"On"
Date	"2021-11-07 18:43:22"
Level	0
Status	"On"
idx	"653134"
152
Data	"Off"
Date	"2021-11-07 12:30:02"
Level	0
Status	"Off"
idx	"652845"
153
Data	"On"
Date	"2021-11-07 12:10:01"
Level	0
Status	"On"
idx	"652767"
154
Data	"Off"
Date	"2021-11-07 11:40:01"
Level	0
Status	"Off"
idx	"652724"
155
Data	"On"
Date	"2021-11-07 11:19:55"
Level	0
Status	"On"
idx	"652675"
156
Data	"Off"
Date	"2021-11-06 21:27:22"
Level	0
Status	"Off"
idx	"652312"
157
Data	"On"
Date	"2021-11-06 21:14:21"
Level	0
Status	"On"
idx	"652277"
158
Data	"Off"
Date	"2021-11-06 20:54:21"
Level	0
Status	"Off"
idx	"652236"
159
Data	"On"
Date	"2021-11-06 20:34:21"
Level	0
Status	"On"
idx	"652134"
160
Data	"Off"
Date	"2021-11-06 20:12:57"
Level	0
Status	"Off"
idx	"652080"
161
Data	"On"
Date	"2021-11-06 19:48:10"
Level	0
Status	"On"
idx	"652014"
162
Data	"Off"
Date	"2021-11-06 19:46:22"
Level	0
Status	"Off"
idx	"651993"
163
Data	"On"
Date	"2021-11-06 19:44:12"
Level	0
Status	"On"
User	"domoticaadmin (IP: 49.230.10.112)"
idx	"651989"
164
Data	"Off"
Date	"2021-11-06 13:45:02"
Level	0
Status	"Off"
idx	"651738"
165
Data	"On"
Date	"2021-11-06 13:25:01"
Level	0
Status	"On"
idx	"651700"
166
Data	"Off"
Date	"2021-11-06 13:04:59"
Level	0
Status	"Off"
idx	"651638"
167
Data	"On"
Date	"2021-11-06 12:44:59"
Level	0
Status	"On"
idx	"651596"
168
Data	"Off"
Date	"2021-11-06 12:20:02"
Level	0
Status	"Off"
idx	"651576"
169
Data	"On"
Date	"2021-11-06 12:18:27"
Level	0
Status	"On"
idx	"651565"
170
Data	"Off"
Date	"2021-11-06 11:58:27"
Level	0
Status	"Off"
idx	"651461"
171
Data	"On"
Date	"2021-11-06 11:36:45"
Level	0
Status	"On"
idx	"651415"
172
Data	"Off"
Date	"2021-11-06 00:34:43"
Level	0
Status	"Off"
idx	"651188"
173
Data	"On"
Date	"2021-11-06 00:26:35"
Level	0
Status	"On"
idx	"651146"
174
Data	"Off"
Date	"2021-11-06 00:01:53"
Level	0
Status	"Off"
idx	"651086"
175
Data	"On"
Date	"2021-11-05 23:01:51"
Level	0
Status	"On"
idx	"650865"
176
Data	"Off"
Date	"2021-11-05 22:45:02"
Level	0
Status	"Off"
idx	"650803"
177
Data	"On"
Date	"2021-11-05 22:25:01"
Level	0
Status	"On"
idx	"650751"
178
Data	"Off"
Date	"2021-11-05 22:02:37"
Level	0
Status	"Off"
idx	"650695"
179
Data	"On"
Date	"2021-11-05 21:42:37"
Level	0
Status	"On"
idx	"650647"
180
Data	"Off"
Date	"2021-11-05 21:22:37"
Level	0
Status	"Off"
idx	"650609"
181
Data	"On"
Date	"2021-11-05 21:02:37"
Level	0
Status	"On"
idx	"650569"
182
Data	"Off"
Date	"2021-11-05 20:42:37"
Level	0
Status	"Off"
idx	"650530"
183
Data	"On"
Date	"2021-11-05 20:21:11"
Level	0
Status	"On"
idx	"650499"
184
Data	"Off"
Date	"2021-11-05 18:19:58"
Level	0
Status	"Off"
idx	"650338"
185
Data	"On"
Date	"2021-11-05 18:10:39"
Level	0
Status	"On"
idx	"650312"
186
Data	"Off"
Date	"2021-11-05 17:50:39"
Level	0
Status	"Off"
idx	"650245"
187
Data	"On"
Date	"2021-11-05 17:30:02"
Level	0
Status	"On"
idx	"650198"
188
Data	"Off"
Date	"2021-11-05 17:10:02"
Level	0
Status	"Off"
idx	"650145"
189
Data	"On"
