Curl is missing in todays docker build
Posted: Saturday 11 September 2021 16:32
by Hartenj
In todays dockerbuild dzVentz scripts reoprt the "curl" missing error. After installing curl in the running container the problem was solved. However this issue will crop up again when not fixed in te build.
Re: Curl is missing in todays docker build
Posted: Monday 13 September 2021 12:52
by jarmoboy
good point, also have the same issue, also iam looking for which build is docekr version and i cant find it, any tips?
Posted: Monday 13 September 2021 12:58
jarmoboy wrote: Monday 13 September 2021 12:52
Go to the tags section
https://hub.docker.com/r/domoticz/domot ... st_updated
Open a image and look for LABEL and see the version
LABEL org.label-schema.version=13496 org.label-schema.build-date=2021-09-10T10:30:59Z
