Is possible toto send to Bravia an IRCC for open a youtube video?
GiovanniG
Post by GiovanniG »
Hi mates, I’ve read a lot of staff and nowhere I’ve found a dscussion about sending a link for open a video in youtube, there is IRCC to open youtube only, but this is a bit useless… as we need to use then emote to tell youtube what it has to do…
My goal is to realize a scenario where I can turn on my TV displaying a fireplace, there is any way I can instruct my bravia to do so? Thank you very much for suggestions!
I’ve read it and found [params], is it possible to forward Youtube parameters to open a link?
That was the example
REST-API HTTP Request Example (Pre-Shared Key: “1234”)
POST /sony/system HTTP/1.1
Host: 192.168.0.1
Accept: */*
Cache-Control: no-cache
Connection: close
Content-Type: application/json; charset=UTF-8
Pragma: no-cache
X-Auth-PSK: 1234
Content-Length: 70
{"method": "getPowerStatus", "params": [], "id": 50, "version": "1.0"}
GiovanniG
Re: Is possible toto send to Bravia an IRCC for open a youtube video?
Post by GiovanniG »
Hi, nobody interested here to switch on TV with a particular video to create a scenario? :(
Domoticz version: 2025.1
If the api is not supporting this, then Domoticz will have an hard time in implementing it ;)
Did you check the api? Did you issue a github issue on that api
Api would be https://github.com/aparraga/braviarc i think?
Edit:
There is a Lua script for bravia (not supporting your functionality) viewtopic.php?f=23&t=8301
There is a plugin (als not supporting your functionality): https://github.com/gerard33/sony-bravia
GiovanniG
Post by GiovanniG »
thank you mate for the links you gave me, I've asked there as well..
That's really strange it's possibile to open youtube but not play a video.. what is the sense to open youtube only? Then I should use the remote..