Date	"2021-11-05 16:50:02"
Level	0
Status	"On"
idx	"650091"
190
Data	"Off"
Date	"2021-11-05 16:30:02"
Level	0
Status	"Off"
idx	"650053"
191
Data	"On"
Date	"2021-11-05 16:10:02"
Level	0
Status	"On"
idx	"650025"
192
Data	"Off"
Date	"2021-11-05 15:50:02"
Level	0
Status	"Off"
idx	"649998"
193
Data	"On"
Date	"2021-11-05 15:30:02"
Level	0
Status	"On"
idx	"649964"
194
Data	"Off"
Date	"2021-11-05 15:10:02"
Level	0
Status	"Off"
idx	"649928"
195
Data	"On"
Date	"2021-11-05 14:50:02"
Level	0
Status	"On"
idx	"649892"
196
Data	"Off"
Date	"2021-11-05 14:30:02"
Level	0
Status	"Off"
idx	"649868"
197
Data	"On"
Date	"2021-11-05 14:10:02"
Level	0
Status	"On"
idx	"649817"
198
Data	"Off"
Date	"2021-11-05 13:50:02"
Level	0
Status	"Off"
idx	"649784"
199
Data	"On"
Date	"2021-11-05 13:30:02"
Level	0
Status	"On"
idx	"649739"
200
Data	"Off"
Date	"2021-11-05 13:10:02"
Level	0
Status	"Off"
idx	"649714"
201
Data	"On"
Date	"2021-11-05 12:50:02"
Level	0
Status	"On"
idx	"649698"
202
Data	"Off"
Date	"2021-11-05 12:30:02"
Level	0
Status	"Off"
idx	"649680"
203
Data	"On"
Date	"2021-11-05 12:07:25"
Level	0
Status	"On"
idx	"649651"
204
Data	"Off"
Date	"2021-11-05 00:02:01"
Level	0
Status	"Off"
idx	"649325"
205
Data	"On"
Date	"2021-11-04 23:50:02"
Level	0
Status	"On"
idx	"649266"
206
Data	"Off"
Date	"2021-11-04 23:30:02"
Level	0
Status	"Off"
idx	"649222"
207
Data	"On"
Date	"2021-11-04 23:10:01"
Level	0
Status	"On"
idx	"649149"
208
Data	"Off"
Date	"2021-11-04 22:49:14"
Level	0
Status	"Off"
idx	"649078"
209
Data	"On"
Date	"2021-11-04 22:28:21"
Level	0
Status	"On"
User	"Admin (IP: 192.168.88.193)"
idx	"648997"
210
Data	"Off"
Date	"2021-11-04 22:10:28"
Level	0
Status	"Off"
idx	"648952"
211
Data	"On"
Date	"2021-11-04 22:02:53"
Level	0
Status	"On"
idx	"648923"
212
Data	"Off"
Date	"2021-11-04 21:42:53"
Level	0
Status	"Off"
idx	"648852"
213
Data	"On"
Date	"2021-11-04 21:22:20"
Level	0
Status	"On"
idx	"648759"
214
Data	"Off"
Date	"2021-11-04 14:44:50"
Level	0
Status	"Off"
idx	"648460"
215
Data	"On"
Date	"2021-11-04 14:26:58"
Level	0
Status	"On"
idx	"648428"
216
Data	"Off"
Date	"2021-11-04 14:05:02"
Level	0
Status	"Off"
idx	"648412"
217
Data	"On"
Date	"2021-11-04 13:45:02"
Level	0
Status	"On"
idx	"648390"
218
Data	"Off"
Date	"2021-11-04 13:22:59"
Level	0
Status	"Off"
idx	"648355"
219
Data	"On"
Date	"2021-11-04 13:02:59"
Level	0
Status	"On"
idx	"648331"
220
Data	"Off"
Date	"2021-11-04 12:42:59"
Level	0
Status	"Off"
idx	"648320"
221
Data	"On"
Date	"2021-11-04 12:22:59"
Level	0
Status	"On"
idx	"648306"
222
Data	"Off"
Date	"2021-11-04 11:55:02"
Level	0
Status	"Off"
idx	"648287"
223
Data	"On"
Date	"2021-11-04 11:35:00"
Level	0
Status	"On"
idx	"648270"
224
Data	"Off"
Date	"2021-11-04 11:07:00"
Level	0
Status	"Off"
idx	"648251"
225
Data	"On"
Date	"2021-11-04 10:47:00"
Level	0
Status	"On"
idx	"648237"
226
Data	"Off"
Date	"2021-11-04 10:19:01"
Level	0
Status	"Off"
idx	"648223"
227
Data	"On"
