Page 1 of 5
Smartwares introduces 433 thermostat valve
Posted: Sunday 19 October 2014 17:20
by Shaggie_NB
Smartwares introduces 433 thermostat device for Homewizard.
http://www.homewizard.nl/smartwares-dra ... kraan.html
Where there were only thermostatic valves for zwave. Now we have an 433Mhz equivalent.
I hope it will be supported by my RFXTRX433!
Re: Smartwares introduces 433 thermostat valve
Posted: Sunday 19 October 2014 17:57
by SweetPants
Ask Bert of RFXcom first, it al starts there. If The RFXcom does not support it, Domoticz won't either.
Posted: Sunday 19 October 2014 20:33
by drogert
Also cheap! I hope it will be supported...
Posted: Sunday 19 October 2014 21:27
by Shaggie_NB
SweetPants wrote:Ask Bert of RFXcom first, it al starts there. If The RFXcom does not support it, Domoticz won't either.
I follow a lot of forums and when there is a question related to rfxcom, Bert always reacts in a very short time...
So I think he reads almost everything about domotics. So I don't worry.... If he thinks it's interesting then it will be supported.
Posted: Sunday 19 October 2014 21:57
by gizmocuz
Page not found.... (fixed the link)
But always nice to ask directly at RFXCom support department, maybe donate a device ?
Posted: Sunday 19 October 2014 22:15
by Shaggie_NB
gizmocuz wrote:Page not found.... (fixed the link)
And when he decides not to support this device....Then the device is useless (for me). You gonna buy it???
Posted: Sunday 19 October 2014 22:41
by gizmocuz
marktplaats/ebay ?
Posted: Monday 20 October 2014 13:38
by markk
Ooooh. Everything crossed for this one
Posted: Saturday 25 October 2014 19:37
by grant
Did anyone find out if these work?
Posted: Saturday 25 October 2014 23:02
by BigDog
Very interesting wanted te buy them if its suported afcourse
Posted: Monday 27 October 2014 9:48
by gizmocuz
grant wrote:Did anyone find out if these work?
delivery time is 4 weeks, so i guess not
Posted: Monday 27 October 2014 9:50
by BigDog
Wow i am so exited about this
I hope its compactable
Posted: Friday 21 November 2014 8:15
by nitpicker
I hope so too!
Posted: Friday 21 November 2014 13:36
by markk
BigDog wrote:Wow i am so exited about this
+1
I nearly wet myself when I first saw the original post
Posted: Tuesday 16 December 2014 20:45
by Raspberry Piet
Posted: Wednesday 31 December 2014 21:44
by Heisenberg
Something to consider before purchasing this product: if you want to use it in the bedroom then be aware that it makes some noise because it constantly changes the temp wheel. So if you're a light sleeper then maybe it's not suitable for the bedroom.
Posted: Thursday 01 January 2015 0:22
by sylvled
I received it today and ... yes, it is noisy.
Too much for me to put it in a bedroom, I will not say it is suitable for a bedroom.
Fairly tested until now, I could say remote is only to put the device in Day or Night mode (and progrmmation is on the device itself for the temperature of night or day).
Until now, I could receive the lighting 2 frame in Domoticz, but I couldn't set the remote from domoticz because there is not yet the "SmartWares" protocole as far as I know.
In rfxmgr, there is a Smartwares command, but I couldn't find the correct ID and unit code...
I will spend some time in the following days on that and will keep you informed.
Yours. Sylvain.
Posted: Friday 02 January 2015 0:37
by Raspberry Piet
Thanks for this feedback.
So better not for bedroom.
My question: doesn't all electronic thermostate valves produce some noise?
Posted: Friday 02 January 2015 9:25
by gizmocuz
sylvled wrote:Hello,
Yours. Sylvain.
You have to use the latest beta version, and manually add the smartwares radiator (manual light/switch), choose smartwares as protocol
You then receive two sensors, a switch to turn it to day/night, and a thermostat setpoint (utility tab), that you can use to time/set the setpoint
Is it 24/7 noisy ? or only when you change the temperature? (or when it wants to change the temperature)
Posted: Saturday 03 January 2015 20:21
by sylvled
Yes, it is noisy when it wants to change temperature. The motor itself is noisy.
But not only.
It reacts with a BIP to each command sent by the rfxcom OR the remote.
So if you keep the internal programming running, no problem, you will have only the motor. But if you want full remote (forcing night, forcing day or giving a target), you will have the bip.
I have the rfxtrx433 AND the rfxtrx433E, and both trapped the remote : Lighting 2 AC Off 6
I could toggle night / day with either the 433 or the 433E device with domoticz 2.2139.
in order to have the target temperature, i will try tomorrow the beta.
