Moes BRT-100-TRV
Posted: Thursday 21 October 2021 21:51
by har0543
I have a Moes BRT-100-TRV, a Thermostatic radiator valve.
It works in the Tuya smart life app.
In the domoticz plugin it is found but not correct:TS0601 - EndDevice
In zigbee2mqtt there is an item about it:
https://github.com/Koenkk/zigbee2mqtt/issues/3821
But I can not figure out what to with it in domoticz.
Any ideas?
Har
Re: Moes BRT-100-TRV
Posted: Friday 22 October 2021 8:42
by pipiche
Are you using z2m or an other gateway ?
Posted: Friday 22 October 2021 17:24
by har0543
I am using v.1.19.1 (zStack12 20201127) zigbee2mqtt
Posted: Friday 22 October 2021 18:09
Posted: Sunday 24 October 2021 15:03
by har0543
should but is not the case
Posted: Monday 25 October 2021 1:20
In this discussion it paired without issues:
https://github.com/Koenkk/zigbee2mqtt/discussions/9155
Perhaps try again to pair and keep the thermostat close to the ZigBee USB stick.
Posted: Wednesday 06 September 2023 9:26
by Patricen
Can this device operate with Conbee II?
Posted: Wednesday 06 September 2023 10:41
Patricen wrote: Wednesday 06 September 2023 9:26
That mostly depends on the controller/plugin software you use, Deconz, Zigbee2MQTT, Zigbee4Domoticz.
Checkout the appropriate repository for supported devices.
The problem is that each stick can zigbee pair with it but the information has to be rendered correctly into Domoticz devices. If a device is not known yet it could lead to incorrect behavior. Make an issue then on the plugin software to get it correctly supported.
Posted: Wednesday 06 September 2023 10:49
by Patricen
I'm currently using Deconz but it looks like setting up a mqtt broker would be a good migration for both Z-wave and Zigbee networks,
I would then be using Zigbee 2mqtt if I understand well.
Posted: Wednesday 06 September 2023 11:18
by pipiche
otherwise you can use Zigbee4Domiticz plugin with the deConz and you don't need any middleware like a mqttbroker
