Curl is missing in todays docker build
Hartenj
Post by Hartenj »
In todays dockerbuild dzVentz scripts reoprt the "curl" missing error. After installing curl in the running container the problem was solved. However this issue will crop up again when not fixed in te build.
jarmoboy
Domoticz version: v2022.2
Re: Curl is missing in todays docker build
Post by jarmoboy »
good point, also have the same issue, also iam looking for which build is docekr version and i cant find it, any tips?
DOCKERED v14824,NODE-RED,Tasmotized Sonoffs,Tasmoadmin,zigbee2mqtt,EWPE,REST980,WLED
Domoticz version: 2025.1
jarmoboy wrote: Monday 13 September 2021 12:52 good point, also have the same issue, also iam looking for which build is docekr version and i cant find it, any tips?
Go to the tags section https://hub.docker.com/r/domoticz/domot ... st_updated
Open a image and look for LABEL and see the version
LABEL org.label-schema.version=13496 org.label-schema.build-date=2021-09-10T10:30:59Z
Users browsing this forum: binbo and 1 guest
