Is it possible to have two Domoticz Servers running, not in an master slave configuration, to one MQTT mosquitto Server and have all IDX numbers the same or most of it? I think both Domoticz will use the same domoticz/in and out or not?
I want to publish with a script to the same IDX number on both servers for example a switch or text device.
Two Domoticz Servers to one MQTT server
Re: Two Domoticz Servers to one MQTT server
Never done it, but it seems simple.
Create all devices on 1 server and then copy the database to the second server.
I am thinking about a second Raspberry Pi, if it should work on the same Raspberry you have to change portnumbers.
jarmoboy
- Domoticz version: v2022.2
HI,
Iam not sure what is your goal so than is bit hard to give an advice. Second, to start 2 clone versions of Domoticz may be possible but hard to manage in future. Other question is why?
jarmo
jarmo
DOCKERED v14824,NODE-RED,Tasmotized Sonoffs,Tasmoadmin,zigbee2mqtt,EWPE,REST980,WLED
Users browsing this forum: willemd and 1 guest
