zwave dead
Posted: Sunday 19 September 2021 12:34
by megamarco83
hi, i was on domoticz stable version and i was using zwave since long time without issue.
Since yesterday my devices have been hot responding anymore.
i try to update to latest beta version but it not change.
i see that in harware page the zwave config button is become red (it was blue)
Immagine 2021-09-19 122714.jpg (101.59 KiB) Viewed 931 times
i have razberry zwave GPIO board 1st version.
i created bot ttyAMA0 and also ttyUSB0
the one that was working is ttyAMA0
today i create the ttyUSB0 but nothing change: configuration button still red and device are not responding:
Immagine 2021-09-19 123334.jpg (116.51 KiB) Viewed 931 times
this is the log:
2021-09-19 12:21:24.302 Active notification Subsystems: (0/13)
2021-09-19 12:21:24.328 Starting shared server on: :::6144
2021-09-19 12:21:24.216 Status: Domoticz V2021.1 (build 13499) (c)2012-2021 GizMoCuz
2021-09-19 12:21:24.216 Status: Build Hash: eee4de721, Date: 2021-09-16 07:36:53
2021-09-19 12:21:24.217 Status: Startup Path: /home/pi/domoticz/
2021-09-19 12:21:24.284 Status: PluginSystem: Failed dynamic library load, install the latest libpython3.x library that is available for your platform.
2021-09-19 12:21:24.305 Status: WebServer(HTTP) started on address: :: with port 8080
2021-09-19 12:21:24.321 Status: WebServer(SSL) started on address: :: with port 443
2021-09-19 12:21:24.330 Status: TCPServer: shared server started...
2021-09-19 12:21:24.330 Status: RxQueue: queue worker started...
2021-09-19 12:21:26.332 Status: NotificationSystem: thread started...
2021-09-19 12:21:26.333 Status: EventSystem: reset all events...
2021-09-19 12:21:26.336 Status: EventSystem: reset all device statuses...
2021-09-19 12:21:26.352 Status: EventSystem - Python: Failed dynamic library load, install the latest libpython3.x library that is available for your platform.
2021-09-19 12:21:26.353 Status: EventSystem: Started
2021-09-19 12:21:26.354 Status: EventSystem: Queue thread started...
2021-09-19 12:21:26.833 Status: OpenZWave: using config in: /home/pi/domoticz/Config/
2021-09-19 12:21:26.962 Status: OpenZWave: Starting...
2021-09-19 12:21:26.962 Status: OpenZWave: Version: 1.6-1911-gc6a420ef
2021-09-19 12:21:27.332 Status: MQTT: Connecting to 192.168.1.110:1883
2021-09-19 12:21:27.534 Status: MQTT: connected to: 192.168.1.110:1883
2021-09-19 12:21:30.437 Status: OpenZWave: A DNS Error Occurred
2021-09-19 12:21:30.437 Status: OpenZWave: ManufacturerSpecificDB Ready
2021-09-19 12:21:31.439 Error: OpenZWave: Type_Notification, NodeID not found internally!. HomeID: 0, NodeID: 255 (0xff)
what i should do?
thanks, regards
p.s. i also try to update the razberry zwave firmware to last version 3.2 it succeed but still not working.
thanks
Re: zwave dead
Posted: Sunday 19 September 2021 13:16
by heggink
If your zwave was working, why did you switch? Zwavejs is only recommended if people have issues.
I would:
1) go back to zwave if that worked
2) if you want to keep zwavejs, start with checking if that works itself (does thw web interface show? Can you see / switch devices?)
Then check if mqtt receives device updates
Then check the domoticz plugin
Re: zwave dead
Posted: Sunday 19 September 2021 13:52
by megamarco83
heggink wrote: Sunday 19 September 2021 13:16 If your zwave was working, why did you switch? Zwavejs is only recommended if people have issues.
I would:
Unfortunately i do not nothing... I don't update nothing and i don't change nothing BUT The only things that i do was switch off raspberry and take the SD to backup it.
Here (blame on me) when i put again the SD i connect the GPIO of zwave raZberry on wrong position (i move forward a raw) i immediately recognize it and disconnect the GPIO and connect again correctly.
I think that the pcb module of zwave is working because I installed on another SD card the raZberry image downloaded from zwave website and i try tu update latest fw to last version 3.2 and it works. So i guess and hope that the moddule is working.
Then i restore my SD with donoticz (that was working) but i have the configuration button red insted of blue and devices that are not been responding.
What do you suggest?
What's the zwavejs?
And what i should do to check the domoticz plugin you are referring to?
Re: zwave dead
Posted: Sunday 19 September 2021 14:29
by heggink
Ah, my bad. I mistakenly thought you were responding to the zwavejs2mqtt thread. Apologies.
