Check status (ON/OFF) of dummy switch from Node-Red Topic is solved
marmachine
Domoticz version: 3.4834
Post by marmachine »
I am working on some functionality in Node-Red.
I have a motion sensor that switches the light on and off through my script.
Now i want to check status of a dummy switch in Domoticz before actually switching the light, because i may want to prevent automatically switching.
I've reached the end of internet, maybe i've overlooked, but i have not found anything that would help me.
I think that it would be fastest to send an MQTT request to Domoticz/in topic to obtain info about IDX 62 but how can i catch the response? Lost :(
jvdz
Domoticz version: 4.107
Re: Check status (ON/OFF) of dummy switch from Node-Red
Post by jvdz »
In Node-Red you can easily get the status of a switch by doing an json call: http://127.0.0.1:8080/json.htm?type=devices&rid=192
(Change 192 to the appropriate IDX in your system and change the ip address in case it runs on another server)
Then in Nodered you can perform that JSON call and test the result in a formula block.
Example get the Data field which will be either "On" or "Off"... when "Off" it sets the msg to null making the flow stop, but you can use your own logic there.
[{"id":"67c37422.c6a7bc","type":"http request","z":"dbd5d34b.5859c","name":"Get device info","method":"GET","ret":"txt","paytoqs":"ignore","url":"http://127.0.0.1:8080/json.htm?type=devices&rid=192","tls":"","persist":false,"proxy":"","authType":"","x":279.00000762939453,"y":372.00000286102295,"wires":[["aa1d1dde.94931"]]},{"id":"aa1d1dde.94931","type":"json","z":"dbd5d34b.5859c","name":"","property":"payload","action":"","pretty":false,"x":424.43359756469727,"y":370.6333055496216,"wires":[["7c0dcf64.2b72e"]]},{"id":"7c0dcf64.2b72e","type":"function","z":"dbd5d34b.5859c","name":"get Switch state","func":"if (msg.payload.result[0].Data == \"Off\") {\n    msg = null;\n}\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":578.9335556030273,"y":370.6333065032959,"wires":[["c8db0f94.c4e49"]]},{"id":"b97c7c56.c4091","type":"inject","z":"dbd5d34b.5859c","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":116.60000610351562,"y":371.0000047683716,"wires":[["67c37422.c6a7bc"]]},{"id":"c8db0f94.c4e49","type":"debug","z":"dbd5d34b.5859c","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":766.6000595092773,"y":370.0000047683716,"wires":[]}]
Jos
marmachine
Thanks, that's very helpfull! I guess this could work, so i'll play with it. :ugeek:
