Light switch/Doorbel Modernizer
DRB2019
Domoticz version: 4.10717
Post by DRB2019 »
I'am running a script to trigger if the doorbel is pressed, when it's pressed, than
flash some lights for a specific amount of times.
All works wel when they press the doorbel one time, when they press it two time's short after each other (within a sec.)
the light goes on burning constanly and i must switch them off manually.
How to solve this?
Below the script i use.
return
         devices = {'Deurbel Modernizr'}
    logging =
        level = domoticz.LOG_ERROR,  -- change to LOG_ERROR when ok (was LOG_DEBUG)
        if  item.state == 'On'
        then
            domoticz.devices('Overkapping').switchOn().forSec(2).repeatAfterSec(1, 8)
Running Domoticz
Version: 4.10717
Build Hash: b38b49e5
Compile Date: 2019-05-09 13:04:08
dzVents Version: 2.4.19
Re: Light switch/Doorbel Modernizer
Check this topic for some inspiration: viewtopic.php?t=18639
DRB2019
Post by DRB2019 »
Sorry for the late reply, i wil check the topic.
DRB2019
Post by DRB2019 »
I solved it in another way.
See the script below.
            devices = { 'Deurbel Modernizr' }
        data = {
            counter = { initial = 0 }
            if (domoticz.data.counter == 1) then
            domoticz.devices('Overkapping').switchOn().forSec(2).repeatAfterSec(1, 5)
            domoticz.data.counter = 0 -- reset counter
            domoticz.data.counter = domoticz.data.counter + 1
/code]
erem
Domoticz version: 2021.1
Post by erem »
the way i read your code it will only blink the lights on the 2nd press.
the first press the counter is 0.
just my $.02
Regards,
Rob
DRB2019
Post by DRB2019 »
It works, i only press the doorbel once....
erem
Post by erem »
must be me then....
i think
1st press -> counter = 0 -> counter becomes 1
2nd press -> counter = 1 -> code executes, counter is reset to 0
never mind, if it works it works
Regards,
Rob
rrozema
Post by rrozema »
You are right erem, it only works when the script gets triggered for a 2nd time. So it doesn't activate when the door bell switches on, it only activates the lights when the doorbell switches back from On to Off.
I think this will work better:
        data = {
		if switch.active then	-- only when the doorbell switches On, not when it switches Off.
        		if domoticz.data.counter == 1 then
			domoticz.data.counter = domoticz.data.counter - 1
You could also try using toggleSwitch() instead of switchOn(). I'm not sure this will work, but I expect this to switch the light off for a short period if it was on at the time the doorbell was pushed. And switch it on temporarily when it was off. The documentation doesn't mention timed command support for toggleSwitch, but the code in switc_device.lua does seem to support TimedCommand.