Date	"2021-11-04 09:59:01"
Level	0
Status	"On"
idx	"648204"
228
Data	"Off"
Date	"2021-11-04 09:31:01"
Level	0
Status	"Off"
idx	"648185"
229
Data	"On"
Date	"2021-11-04 09:11:01"
Level	0
Status	"On"
idx	"648171"
230
Data	"Off"
Date	"2021-11-04 08:35:12"
Level	0
Status	"Off"
idx	"648145"
231
Data	"On"
Date	"2021-11-04 08:20:08"
Level	0
Status	"On"
idx	"648095"
232
Data	"Off"
Date	"2021-11-04 08:05:02"
Level	0
Status	"Off"
idx	"648022"
233
Data	"On"
Date	"2021-11-04 07:45:02"
Level	0
Status	"On"
idx	"647980"
234
Data	"Off"
Date	"2021-11-03 22:47:08"
Level	0
Status	"Off"
idx	"647541"
235
Data	"On"
Date	"2021-11-03 22:27:08"
Level	0
Status	"On"
idx	"647480"
236
Data	"Off"
Date	"2021-11-03 22:03:09"
Level	0
Status	"Off"
idx	"647393"
237
Data	"On"
Date	"2021-11-03 21:43:09"
Level	0
Status	"On"
idx	"647351"
238
Data	"Off"
Date	"2021-11-03 21:23:09"
Level	0
Status	"Off"
idx	"647319"
239
Data	"On"
Date	"2021-11-03 21:03:09"
Level	0
Status	"On"
idx	"647279"
240
Data	"Off"
Date	"2021-11-03 20:43:09"
Level	0
Status	"Off"
idx	"647218"
241
Data	"On"
Date	"2021-11-03 20:22:29"
Level	0
Status	"On"
idx	"647176"
242
Data	"Off"
Date	"2021-11-03 18:00:03"
Level	0
Status	"Off"
idx	"646975"
243
Data	"On"
Date	"2021-11-03 17:39:12"
Level	0
Status	"On"
idx	"646934"
244
Data	"Off"
Date	"2021-11-03 17:19:12"
Level	0
Status	"Off"
idx	"646887"
245
Data	"On"
Date	"2021-11-03 16:59:12"
Level	0
Status	"On"
idx	"646843"
246
Data	"Off"
Date	"2021-11-03 16:37:21"
Level	0
Status	"Off"
idx	"646773"
247
Data	"On"
Date	"2021-11-03 16:15:13"
Level	0
Status	"On"
idx	"646707"
248
Data	"Off"
Date	"2021-11-03 15:55:13"
Level	0
Status	"Off"
idx	"646635"
249
Data	"On"
Date	"2021-11-03 15:35:13"
Level	0
Status	"On"
idx	"646609"
250
Data	"Off"
Date	"2021-11-03 15:15:13"
Level	0
Status	"Off"
idx	"646553"
251
Data	"On"
Date	"2021-11-03 14:55:13"
Level	0
Status	"On"
idx	"646526"
252
Data	"Off"
Date	"2021-11-03 14:31:14"
Level	0
Status	"Off"
idx	"646504"
253
Data	"On"
Date	"2021-11-03 14:11:14"
Level	0
Status	"On"
idx	"646490"
254
Data	"Off"
Date	"2021-11-03 13:47:14"
Level	0
Status	"Off"
idx	"646455"
255
Data	"On"
Date	"2021-11-03 13:25:42"
Level	0
Status	"On"
idx	"646420"
256
Data	"Off"
Date	"2021-11-03 12:39:15"
Level	0
Status	"Off"
idx	"646355"
257
Data	"On"
Date	"2021-11-03 12:19:15"
Level	0
Status	"On"
idx	"646349"
258
Data	"Off"
Date	"2021-11-03 11:47:16"
Level	0
Status	"Off"
idx	"646334"
259
Data	"On"
Date	"2021-11-03 11:27:16"
Level	0
Status	"On"
idx	"646330"
260
Data	"Off"
Date	"2021-11-03 11:06:30"
Level	0
Status	"Off"
idx	"646310"
261
Data	"On"
Date	"2021-11-03 10:55:16"
Level	0
Status	"On"
idx	"646293"
262
Data	"Off"
Date	"2021-11-03 09:43:17"
Level	0
Status	"Off"
idx	"646201"
263
Data	"On"
Date	"2021-11-03 09:23:17"
Level	0
Status	"On"
idx	"646187"
264
Data	"Off"
Date	"2021-11-03 08:39:18"
Level	0
Status	"Off"
idx	"646134"
265
Data	"On"
Date	"2021-11-03 08:19:10"
Level	0
Status	"On"
idx	"646095"
266
Data	"Off"
Date	"2021-11-03 07:09:01"
Level	0
Status	"Off"
idx	"645993"
267
Data	"On"
Date	"2021-11-03 07:07:57"
Level	0
Status	"On"
idx	"645982"
268
Data	"Off"
Date	"2021-11-02 23:31:24"
Level	0
Status	"Off"
idx	"645855"
269
Data	"On"
Date	"2021-11-02 23:11:24"
Level	0
Status	"On"
idx	"645786"
270
Data	"Off"
Date	"2021-11-02 22:36:22"
Level	0
Status	"Off"
idx	"645679"
271
Data	"On"
Date	"2021-11-02 22:15:35"
Level	0
Status	"On"
idx	"645607"
272
Data	"Off"
Date	"2021-11-02 21:25:04"
Level	0
Status	"Off"
idx	"645517"
273
Data	"On"
Date	"2021-11-02 21:11:25"
Level	0
Status	"On"
idx	"645487"
274
Data	"Off"
Date	"2021-11-02 20:43:26"
Level	0
Status	"Off"
idx	"645409"
275
Data	"On"
Date	"2021-11-02 20:23:26"
Level	0
Status	"On"
idx	"645347"
276
Data	"Off"
Date	"2021-11-02 20:02:45"
Level	0
Status	"Off"
idx	"645262"
277
Data	"On"
Date	"2021-11-02 19:42:11"
Level	0
Status	"On"
idx	"645202"
278
Data	"Off"
Date	"2021-11-02 16:47:28"
Level	0
Status	"Off"
idx	"644876"
279
Data	"On"
Date	"2021-11-02 16:27:28"
Level	0
Status	"On"
idx	"644831"
280
Data	"Off"
Date	"2021-11-02 16:03:29"
Level	0
Status	"Off"
idx	"644774"
281
Data	"On"
Date	"2021-11-02 15:43:29"
Level	0
Status	"On"
idx	"644747"
282
Data	"Off"
Date	"2021-11-02 15:20:02"
Level	0
Status	"Off"
idx	"644714"
283
Data	"On"
Date	"2021-11-02 14:59:30"
Level	0
Status	"On"
idx	"644686"
284
Data	"Off"
Date	"2021-11-02 14:39:30"
Level	0
Status	"Off"
idx	"644652"
285
Data	"On"
Date	"2021-11-02 14:19:30"
Level	0
Status	"On"
idx	"644636"
286
Data	"Off"
Date	"2021-11-02 13:59:30"
Level	0
Status	"Off"
idx	"644607"
287
Data	"On"
Date	"2021-11-02 13:37:19"
Level	0
Status	"On"
idx	"644580"
288
Data	"Off"
Date	"2021-11-02 12:52:59"
Level	0
Status	"Off"
idx	"644527"
289
Data	"On"
Date	"2021-11-02 12:47:31"
Level	0
Status	"On"
idx	"644511"
290
Data	"Off"
Date	"2021-11-02 11:25:02"
Level	0
Status	"Off"
idx	"644463"
291
Data	"On"
Date	"2021-11-02 11:04:07"
Level	0
Status	"On"
idx	"644437"
292
Data	"Off"
Date	"2021-11-02 10:03:33"
Level	0
Status	"Off"
-----------<had to truncate otherwise to many characters in a post>
title	"LightLog"
i made a virtual dimmer dev and use this code as a workaround, that works;
if (ac.state == 'On') then
        aclvl.setLevel(100)
    elseif (ac.state == 'Off') then
        aclvl.setLevel(0)
Lokonli
Post by Lokonli »
As you see the Data is reported as On and Off, but the level always is 0. That explains what we see. (and indeed, a virtual dimmer is a workaround)
I've to think of a way how to determine automatically whether to use the Level values or the Data values.
Probably we should use the Data values in case the Level values don't change.
I'll do some tests...
Lokonli
Post by Lokonli »
brandsrus wrote: Wednesday 27 October 2021 14:19 Traffic Block:
Fixed in latest beta.
Including a block parameter to show/hide empty roads.
See: https://dashticz.readthedocs.io/en/beta ... rafficinfo
